Low power sleep mode 18f46k80
Results 1 to 12 of 12
    Feb 2012
    PERTH AUSTRALIA
    Default Low power sleep mode 18f46k80
    Hi guys trying to get the PIC to go to sleep in the lowest power mode available
    but i notice even in sleep mode i am still pulling 3ma
    also that the outputs with week pullups are still active on outputs
    wondering if this normal even when in sleep mode
    or have missed a setting
    cheers
    Sheldon
    ' config for 18F46K80
    ;----- CONFIG1L Options --------------------------------------------------
        CONFIG XINST     = OFF
        CONFIG SOSCSEL   = DIG        ; Digital (SCLKI) mode; I/O port functionality of RC0 and RC1 is enabled
        CONFIG INTOSCSEL = HIGH       ; LF-INTOSC in High-power mode during Sleep
        CONFIG RETEN     = ON         ; regulator is Enabled  (Controlled by SRETEN bit)when in sleep
    ;----- CONFIG1H Options --------------------------------------------------
        CONFIG IESO      = OFF
        CONFIG FCMEN     = OFF
        CONFIG PLLCFG    = ON
        CONFIG FOSC      = INTIO2     ; Internal RC oscillator  , PORTA.6 , PORTA.7 as I/O
    ;----- CONFIG2L Options --------------------------------------------------
        CONFIG BORPWR    = ZPBORMV    ; ZPBORMV instead of BORMV is selected
        CONFIG BORV      = 2          ; 2V
        CONFIG BOREN     = SBORDIS    ; Enabled in hardware, SBOREN disabled
        CONFIG PWRTEN    = OFF
    ;----- CONFIG2H Options --------------------------------------------------
        CONFIG WDTPS     = 512        ; 1:512
        CONFIG WDTEN     = OFF        ; WDT off
    ;----- CONFIG3L Options --------------------------------------------------
    ; no register in the device
    ;----- CONFIG3H Options --------------------------------------------------
        CONFIG MCLRE     = ON              ; MCLR ENabled FOR DIAG , RG5 DISabled
        CONFIG MSSPMSK   = MSK7            ; 7 Bit address masking mode
        CONFIG CANMX     = PORTB           ; ECAN TX and RX pins are located on RB2 and RB3, respectively
    ;----- CONFIG4L Options --------------------------------------------------
        CONFIG BBSIZ     = BB1K            ; 1K word Boot Block size
        CONFIG STVREN    = ON
    ;----- CONFIG5L Options --------------------------------------------------
        CONFIG CP0       = ON        ;  MEMORY BLOCK 0 CODE PROTECT BIT - 7KW 800h  - 3FFFh ( when 1K BOOT OPTION used )
        CONFIG CP1       = ON        ;  MEMORY BLOCK 1 CODE PROTECT BIT - 8KW 4000h - 7FFFh
        CONFIG CP2       = ON        ;  MEMORY BLOCK 2 CODE PROTECT BIT - 8KW 8000h - BFFFh
        CONFIG CP3       = ON        ;  MEMORY BLOCK 3 CODE PROTECT BIT - 8KW C000h - FFFFh
    ;----- CONFIG5H Options --------------------------------------------------
       CONFIG  CPD       = OFF        ; EEPROM DATA PREOTECT BIT - EXTERNAL R/W
       CONFIG  CPB       = ON        ; BOOT BLOCK CODE PROTECT BIT
    ;----- CONFIG6L Options --------------------------------------------------
        CONFIG WRT0      = OFF       ; MEMORY BLOCK WRITE PROTECT BIT
        CONFIG WRT1      = OFF
        CONFIG WRT2      = OFF
        CONFIG WRT3      = OFF
    ;----- CONFIG6H Options --------------------------------------------------
        CONFIG WRTD      = OFF      ; EEPROM WRITE PROTECT BIT - INTERNAL AND EXTERNAL
        CONFIG WRTB      = ON       ; BOOT BLOCK WRITE PROTECT
        CONFIG WRTC      = ON       ; CONFIGURATION REGISTER WRITE PROTECT BIT
    ;----- CONFIG7L Options --------------------------------------------------
         CONFIG EBTR0     = OFF     ; MEMORY READ TABLE BLOCK PROTECT
         CONFIG EBTR1     = OFF
         CONFIG EBTR2     = OFF
         CONFIG EBTR3     = OFF
    ;----- CONFIG7H Options --------------------------------------------------
        CONFIG EBTRB     = OFF     ; TABLE READ PROTECT BOOT
    ' =========== Power Shutdown routine ==================
    Shut_Down:
     pwr_on = 1                              ' PWR ON = 1 = OFF  - turns off power to devices external to cpu
    @ INT_DISABLE  RBC_INT                   ; TURN OFF PortB IOC Interrupts for RX_mode  - RF_IRQ pin NOT USED WHEN IR-TX
    @ INT_DISABLE  RX2_INT                   ; Turn Off  USART RX Interrupts for RX_mode  - RX input on USART not used when IR-TX for configuration
