Serial Port Timeout
Results 1 to 5 of 5
    brighton
    Question Serial Port Timeout
    Hi People
    Could someone be able to point me in the right direction here
    I am running a Data Logger which is in sleep mode for 99% of the time
    The problem is that I wake the PIC from sleep when it receives any
    character from the Serial port and jumps to my Sub Routine Called SETMODE
    This all works fine and if I type the word SET and if the word typed is not
    correct its times out and go back to the label SLEEP_AGAIN, where the Pic
    goes back to sleep.
    This is all achieved by me linking my RX line to RBO Interrupt.
    The problem is that , once in the Label SETUP_MODE, if no character is
    received the program doesn't timeout to label SLEEP_AGAIN only if a
    character is received but
    Not the correct character.
    Is there a way I can make the program timeout if no character comes in
    Isaac
    SETUP_MODE:
    HSEROUT[" **** SET UP MODE ***** ",10,13,10,13 ]
    Hserin 2000, SLEEP_AGAIN, [WAIT ("SET")] ' Get the word SET from serial
    port
    'WAITS FOR 2 SECOND FOR THE TEXT SOIL
    Rest of program here
    what about some FOR TO NEXT loop with PAUSEUS to poll the RCIF bit???
    brighton
    Thanks steve
    \but i don't understand what you mean here
    isaac
    Can you post the PIC you use and schematic?? We can work on something for you.
    brighton
    I am using an 18f452 with the RX line tired to RB0 Interupt.
    This is because when is sleep mode any activity on the RX line (ie when i
    type in hypertheminal) the pic wakes up.
    RB0 has a 10k pullup resistor to +5v
    Isaac
  1. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  2. Microcontroller with 2 way paging application problem
  3. serial port control relay
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2006, 23:56
  4. Replies: 2
    Last Post: - 28th April 2006, 12:10
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 10:20
