Debug/Serout/Serout2 - please, need advice ...
Results 1 to 14 of 14
    Dec 2008
    Ploiesti, ROMANIA
    Default Debug/Serout/Serout2 - please, need advice ...
    Hi !
    I try to understand how work communication between PIC and PC.
    I wrote this simple code :
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    INCLUDE "modedefs.bas"
    DEFINE OSC 04
            CMCON = 7
            VRCON = 0
            WPU = 0                 'no wake pullup
            IOCB = 0                'no int. on change
            ANSEL = %01010001
            ADCON0 = %10000001      'right just , Vref=Vdd , ch.0 , A/D on
            GPIO = %00101001        'preset I/O
            TRISIO = %00001001      'configure direction  1=input 0=output
            OPTION_REG = %10000111
    advalue        var     word
    PauseUs 50                  'sample time
            ADCON0.1 = 1                'start A/D
            @ nop
            while ADCON0.1 = 1
            wend
            advalue.byte1 = ADRESH         'get A/D value
            advalue.byte0 = ADRESL
            if advalue < 650 then
               SerOut2 GPIO.5,300,["Advalue : ",DEC advalue, 13, 10]   ; the calculated result is "93" , but ?!
    goto Main
    I use on GPIO.0 one 1k resistor to +5 volts and one 100R resistor to ground. Advalue is 93, don't ?!
    But on RealTerm I am unable to see the "real" value of Advalue, no matter what option I choose...
    What I do wrong ?!
    Thanks in advance !
    Jan 2013
    Texas USA
    Default Re: Debug/Serout/Serout2 - please, need advice ...
    Hi Fratello.
    You don't say how your PIC is connected to the PC.
    Whether you have the PIC connected via a MAX232 chip or direct to the PC.
    e.g.
    PIC -> MAX232 -> PC
    or
    PIC -> PC
    It makes a difference on how you use SEROUT or SEROUT2.
    Also, take a look in the PBP manual for the SEROUT2 command.
    I don't think your MODE setting is quite right for you comms settings on the PC, not to mention what I said above about the connectivity between the PIC and the PC.
    If you are trying to use 300 baud 8N1 then setting MODE 300 is most likely not correct.
    Read through section 5.73 (SEROUT2 command) and then look at the table in section 8.6 (SERIN2/SEROUT2 Mode List).
    With this I think you can find the correct MODE value.
    A couple of more suggestions.
    1. You have DEFINE OSC 04
    I don't know if this is an issue since no errors are reported during compile, but you may want to use DEFINE OSC 4 instead as per the manual.
    2. Try a simple program that you just send out a known text string and maybe a value via the serial port without the ADC stuff.
    See if you can get just that to work with your PC and then move on to the ADC stuff.
    Just some suggestions.
    TABSoft
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    I use simple link PIC to PC (GPIO.5 connected to DB9 - pin 2).
    I tried DEBUG command too ... with same results ...
    Of course I added in my program :
     DEFINE DEBUG_REG GPIO          'Set Debugin pin por
     DEFINE DEBUG_BIT 5             'Set Debug pin bit
     DEFINE DEBUG_BAUD 2400         'Set Debug baud rate
     DEFINE DEBUG_MODE 0            'Set Debug mode: 0=true,1=inverted
    My schematic is based on Mr.GioppY "serial voltmeter" (http://www.picbasic.co.uk/forum/showthread.php?t=7182) with modification for my purpose ...
    Mr.GioppY use, in his program :
    debug  dec TmpW dig 4,dec TmpW dig 3,",",dec TmpW dig 2,Cr,Lf
    but with VB program.
    First I tried "Debug DEC Advalue, 13, 10" , but I have same results in RealTerm.
    Aug 2003
    for 2400 baud try mode 16780 for inverted data.
    Like Tabsoft suggested, you don’t have a real RS232 serial port there.
    SEROUT2 GPIO.5,19697,[ "Hello World !!! ",$D ,$A]
    Try the above for 300 baud without a MAX232 chip.
    Aug 2003
    And if that doesn’t work, just get the chip to tell you what it is
    mode var word
    mode = 100;
    WHILE mode < 60000
    SEROUT2 GPIO.5,mode,[ "     ",DEC mode,"     ", $0D, $0A]
    mode = mode + 1;
    WEND
  1. 12f629 serout,debug and serout2 timings
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 10th January 2010, 04:13
  2. Serout/serin issues, advice required
    By Agent36 in forum mel PIC BASIC Pro
    Last Post: - 29th May 2008, 23:51
  3. debug vs serout vs serout2
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 25th March 2007, 06:35
  4. Serout/serout2
    By fowardbias in forum Serial
    Last Post: - 23rd January 2006, 06:48
  5. Debug vs SerOut Commands
    By EShatara in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 06:16
