Jim, I have converted much of my code from old projects using the 18F4620 to 18F46K22's. I have a few questions. What are you doing with the RESET line to the part? Are you looking at the DONE bit for the conversion to complete? If I could see the section of code you are using for configuring the part and reading it I can probably help.
                     'DS1620 Constants:
RdTmp    CON $AA        'read temperature
WrHi     CON $01        'write TH (high temp)
WrLo     CON $02        'write TL (low temp)
RdHi     CON $A1        'read TH
RdLo     CON $A2        'read TL
RdCntr   CON $A0        'read counter
RdSlope  CON $A9        'read slope
StartC   CON $EE        'start conversion
StopC    CON $22        'stop conversion
WrCfg    CON $0C        'write config register
RdCfg    CON $AC        'read config register
THi      CON 85         'high temp alarm
TLo      CON 40         'low temp alarm
                     'DS1620 Variables:
tempIn       VAR Word         ' Raw temperature + Temporary conversion var
tsign        VAR tempIn.BIT8  ' 1 = negative temperature
tC           VAR Word         ' Celsius Temp
tF           VAR Word         ' Fahrenheit Temp
tF2          VAR Word         ' Fahrenheit Temp
HIGH TRS1         ' Initialize DS1620 Temp Sensors (Once at program start)
SHIFTOUT TDAT, TCLK, LSBFIRST, [WrCfg, %10] 'Use with CPU; free-run
LOW TRS1
PAUSE 10
HIGH TRS1
SHIFTOUT TDAT, TCLK, LSBFIRST, [StartC]      'Start conversions
LOW TRS1
HIGH TRS2                                    'Alert the DS1620 #2
LOW TRS2
PAUSE 10
HIGH TRS2
LOW TRS2
Read_DS1620:
  HIGH TRS1                                     ' Alert the DS1620
  Pause 5
  SHIFTOUT TDAT, TCLK, LSBFIRST, [RdTmp]        ' Command to read temp
  SHIFTIN TDAT, TCLK, LSBPRE, [tempIn\9]        ' Read it in as 9 bit word
  LOW TRS1                                      ' Release the DS1620
  tempIn.BYTE1 = -tsign                         ' Extend sign bit
  tC = tempIn * 5                               ' Convert to tenths
  IF (tC.BIT15 = 0) THEN                        ' Temp C is positive
    tF = tC */ $01CC + 320                      ' Convert to F
  ELSE                                          ' Temp C is negative
    tF = 320 - ((ABS tC) */ $01CC)              ' Convert to F
  Pause 10
  HIGH TRS2                                     ' Alert the DS1620-2
  Pause 5
  LOW TRS2                                      ' Release the DS1620-2
    tF2 = tC */ $01CC + 320                     ' Convert to F
    tF2 = 320 - ((ABS tC) */ $01CC)             ' Convert to F
