Elapsed Timer findings
Results 1 to 40 of 48
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Elapsed Timer findings
    i am a bit lost on what the outcome of this has been , its quite a long thread
    Aug 2003
    If you use Darrel’s original code you want to add 1 to the constant reload value you use (to the table at the top of this thread).
    It appears if you are using Tabsoft’s modified version that calculates the value for you based on crystal frequency,
    it should be correct already (and has been the whole time).
    We are still talking, but also we must be across the world from each other, I only get his emails live if I stay up late.
    I’m only waiting to see what he’d like me to do (if anything) about testing it.
    The best I can tell for all of the crystal values Darrel provided, using the correct constant value should cause the software
    to perfectly keep time indefinitely... of course crystal tolerance makes this not possible..
    but the software should not introduce any of it’s own error.
    Some testing will happen in any case, a six month long project of mine is a GPS equipped atomic clock!
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. SPWM and Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 04:16
  3. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 02:22
  4. DT Elapsed Timer
    Last Post: - 10th March 2008, 00:17
