EUSART's - Which timers do they use?
Results 1 to 2 of 2
    New Jersey
    Default EUSART's - Which timers do they use?
    Referencing page 12 of the 18F87J50 data sheet, the diagram has arrows pointing from EUSART1 to Timer3 and EUSART2 to Timer4. Is that true? If not, which timers are they associated with?
    For now, I need to use a pause in a timer. I know you're not supposed to do that and will remove it when the code gets refined later on. The main reason for asking the question is that when there's a long pause in Timer3 and/or Timer4, the data for HSERIN and HSERIN2 sometimes aren't received.
    If I use a pause in any timer, will the HSERIN data always be affected?
    Default Re: EUSART's - Which timers do they use?
    no , the arrows show how the modules connect to the internal data bus . not each other
    yes. if the pause is long enough to stop the rx fifo buffer from being read before incoming data causes an overflow of the rx buffer
  1. Watchdog Timers
    Last Post: - 27th August 2014, 19:03
  2. Timers and Interrupts
    By senior project1 in forum Off Topic
    Last Post: - 25th November 2008, 15:17
  3. Timers
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 15th November 2008, 21:08
  4. Timers !
    By n qwerty in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 12:39
  5. Timers perhaps?
    By Doormatt in forum mel PIC BASIC Pro
    Last Post: - 6th June 2007, 17:02
