Personally I would not alternate different data types in a big character table because you want to make it as simple and small as possible. From the PBP manual it says: "Lookup2 generates code that is about 3 times larger then Lookup."
So I went back to Lookup. The only other reason that you might use Lookup2 is because it can address 1024 values. The new manual for V3 says Lookup can address 1024 values but it failed after "S" and before it reached "T" which is exactly 256 values.
Me thinks the V3.0.8 compiler has a bug!
) but I couldn't make it work don't know why, I'll examine them detailed later but they are definetly very useful and easy to work with.
