formula for converting linear taper digital pot to audio taper
Results 1 to 3 of 3
    Default formula for converting linear taper digital pot to audio taper
    I'm using ADCIN on a linear analog pot to generate a number 0 - 127. This number is used to simultaneously control several 100k digital pots. Unfortunately, one of the digital pots needs to be linear taper....or I should say, its optimal taper would be linear. And I'm not so good with the math and logarithmic equations and such.
    Could someone please help me with the formula to create a taper that approximates the line in graph "TAPERS A SERIES" found here: http://www.taiwanalpha.com.tw/englis...p_e_106_10.htm
    Default Re: formula for converting linear taper digital pot to audio taper
    For "only" 127 values I'd probably go with a lookup table. Perhaps something like:
    Lookup LinValue, [0,0,0,1,1,1,1,1,2,2,2,2,3,3,3,3,4,4,4,4,4,5,5,5,5,6,6,6,7,7,7,7,8,8,8,8,9,9,9,10,_
    10,10,11,11,11,11,12,12,12,13,13,13,14,14,15,15,15,16,16,16,17,17,18,18,18,19,19,20,20,21,21,21,22,_
    22,23,23,24,24,25,26,26,27,27,28,28,29,30,30,31,32,32,33,34,35,35,36,37,38,39,40,41,42,43,44,45,46,_
    47,48,50,51,53,54,56,58,60,62,64,67,69,72,76,80,85,91,98,109,127], LogValue
    Name:  Log lookup.PNG
    Attachment 7825
    Ah, yes! That makes perfect sense. Thank you, Henrik.
  1. Audio to Digital - any sample around?
    Last Post: - 1st December 2012, 01:38
  2. Digital Pot
    Last Post: - 3rd January 2012, 07:54
  3. Digital audio delay
    By RussMartin in forum Schematics
    Last Post: - 7th July 2008, 20:55
  4. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 20:42
  5. Rx433 linear and digital output
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 29th October 2006, 21:26
