Hserout
Results 1 to 12 of 12
Thread: Hserout
    May 2015
    Default Hserout
    I need to do serial output with PIC12F675 using HSEROUT.
    It's possible?
    Sorry for my English speech.
    Default Re: Hserout
    no get a 12f1822
    Dec 2010
    Default Re: Hserout
    Or just use SEROUT (no "H")
    Default Re: Hserout
    Or use the DEBUG function, usually makes smaller code.
    May 2015
    Default Re: Hserout
    I just used SEROUT.
    May 2015
    Default Re: Hserout
    Firstly I want to apologise for my English speech.
    What's wrong with my code? Receiver will not turning on LED, when transmitter sending command.
    Transmitter:
        __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _CP_OFF & _MCLRE_OFF & _BODEN_OFF  & _PWRTE_OFF
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    DEFINE SER_BAUD 1200
    DEFINE SER_CLROERR 1
    CMCON = 7 : TRISIO = %00010001 : ADCON0.7 = 1 : ANSEL = %00011001
    LED var GPIO.2
    i var byte
    Akumuliatorius VAR word
    Lygis var word
    Buves var word : Buves = 0
    Buves1 var word
    Buves2 var word
    Adr1 var byte : Adr1 = %00111110
    Adr2 var byte : Adr2 = %01101110
    CMD1 VAR BYTE : cmd1 = %10111110
    CMD2 var byte : cmd2 = %10011100
    FOR i = 1 TO 3
    high led : pause 400
    low led : pause 400
    NEXT i
    ADCIN 0, akumuliatorius
    if akumuliatorius <= 640 then
    high led
    low led
    adcin 3, lygis
    Buves1 = Buves - 4 : Buves2 = Buves + 4
    if Lygis <= Buves1 or Lygis >= Buves2 then
    buves = lygis
    SEROUT2 GPIO.1,813,[Adr1,Adr2,Lygis,CMD1,CMD2]
    Receiver:
    CMCON = 7 : TRISIO = %00100000
    LED var GPIO.0
    i var byte
    CMD1 VAR BYTE
    CMD2 var byte
    Lygis var word
    FOR i = 1 TO 3
    low led : pause 400
    NEXT i
    SERIN2 GPIO.5,813,[wait (Adr1,Adr2),Lygis,cmd1,cmd2]
    pause 10
    if cmd1 = %10111110 and cmd2 = %10011100 then
    high led
    low led
    pause 10
    Jan 2011
    Sydney, Australia
    Default Re: Hserout
    Hi Mazytis,
    One quick observation with your receiver code - your "pause 10" time is incredibly short. I doubt you will actually be able to see the LED change status
    Cheers
    Barry
    VK2XBP
    Default Re: Hserout
    from the manual
    SERIN2
    is not supported on 12-bit core PIC MCUs due to RAM and stack
    constraints
    use serin
    May 2015
    Default Re: Hserout
    Still not working... :/
    Transmitter:
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE SER_BAUD 2400
    INCLUDE "modedefs.bas"
    LED var GPIO.2
    i var byte
    Lygis var word
    Buves1 var word
    Buves2 var word
    FOR i = 1 TO 3
    low led : pause 400
    NEXT i
    high led
    low led
    adcin 3, lygis
    buves = lygis
    SEROUT GPIO.1,T2400,[Adr1,Adr2,Lygis,CMD1,CMD2]
    Receiver:
    LED var GPIO.0
    i var byte
    Adr1 var byte
    Adr2 var byte
    CMD1 VAR BYTE
    CMD2 var byte
    Lygis var word
    FOR i = 1 TO 3
    low led : pause 400
    NEXT i
    SERIN GPIO.5,T2400,[Adr1,Adr2,Lygis,CMD1,CMD2]
    if Adr1 = %00111110 and ADR2 = %01101110 and cmd1 = %10111110 and cmd2 = %10011100 then
    high led : pause 100
    low led
    Default Re: Hserout
    add a sync chr to the tx eg
    SEROUT GPIO.1,T2400,["*",Adr1,Adr2,Lygis,CMD1,CMD2]
    rx becomes
    SERIN GPIO.5,T2400,["*"],Adr1,Adr2,Lygis,CMD1,CMD2
    syntax for logical expressions is best done in parenthesis
    if (Adr1 = %00111110) and (ADR2 = %01101110) and (cmd1 = %10111110 )and (cmd2 = %10011100) then
    May 2015
    Default Re: Hserout
    Still the same. Maybe I don't configured something?
    Default Re: Hserout
    you might have a rmw issue
    try this
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    LED var GPIO.2
    i var byte
    Lygis var word
    Buves1 var word
    Buves2 var word
    FOR i = 1 TO 3
    low led : pause 400
    NEXT i
    high led
    low led
    gpio.0=1
    adcin 3, lygis
    buves = lygis
  1. HSEROUT Disable
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 26th January 2012, 23:50
  2. HSEROUT problem
    By karlosguay in forum Serial
    Last Post: - 11th January 2012, 19:44
  3. Hserout
    By Andre_Pretorius in forum Serial
    Last Post: - 7th June 2007, 04:45
  4. Hserout
    By MICOCALI in forum mel PIC BASIC Pro
    Last Post: - 7th August 2004, 18:08
  5. HSEROUT and 16F628A
    By fredblah in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 00:07
