High Voltage NiMH battery charger
Results 1 to 9 of 9
    Default Re: High Voltage NiMH battery charger
    Oven heater element? Great idea. I too was concerned about the 1KW in silicon...
    I think the balancer is needed in LiIon batteries because they are dangerous when charged in series. In NiMH will not do harm but is not absolutely necessary.
    I do not think that the car itself is balancing the battery pack. Info on this are very limited. Sure is monitoring each cell though.
    Sep 2010
    Las Vegas, NV
    Many years ago I worked on a project where we had battery backups. Some of our batteries were NiCad and others were some weird metal combinations. The NiCads were charged and discharged as a unit but the weird ones required many little chargers that monitored each individual cell. It was the only way to ensure each cell didn't over charge or discharge. If they did over charge or discharge it ruined the cell.
    My point, Ioannis, is that I agree with your last post in that you'll need to treat the cells individually. Not only for safety but for efficient charge and balanced discharge.
    It wouldn't surprise me if the car monitored the battery using some proprietary bus scheme. Seems like cars get more and more complicated each year. Not necessarily better just more complicated.
    OK, looking at the battery pack, seems that the battery controller is much more than a charger circuit. It checks each cell and gives driver a warning if something is not good.
    Other cars just check the pack as a whole cell.
  1. Pic Battery Charger
    By Squibcakes in forum Off Topic
    Last Post: - 22nd January 2012, 06:56
  2. 9V NiMH charger
    By bogdan in forum Schematics
    Last Post: - 10th September 2009, 04:43
  3. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 20:15
  4. Pic 16Fxx Battery Charger Help
    By wbjunkie in forum Schematics
    Last Post: - 15th December 2008, 20:34
  5. Li-Ion battery charger
    By Nicmus in forum Off Topic
    Last Post: - 21st May 2008, 01:28
