Old Chestnut ? - 128 x 64 GLCD
Results 1 to 2 of 2
Threaded View
  1. #2
    Wink Re: Old Chestnut ? - 128 x 64 GLCD
    first up you need to create a font
    font8x8:
      @ DB 0X00,0X00,0X00,0X00,0X00,0X00,0X00,0                                                ' Code for char num 32
      @ DB 0X08,0X1C,0X1C,0X08,0X08,0X00,0X08,0                                                ' Code for char num 33
      @ DB 0X36,0X36,0X12,0X00,0X00,0X00,0X00,0                                                ' Code for char num 34
      @ DB 0X00,0X14,0X3E,0X14,0X14,0X3E,0X14,0                                                ' Code for char num 35
      @ DB 0X04,0X1C,0X02,0X0C,0X10,0X0E,0X08,0                                                ' Code for char num 36
      @ DB 0X26,0X26,0X10,0X08,0X04,0X32,0X32,0                                                ' Code for char num 37
      @ DB 0X04,0X0A,0X0A,0X04,0X2A,0X12,0X2C,0                                                ' Code for char num 38
      @ DB 0X0C,0X0C,0X04,0X00,0X00,0X00,0X00,0                                                ' Code for char num 39
      @ DB 0X08,0X04,0X04,0X04,0X04,0X04,0X08,0                                                ' Code for char num 40
      @ DB 0X04,0X08,0X08,0X08,0X08,0X08,0X04,0                                                ' Code for char num 41
      @ DB 0X00,0X14,0X1C,0X3E,0X1C,0X14,0X00,0                                                ' Code for char num 42
      @ DB 0X00,0X08,0X08,0X3E,0X08,0X08,0X00,0                                                ' Code for char num 43
      @ DB 0X00,0X00,0X00,0X00,0X00,0X0C,0X0C,4                                                ' Code for char num 44
      @ DB 0X00,0X00,0X00,0X3E,0X00,0X00,0X00,0                                                ' Code for char num 45
      @ DB 0X00,0X00,0X00,0X00,0X00,0X0C,0X0C,0                                                ' Code for char num 46
      @ DB 0X00,0X20,0X10,0X08,0X04,0X02,0X00,0                                                ' Code for char num 47
      @ DB 0X1C,0X22,0X32,0X2A,0X26,0X22,0X1C,0                                                ' Code for char num 48
      @ DB 0X08,0X0C,0X08,0X08,0X08,0X08,0X1C,0                                                ' Code for char num 49
      @ DB 0X1C,0X22,0X20,0X18,0X04,0X02,0X3E,0                                                ' Code for char num 50
      @ DB 0X1C,0X22,0X20,0X1C,0X20,0X22,0X1C,0                                                ' Code for char num 51
      @ DB 0X10,0X18,0X14,0X12,0X3E,0X10,0X10,0                                                ' Code for char num 52
      @ DB 0X3E,0X02,0X02,0X1E,0X20,0X22,0X1C,0                                                ' Code for char num 53
      @ DB 0X18,0X04,0X02,0X1E,0X22,0X22,0X1C,0                                                ' Code for char num 54
      @ DB 0X3E,0X20,0X10,0X08,0X04,0X04,0X04,0                                                ' Code for char num 55
      @ DB 0X1C,0X22,0X22,0X1C,0X22,0X22,0X1C,0                                                ' Code for char num 56
      @ DB 0X1C,0X22,0X22,0X3C,0X20,0X10,0X0C,0                                                ' Code for char num 57
      @ DB 0X00,0X00,0X0C,0X0C,0X00,0X0C,0X0C,0                                                ' Code for char num 58
      @ DB 0X00,0X00,0X0C,0X0C,0X00,0X0C,0X0C,4                                                ' Code for char num 59
      @ DB 0X10,0X08,0X04,0X02,0X04,0X08,0X10,0                                                ' Code for char num 60
      @ DB 0X00,0X00,0X3E,0X00,0X00,0X3E,0X00,0                                                ' Code for char num 61
      @ DB 0X04,0X08,0X10,0X20,0X10,0X08,0X04,0                                                ' Code for char num 62
      @ DB 0X1C,0X22,0X20,0X18,0X08,0X00,0X08,0                                                ' Code for char num 63
      @ DB 0X1C,0X22,0X3A,0X2A,0X3A,0X02,0X1C,0                                                ' Code for char num 64
      @ DB 0X1C,0X22,0X22,0X22,0X3E,0X22,0X22,0                                                ' Code for char num 65
