High Voltage NiMH battery charger
Results 1 to 9 of 9
    Default High Voltage NiMH battery charger
    I am trying to get info on building a high voltage hybrid car NiMH battery charger.
    They are based on 28 cells of 7.2 volt/6.5Ah in series resulting in a 201,6 volts (much higher when charged).
    One idea is to seperate the battery cells and make 28 discreate chargers but this leads to higher cost.
    The other idea is to have one high voltage charger of about 300 Volts max at 0.1-0.2C with timer and voltage circuits to monitor the process.
    Any ideas welcome,
    Dec 2010
    Default Re: High Voltage NiMH battery charger
    What about charging with current pulses? Then you can use a transformer to step up the voltage, and do the current limiting on the low voltage side.
    Sep 2009
    Thanks for the interesting ideas.
    It gets more complicated than I thought.
    Well, my approach initially was more direct (and maybe dangerous). Make a high voltage power supply with current limiting and some more extras from a PIC to control and check the time and voltage of the battery cells.
    The client needs also to discharge the battery under control to make a couple of conditioning cycles and check at the same time the capacity of the battery pack.
    The discharge I guess is going to be a very large array of transistors on big heatsink, to act like a electronic load, controled by the PIC and also keep a record of the discharge rate.
    Too much power to convert into heat, about 1KWh. And then to charge back the pack.
    Charlie, I did not quite understood how your idea would be implemented. Could you give more details?
    This is what I want to accomplish: http://www.hybrids.co.nz/testing-com...tery-analyser/
    P.S. These batteries are "small" cells of 7.2/6.5Ah and can be disconneted from each other. So one other idea would be to charge and discharge independently. Of course this means 28 seperate circuits...
    Sep 2009
    Much better solution is to use oven heater element, or similar. Then just use PWM to set to desired current/power.
    Dissipating 1KW in silicone, is very bad idea...
    Oct 2009
    Utah, USA
    you may also want to consider making it possible to balance the batteries over time. As you probably know the cells will not always have the same exact capacity and voltage. Over time some batteries will become discharged before others and could suffer polarity reversal.
    Most remote control car/airplane/etc chargers have the capability to re-balance the pack. Or they use an external balancer. In order to do this you would need to extend a wire from each cell to a balancing plug. This is usually a low current process so smaller gauge wire is used.
    I see this more in the LiPo type batteries so I'm not sure if NiMh types would benefit from it.
    Just more to consider
    Dwight
  1. Pic Battery Charger
    By Squibcakes in forum Off Topic
    Last Post: - 22nd January 2012, 05:56
  2. 9V NiMH charger
    By bogdan in forum Schematics
    Last Post: - 10th September 2009, 03:43
  3. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 19:15
  4. Pic 16Fxx Battery Charger Help
    By wbjunkie in forum Schematics
    Last Post: - 15th December 2008, 19:34
  5. Li-Ion battery charger
    By Nicmus in forum Off Topic
    Last Post: - 21st May 2008, 00:28