    @ INT_DISABLE  TMR0_INT                  ; disable  Timer0 interupts and start Timer0
     INTCON.1 = 0                            ' CLEAR INT0 interupt flag prior to enable
     PWR_shutdown = 0                        ' CLEAR shutdown flag
    @ INT_ENABLE INT0_INT                    ; Enable INT0 interupt to allow wakeup from Sleep command  - Triggered by PWR_SW , active Low
    OSCCON.7 =0                             ' clear  IDLEN bit ready for sleep command
    @ sleep                                  ; sleep command
    Default Re: Low power sleep mode 18f46k80
    Hi Sheldon,
    I'm not sure I can be of much assistance here but WPU are only available when the TRIS-bit is set. That is, when the pin is an output (TRIS-bit cleared) the WPU for that pin is disabled. So no, having the WPU enabled on an output pin, when in sleep mode or otherwise, is not normal and not something that should be happening.
    However, when entering sleep mode, all the peripherals are turned off (no longer clocked) but outputs that are being driven will be kept 'on' during sleep so any load you have on those outputs will be reflected in the total current drawn by the PIC.
    Feb 2012
    PERTH AUSTRALIA
    hi hendrick , yes i should have been more clear , the tris is set to input , with week pullups enabled , which shows the pin as high (output) during sleep mode
    i did try shut those down prior to sleep , which helped but in the end i needed them on so i can use the power sw
    think the cct is set for min of 3ma i try find where the leaks are
    be good if someone knows the chip well for settings for low power , suck nothing at all sleep
    i have good LDO which is powering the cpu at 3v3 with no load on the output and enabled i get about 0.3ma
    i have a mosfet controling the 3v3 to anything external to the cpu
    Hi Sheldon,
    Well, if you enable the internal pull-up resistor then "of course" the pin measures "high" - it's being pulled high by the resistor.
    The pullup current, according to the datasheet, is 50-400uA @Vdd=5.5V so if you have the pullup resistor enabled and ground the pin you'll get a current of 45-360uA thru the Vdd pin, thru the WPU resistor, out thru the pin and to GND. If you do the same thing with two pins, then another 45-360uA and so on. (This is with Vdd @5V).
    The current draw you meassure, is that of the PIC itself or on the input to the LDO? What's the quiescent current of the regulator?
    Feb 2012
    PERTH AUSTRALIA
    i have made the pcb , so need to isolate every thing and work backward , but seems i am still looking at about 2ma , which i was hoping to get to about 0.7ma , 1ma max ,
    i would like eventuly put the wdt on every 15 - 30 mins for rf update to the cct but i want to get as low as i can before considering that
    Feb 2012
    PERTH AUSTRALIA
    measured load value is at the output of the ldo of 2ma ,with only cpu , pullups enabled , power mostet Pch turned off to disable external load
    with the output from ldo pcb track cut and ldo active so no no load i get 0.3ma at the input to the ldo , ldo had max drop of 250mv below 300ma
    Feb 2012
    PERTH AUSTRALIA
    Dec 2007
    Finland
    Try to change all ports to inputs before entering sleep.
    With 18F4520 I can see big difference if I don't do that (~2mA vs 200uA, incl. quiescent current of the regulator).
    After sleep change ports back to normal settings before executing next steps.
    Also disable pull-ups and use external pull-up with power sw.
    Can you post the circuit diagram so we can see what's connected to what?
    If you have an input with a pullup resistor (internal or external) and that input is pulled low by whatever is interfaced to it then current WILL flow thru pullup resistor and contribute to the total current drawn by the circuit.
    Going to external pullup resistors powered thru a MOSFET won't gain much compared to simply disabling the internal pullups - as far as I can see.
    The dropout voltage of the regulator doesn't have much to do with this. It's the "idle current" you're interested in, how much the regulator itself consumes in order to operate. The datasheet states 150uA max
    Nov 2007
    West Covina, CA
    My experience with the PIC18F14K50 and Sleep mode.
    First thing I would suggest is to add @NOP right after the @ SLEEP command.
