High Voltage NiMH battery charger
Results 1 to 9 of 9
Threaded View
  1. #4
    Default Re: High Voltage NiMH battery charger
    Thanks for the interesting ideas.
    It gets more complicated than I thought.
    Well, my approach initially was more direct (and maybe dangerous). Make a high voltage power supply with current limiting and some more extras from a PIC to control and check the time and voltage of the battery cells.
    The client needs also to discharge the battery under control to make a couple of conditioning cycles and check at the same time the capacity of the battery pack.
    The discharge I guess is going to be a very large array of transistors on big heatsink, to act like a electronic load, controled by the PIC and also keep a record of the discharge rate.
    Too much power to convert into heat, about 1KWh. And then to charge back the pack.
    Charlie, I did not quite understood how your idea would be implemented. Could you give more details?
    This is what I want to accomplish: http://www.hybrids.co.nz/testing-com...tery-analyser/
    P.S. These batteries are "small" cells of 7.2/6.5Ah and can be disconneted from each other. So one other idea would be to charge and discharge independently. Of course this means 28 seperate circuits...
  1. Pic Battery Charger
    By Squibcakes in forum Off Topic
    Last Post: - 22nd January 2012, 06:56
  2. 9V NiMH charger
    By bogdan in forum Schematics
    Last Post: - 10th September 2009, 04:43
  3. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 20:15
  4. Pic 16Fxx Battery Charger Help
    By wbjunkie in forum Schematics
    Last Post: - 15th December 2008, 20:34
  5. Li-Ion battery charger
    By Nicmus in forum Off Topic
    Last Post: - 21st May 2008, 01:28