      @ DB 0X1E,0X22,0X22,0X1E,0X22,0X22,0X1E,0                                                ' Code for char num 66
      @ DB 0X1C,0X22,0X02,0X02,0X02,0X22,0X1C,0                                                ' Code for char num 67
      @ DB 0X1E,0X22,0X22,0X22,0X22,0X22,0X1E,0                                                ' Code for char num 68
      @ DB 0X3E,0X02,0X02,0X1E,0X02,0X02,0X3E,0                                                ' Code for char num 69
      @ DB 0X3E,0X02,0X02,0X1E,0X02,0X02,0X02,0                                                ' Code for char num 70
      @ DB 0X1C,0X22,0X02,0X3A,0X22,0X22,0X3C,0                                                ' Code for char num 71
      @ DB 0X22,0X22,0X22,0X3E,0X22,0X22,0X22,0                                                ' Code for char num 72
      @ DB 0X1C,0X08,0X08,0X08,0X08,0X08,0X1C,0                                                ' Code for char num 73
      @ DB 0X20,0X20,0X20,0X20,0X22,0X22,0X1C,0                                                ' Code for char num 74
      @ DB 0X22,0X12,0X0A,0X06,0X0A,0X12,0X22,0                                                ' Code for char num 75
      @ DB 0X02,0X02,0X02,0X02,0X02,0X02,0X3E,0                                                ' Code for char num 76
      @ DB 0X22,0X36,0X2A,0X22,0X22,0X22,0X22,0                                                ' Code for char num 77
      @ DB 0X22,0X26,0X2A,0X32,0X22,0X22,0X22,0                                                ' Code for char num 78
      @ DB 0X1C,0X22,0X22,0X22,0X22,0X22,0X1C,0                                                ' Code for char num 79
      @ DB 0X1E,0X22,0X22,0X1E,0X02,0X02,0X02,0                                                ' Code for char num 80
      @ DB 0X1C,0X22,0X22,0X22,0X2A,0X12,0X2C,0                                                ' Code for char num 81
      @ DB 0X1E,0X22,0X22,0X1E,0X12,0X22,0X22,0                                                ' Code for char num 82
      @ DB 0X1C,0X22,0X02,0X1C,0X20,0X22,0X1C,0                                                ' Code for char num 83
      @ DB 0X3E,0X08,0X08,0X08,0X08,0X08,0X08,0                                                ' Code for char num 84
      @ DB 0X22,0X22,0X22,0X22,0X22,0X22,0X1C,0                                                ' Code for char num 85
      @ DB 0X22,0X22,0X22,0X22,0X22,0X14,0X08,0                                                ' Code for char num 86
      @ DB 0X22,0X22,0X2A,0X2A,0X2A,0X2A,0X14,0                                                ' Code for char num 87
      @ DB 0X22,0X22,0X14,0X08,0X14,0X22,0X22,0                                                ' Code for char num 88
      @ DB 0X22,0X22,0X22,0X14,0X08,0X08,0X08,0                                                ' Code for char num 89
      @ DB 0X1E,0X10,0X08,0X04,0X02,0X02,0X1E,0                                                ' Code for char num 90
    then a way to read the font
    get_chr:
      @ getaddr _font8x8, _tempPC
       tempoff = (chr-$20)*8   +  tempPC
        for i=0 to 7
            readcode tempoff +i ,cga[I]
        next
    a macro to get the fonts address
     asm
    getaddr macro Text, Addr
      movlw low Text
      movwf Addr
      movlw High Text
      movwf Addr + 1
    then put the 8 bytes in array cga[] onto the display
    ps this is for a pic18 its not easy to do it this way with a pic16
    tempPC var word
    tempoff var word
    cga var byte[8]
    I var byte
    chr var byte
    Last edited by richard; - 12th June 2015 at 03:19. Reason: spelling , still can't tyep
  1. 128 bit variable???
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 28th October 2011, 18:39
  2. old chestnut, 18f2550, fuses, osc's leds...
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 31st October 2009, 18:18
  3. max 128 + pic 16f877
    By supernono in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 14:45
  4. PIC18F4550 Error[128] Missing Arguments
    By damalu in forum mel PIC BASIC
    Last Post: - 17th November 2008, 22:47