    It could be the rascal is not even going to sleep!
    Next make any unused pins an output (HIGH). Left floating as inputs was causing erratic higher Sleep currents that varied in the 10's to 100's of uA.
    One last thing that really cleaned house before going to sleep was @RESET.
    But my routine was structured to power up then go right to sleep until an IOC occurred that woke it up.
    After chores were done and activity was quiet for a little and nothing happening.... @RESET... get back to sleep!
    And of course the as the guys suggested, all external loads to the PIC need to be considered, they add up.
    Louie
    Feb 2012
    PERTH AUSTRALIA
    ok will try those suggestions
    as test for current
    i just had the LDO regulator and smoothing caps only - current draw was 0.25ma
    with CPU added on a bare board,
    blank cpu , no other componets except a 4k7 resistor on the MCLR pin pulled high , current draw 2.8ma( note: tried a 100k resistor as pullup with same results)
    when the cpu was held in reset state by pulling 4k7 to low - current draw was 1.5ma
    its interesting that the cpu is at 2.8ma with no code in it
    Feb 2012
    PERTH AUSTRALIA
    UPDATE
    well i founds some of the current leek during " sleep"
    started out at 3ma
    1. turning all the peripherals off - mainly the serial port which is connected to a usb module on the pcb , help reduce it by 0.9ma - brought it down to 2.1ma
    2. making all ports inputs except where i need the 1 output to be high during the shut down reduced it by 0.3ma help in sleep mode - 1.8ma
    3. only leaving on 1 pullups, i need during sleep also helped by 0.35ma -1.45ma
    i am not convinced yet i have turned off the internal regulator, or got as low as i should be able to yet for ultra low power mode for sleep ,
    i still believe i can get below 1ma
    could someone review the config settings to see if i missed anything else
    cheers
    sheldon
        CONFIG XINST     = OFF
        CONFIG INTOSCSEL = LOW        ; LF-INTOSC in low-power mode during Sleep
        CONFIG RETEN     = ON        ; Ultra Low power regulator is Enabled  (Controlled by SRETEN bit)when in sleep
        CONFIG IESO      = OFF
        CONFIG FCMEN     = OFF
        CONFIG PLLCFG    = ON
        CONFIG PWRTEN    = OFF
        CONFIG WDTEN     = OFF        ; WDT Off
        CONFIG STVREN    = ON
        CONFIG WRT1      = OFF
        CONFIG WRT2      = OFF
        CONFIG WRT3      = OFF
         CONFIG EBTR1     = OFF
         CONFIG EBTR2     = OFF
         CONFIG EBTR3     = OFF
       clear                    ' clear all varables to 0 on startup
       OSCCON   = %01100000     ' Select 32Mhz - using 8Mhz internal with PPLx4 in Config1H<3:0>  =  IDLEN =0 , 8Mhz , OSTS=0,RFIOFS=1,RC_Run (1x) OSC using PLL
                                ' Bit 7 IDLEN =0 ( sleep mode when sleep instraction executed)
                                ' Bits 6-4 -  111 = 16Mhz , 110 = 8MHz ,101 = 4 MHz, 100 = 2MHz 011 = 1MHz
                                ' If INTTSRC=0 and MFIOSEL= 0 then 010 = HF-INTOSC/32 (500Khz), 001 = HF-INTOSC/64 (250Khz) ,000 = LF-INTOSC     (31.25Khz)
                                ' If INTTSRC=0 and MFIOSEL= 1 then 010 = MF-INTOSC    (500Khz), 001 = MF-INTOSC/2  (250Khz) ,000 = LF-INTOSC     (31.25Khz)
                                ' If INTTSRC=1 and MFIOSEL= 0 then 010 = HF-INTOSC/32 (500Khz), 001 = HF-INTOSC/64 (250Khz) ,000 = HF-INTOSC/512 (31.25Khz)
                                ' If INTTSRC=1 and MFIOSEL= 1 then 010 = MF-INTOSC    (500Khz), 001 = MF-INTOSC/2  (250Khz) ,000 = MF-INTOSC/16  (31.25Khz)
                                ' Note: INTSRC = OSCTUNE<7> and MFIOSEL = OSCCON2<0>
                                ' Bit 3 - OSTS = 0 - Osc startup time out  is ruinning from internal OSC ( HF, MF or LF-INTOSC)
                                ' Bit 2 - HFIOFS =1 ( INTOSC Frq stable bit  -  1 = stable , 0 = not stable
