two serial ports
Results 1 to 15 of 15
    Oct 2009
    Default Re: two serial ports
    Thanks again,
    I'll see if the PC application needs that action, and if not I'll try re-write the section that deals with sending and receiving data from the PC to use serial coms, thus leaving the hardware port on the PIC to deal with cons to the GLCD driver board, which for some reason or another accepts the modifiers DEC 1 etc
    Oct 2009
    Well after a lot of head scratching I have it working. No matter what I tried it still work and kept halting - Off board Tabsoft stated it worked fine for him using PBP3 so I downloaded the 15 day trial, confirmed it worked, but then as it screwed up my pbp2.60 setting, un-installed it and pointed MSC back at the PBP2.6 folder... tried again and it worked (WT* and other expletives filled the air at this point)
    Anyway, just to clear things up, I now have the GLCD running via a driver board using PORTB.0 and software serial commands (SEROUT2) and the PC application communicates with the PIC via an FTDI chip on the PICs hardware UART - and it updates juts fine
    Rightt onto the next part of tidying up the menus before replacing the FTDI chip with an ES8622 Wi-Fi module - stand by guys, no doubt I'll have a few more questions for you.
    On a serious note, I want to publically shout out a big THANK YOU to Tabsoft for all his help and contributions, both on and off the board - I'm also slowly understanding more of what I'm doing, and how PBP and it's commands work
  1. defines values for 2nd / 3rd serial ports
    By longpole001 in forum General
    Last Post: - 29th January 2015, 01:45
  2. serial ports, the servo control.
    By m.nobre in forum Serial
    Last Post: - 7th December 2009, 16:16
  3. multipal serial ports
    By Andre_Pretorius in forum Serial
    Last Post: - 11th September 2007, 14:53
  4. How many serial ports can 1 PIC handle?
    Last Post: - 2nd March 2005, 04:34
  5. Which PIC supports 2 HW serial ports?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 27th July 2004, 08:01
