Hi Richard, did you mean rotating 2D 90 degrees each time you call the function?
If so I wish I’d looked a this. It's in my display code, Tetris has to do itI used a lookup table for block rotation,
but rotated digits for vertical orientation.
its a 2d 8x8 matrix each element is 24 bits (rgb) the lot rotate 90 deg with each call . the cw and ccw both work flawlessly and are fairly quick too .
a 45 deg rotate would be interesting.
At 8x8 resolution, as you get away from even 90 deg angles, it looks horrible.
