Steampunk GPS
Results 1 to 7 of 7
Thread: Steampunk GPS
    Aug 2003
    Default Steampunk GPS
    Hi Guys
    I wanted to show a new project which is an add on for an older project.
    And an idea why timing math problem might make a headache
    and to show off.
    It’s a GPS made back in the 1920’s when GPS first arrived on the scene.
    It’s a Ublox LEA-5T timing module, I think now a generation behind the current one.
    15ns timing error when in timing mode and kept stationery after an auto position survey.
    I’m using positioning mode which is 30ns timing error.
    There is a copper plane under the module insulated with a thin dielectric.
    The antenna is QFH (Quadrifillar Helecoidial) backfire antenna for L2 (1.575 GHz),
    and is made with copper elements, brass tube stem (as they did back in that age),
    and rigid coax fed through to the tip of the antenna. It’s a backfire antenna,
    because if it was a transmitter, it would radiate toward the feed point at the tip of the antenna.
    The SPI EEPROM is for faster startup time by storing almanac information,
    but I did not use it in the end, I gathered it just start fresh each power cycle.
    The Ublox timing module was salvaged form an existing product board that was rejected by
    the manufacturer, and I had to remove it. Out of six modules, this was the only one successful
    where I didn’t lose some pads off the module. It later got a frequency output SMA connector
    underneath which isn’t present in the photos. Hope you like it
    Aug 2003
    Default Re: Steampunk GPS
    Aug 2003
    Looks like you got the plans from Jules Verne.
    LOL
    Yup. I like looking at this stuff.
    Oct 2011
    Pennsylvania
    I believe at this point you must add a vacuum tube for better accuracy!
    Aug 2003
    lol.. The display assembly could be replaced one day with nixies
    Here is the bracket made of soldered standoff hardware I copper electroplated.
    Not quite what I expected, but hey, I’ll take it...
    So a bit of a story why the whole thing almost landed in the rubbish,
    even though it works perfectly and I did not know it.. I will post a bit later.
  1. Replies: 1
    Last Post: - 27th July 2008, 06:14
  2. Gps/glcd
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 1st April 2008, 16:18
  3. GPS problem
    By pcbb in forum GPS
    Last Post: - 16th October 2007, 07:04
  4. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 02:52
  5. gps programming
    By chuckad in forum mel PIC BASIC Pro
    Last Post: - 20th June 2006, 01:02
