Anyone else programming with Microchip C30? (Bitwise operation)
Results 1 to 10 of 10
    Aug 2003
    Default Re: Anyone else programming with Microchip C30? (Bitwise operation)
    Speed doesn’t address the problem Robert ( convenient floating point math),
    but I should have tried out some faster pics years ago yes!
    Richard, you’re probably right, and I didn’t think of that.
    At least 16 bit rotation should take the same time, and in this instance the bytes don’t have to be bytes.
    I don’t think C can create an alias of another variable type like PBP does (it might cost more time to access them)
    but accessing an array out of bounds has worked on every platform I’ve tried, and probably for PBP too although not needed.
    unsigned char bytearray[2];
    long longarray[2];
    Now bytearray[2],bytearray[3], etc. can access the bytes of longarray.
    you use a union
    eg
    union U32_
    unsigned long l; // For accessing the whole 32-bits
    unsigned char b[4]; // For accessing as individual bytes
    char mybyte;
    union u32_ my_array;
    my_array.l= 0b00001111000011110000111100001111
    mybyte=my_array.b[3];
    Last edited by richard; - 16th May 2015 at 02:56. Reason: can't count o's and ones
    Aug 2003
    Thanks I’m sure that will be handy.
  1. Problems with U2 programmer C30 compiled code
    By minimii in forum Off Topic
    Last Post: - 5th November 2009, 09:43
  2. Bitwise Operators
    By SterlingY in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 05:57
  3. Anybody used MPLAB's C30 C Compiler for dsPICs?
    By picnaut in forum Off Topic
    Last Post: - 6th September 2005, 23:28
  4. Bitwise AND
    By paul.mcallister in forum mel PIC BASIC Pro
    Last Post: - 16th February 2005, 05:22
  5. Bitwise Operations
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 5th November 2004, 13:58
