Dave,
from one reading to the next, the data does look consistent, but the temp is off which seems weird. I have been logging the results and they are smooth changes in temp. I think it will be a bit easier to follow what is going on with the logic analyzer if I remove the fahrenheit conversion and compare the data read to the bits on the analyzer, but that will be for another day since I don't have the analyzer set up next to where the device is mounted. Maybe then I will be able to see if I am dropping a bit someplace. I may try a different type of Temp IC also (Maybe one that also does humidity)
