LED Blinking while main does something else
Results 1 to 13 of 13
    May 2015
    Default LED Blinking while main does something else
    Hello, I am new to PIC programming and the forum so please be gentle. I was hoping someone could offer some suggestions on a program. I am using a PIC16f628 to check for a button press (this all works) and I have one pin set for High for a steady LED. I am trying to also have a second LED blink continuously while the main program keeps looping (checking for button presses. I am trying to use the blink LED:
    High LED5 ' Turn on LED connected to PORTB.0
    Pause 1000 ' Delay for .5 seconds
    Low LED5 ' Turn off LED connected to PORTB.0
    Pause 1000
    readbutton1:
    Pause 30
    Button bt1,0,40,0,B1,0,readbutton2
    Toggle LED1 ' Toggle LED if pressed
    readbutton2:
    Button button2,0,40,0,B2,0,readbutton1
    Toggle LED2 ' Toggle LED if pressed
    goto readbutton1
    If I have it return to main, then it blinks but the button checks are erratic. I am trying to get away from having a 555 timer in the circuit just to provide a blinking LED and was hoping something SIMPLE would work.
    Any advice would be greatly appreciated.
    Default Re: LED Blinking while main does something else
    Darrel's blinky led is what you need.
    May 2015
    Thank You Robert, I will give that a try
    May 2015
    Hello Robert,
    When compiling the Blinky code I get these ASM errors, using PBP3 (MPLABX IDE) with PIC16f628. Any ideas on the errors?
    as the error message suggests , add these lines to your code
    wsave VAR BYTE $70 SYSTEM ' location for W if in bank0
    wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1
    wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2
    Nov 2007
    West Covina, CA
    I've never used the Button command before but here's something simple to try.
    You'll probably need to modify your readbutton routines so it returns to the Main loop after testing for button activity.
    x VAR BYTE
    FOR x = 0 TO 250  ' Loop here for 1 second while monitoring
      PAUSE 4
      GOSUB readbutton1
      GOSUB readbutton2
    NEXT x
      PAUSE 4
      GOSUB readbutton1
      GOSUB readbutton2
    NEXT x
    GOTO main
    readbutton1:
      Button bt1,0,40,0,B1,0,readbutton2      ' main instead of redabutton2?
    readbutton2:
      Button button2,0,40,0,B2,0,readbutton1   ' main instead of redabutton1?
    Louie
    just read the "DT interrupts" file comments header....
    explanation is there !
    May 2015
    Richard, thanks for pointing out what was clearly staring me in the face. I will also give LinkMTech version a try. I really appreciate the help.
    Don
    SWITZERLAND (french speaking)
    Default The best broth is made in the oldest pot
    I sometimes like to use "old fashion" systems like "autonomous" blinking leds like, i.e., these ones here; there are many others - just google around.
    So when you need blinking led, just set the respective PORT and do what ever you need to and when done, reset the PORT ;-)
    No interrupts, no subroutines, just two lines of code.....
    Roger
    Default Re: The best broth is made in the oldest pot
    But if you do it the software way, you can be sure that te program is running and did not crash.
    You're right Ioannis
    Roger
    May 2015
    OK, I finally had some time to get back to it. However the code compiles fine but I don't get any output on B1. If anyone can point me to what Im missing please do. I am using a 16f628. Attached is the PBP3 code that complies. Thank You in advance.
    LED1 VAR PORTB.1
    INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
    CMCON = 7
    TRISB = 0
    INT_Handler TMR1_INT, _ToggleLED1, PBP, yes
    T1CON = $31 ; Prescaler = 8, TMR1ON
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    PAUSE 1
    GOTO Main
    ToggleLED1:
    TOGGLE LED1
    @ INT_RETURN
    no. 1 putting code in code tags
    notice how all the necessary indenting is now lost
     LED1 VAR PORTB.1
     CMCON = 7
     TRISB = 0
     PAUSE 1
     GOTO Main
     ToggleLED1:
     TOGGLE LED1
     @ INT_RETURN
    no 2. posting complete code
    the "configuration word/s" are a vital part of pic code , having to speculate makes diagnosis a hit and miss affair
    no 3. posting a sketch/description of your setup
    led1 is on what pin? , what resistor? . is mclr high ? , what vcc ? , xtal /ext clock/intosc ?
  1. Blinking LED will not Blink
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2014, 22:20
  2. PIC16F819 LED not blinking
    By ronbowalker in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 03:04
  3. blinking LED
    By kindows in forum mel PIC BASIC Pro
    Last Post: - 31st July 2009, 17:08
  4. PIC18f452 blinking led ?
    By iugmoh in forum General
    Last Post: - 7th March 2008, 15:12
  5. Why is my LED not blinking?
    By Gary Goddard in forum General
    Last Post: - 1st January 2007, 21:23