                                ' Bits 1-0 - 00= Dephalt Pri OSc ( OSC1/2 or HF-INTOSC with/without PLL set in FOSC,3:0> config1H <3.0>
                                '            01 = SOSC osc
                                '            1x = Internal osc ( LF, MF,HF-INTOSC)
      ' OSCCON2 = $00            ' Bit 7 n/a , Bit 6 - SOSCRUN - Run status bit , Bit 5-4 n/a,
                                ' Bit 3 = SOASCGO - Osc Start control bit 1 = OSC running , 0 = OSC shut off if no requests for it
                                ' Bit 2 n/a , Bit 1 - MFIOFS 1= MFINTOSC stable  0 = Not stable
                                ' Bit 0 MFIOSEL - 1 = MF-INTOSC replaces HF-ISTOSC Freq for 500Khz,250Khz,31.25KHz) 0 = MF-INTOSC not used
       OSCTUNE = %01000000      ' Bit 7  - INTSRC - internal LF Source Select 1 = 31.25 from 16Mhz Internal /512 HF-INTOSC ) 0 = Internal 31khz OSC
                                ' Bit 6 - PLLEN - 1 PLL enabled  , 0 = PLL disabled
                                ' Bits 5-0 Frequancy callibaration 00000 = centre Frq
       WDTCON = %00010000       ' use ultra low power mode when in sleep - disable  regulator in sleep mode
                                ' Bit7 = REGSLP- Regulator Voltage Sleep Enable - 1= Reg goes into low-power Mode when in sleep mode ,0 = Reg stay in normal mode
                                ' Bit6= n/a , Bit5 = ULPLVL - Ultra lowpower Wakeup output sel 1= Vout on RA0 0= Vout on RA1 ( no effect if WDTEN in config is set  )
                                ' Bit4= SRETEN = Regulator Volt Sleep Disable bit - 1= goes into Ultra lOwpower mode in sleep ( CONFIG1L.0 =0 MUST BE SET)
                                ' Bit3=n/a , Bit2 = ULPEN - Ultra Low Power Wakup Module enable 1 = enabled , 0 = disabled
                                ' Bit1=ULPSINK- Ultra Low-power Wakeup Current Sink Enable  1= Sink enabled 0 = Sink disabled ( Not valid if ULPEN=0 )
                                ' Bit0= SWDTEN -Watchdog Timer Enable  = 1= enable watchdog 0 = Disable Watchdog ( no effect if WDTEN in config is set  )
        PSPCON.4 = 0             ' turn off parallel slave port mode - general purpose I/O mode PORTD & PORTE
        INTCON2.6 = 0          ' INTEDG0 - External Interrupt 0 Edge Select - 1= Rising Edge , 0 = Falling Edge
        INTCON2.5 = 0          ' INTEDG1 - External Interrupt 1 Edge Select - 1= Rising Edge , 0 = Falling Edge
        INTCON2.4 = 0          ' INTEDG2 - External Interrupt 2 Edge Select - 1= Rising Edge , 0 = Falling Edge
        INTCON2.3 = 0          ' INTEDG3 - External Interrupt 3 Edge Select - 1= Rising Edge , 0 = Falling Edge
        INTCON3.6 = 0          ' INT1IP  - INT1 External Interupt Priority - 1 = High Priorty , 0 = Low Priority
        INTCON3.7 = 0          ' INT2IP  - INT2 External Interupt Priority - 1 = High Priorty , 0 = Low Priority
        INTCON2.1 = 0          ' INT3IP  - INT3 External Interupt Priority - 1 = High Priorty , 0 = Low Priority
    Shut_Down:
     TRISA = $FF                             ' reduce power usage by puting port to inputs
     TRISC = $FF
     TRISD = $F7                             ' make all ports inputs except portd.3 for PWR_ON output
     TRISE = $FF
     WPUB  = $01                             ' Port B set to inputs already , turn off all week pullups except Pwr_sw input
     PMD0 = $FF                              ' TURN OFF ALL PERIPHERALS ON CPU
     PMD1 = $FF
     PMD2 = $FF
    @ NOP
     Sleep_Over:
     ' Interupt routine to recover from the sleep command
    @ reset                                     ; just reset device
    @ INT_RETURN
  1. High Power Consumption in Sleep Mode
    Last Post: - 18th September 2014, 14:29
  2. Low Power Sleep
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 4th December 2009, 15:33
  3. Replies: 4
    Last Post: - 9th October 2009, 09:01
  4. Sleep/Nap Low power consumption
    By George in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 07:19
  5. Programming 12F629 low power (Sleep)
    By Warrier in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 15:45
