Writing & Reading 2 Bytes to/from Flash
Results 1 to 12 of 12
    Default Re: Writing & Reading 2 Bytes to/from Flash
    Each PIC controller has different page size that you can WRITE to.
    For example if your chip has 64 words page, then you have to read all 64 words, change what you want, then write back the whole 64 words page.
    It is a bit clumsy but that is how it works. You cannot change only the words you really want. And if you write less tat the page size, then data will not be written!
    So, my suggestion is to make an array, get the page form Flash, make the changes, then store back to Flash the array.
    Jan 2013
    Texas USA
    Or, if reading/writing to a whole page of flash program memory does not appeal to you.
    You can always switch to a PIC model that has internally EEPROM or add an external Serial EEPROM.
    TABSoft
    Jul 2013
    Ioannis,
    This is getting more complicated than I figured.
    Might you be available to implement this for a fee?
    I can send you money in advance via PayPal.
    Jay Zebryk
    Zebryk Engineering
    Southbridge, Massachusetts
    I would also suggest adding an external I2C serial eeprom of small size and using it to store your data. Something as small as an 24LC01 1K device.
    EN82fn
    Zebryk,
    1. how many times will your write new values to flash? Flash has less durabilit than EEPROM.
    2. how many words will you store to flash? Think ahead in the future.
    3. Are you sure that the address you have chosen will be free?
    P.S. No fee necessary, we are here to help each other! Look at your P.M. also.
  1. Reading, writing, erasing flash (16F88)
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 09:13
  2. writing 256 bytes to eeprom
    By astouffer in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2008, 15:44
  3. Writing & Reading to iButton EEPROM
    By crhomberg in forum Code Examples
    Last Post: - 6th October 2008, 20:40
  4. Help reading/writing DS1996
    By Peder in forum mel PIC BASIC Pro
    Last Post: - 12th October 2007, 13:12
  5. Writing and reading to a 24LC1025
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 20th April 2007, 12:49
