How to work with LCD in a mode of 8 bits?
Results 1 to 10 of 10
    how about PORTA.4??? is this pin tie with pull-up resistor???
    Not sure if PBP handle the R/W pin for you. Can you add a LOW PORTE.0 and post results...
    MCU Destroyer's Avatar
    MCU Destroyer Guest
    Thumbs up
    Great thank All !
    Now all worked.
    When I use commands
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    and increased delays by 30 %, LCD has earned in a mode 4 bits.
    But nevertheless it is possible in PBP to work with LCD in a mode 8 bits?
    Feb 2004
    Germany
    Quote Originally Posted by MCU Destroyer
    DEFINE LCD_BITS 8
    But why would you want to waste 4 Port Bits?
    regards
    Ralph
    MCU Destroyer Guest
    Now I any more do not wish to spend all for nothing a bits of port. It simply question for the my general development - became already interestingly can-whether PBP work with LCD in a mode 8 bits.
    Once again all many thanks !
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  2. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 06:13
  3. Play with LCD on PICDEM
  4. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 20:06
  5. 16f88 can't get lcd to work
    By nicjo in forum General
    Last Post: - 13th December 2006, 02:20
