LCD do display - but pins check out
Results 1 to 28 of 28
    Oct 2009
    Default Re: Confirmation
    Thanks for the suggestion, but I've tried taking pin 3 to grnd and +5 but it still makes no difference. I've tried wiring the LCd direct to the pins, but still no joy, so I'm at a loss, other than break all the tracks between the PIC and it's header for the LCD, but if there is an issue with the board's through hole plating or something similar then the fault could still be there
    Jan 2013
    Texas USA
    What LCD are you using?
    TABSoft
    May 2012
    Merseyside, UK
    Default Re: LCD do display - but pins check out
    What was the board designed in...?
    Can you post the project artwork / gerbers at least ?
    Jan 2013
    Texas USA
    The E line should pulse Positive.
    If you were to send an "H" $48 to an LCD with a 4bit interface, you should see something like this.
    TABSoft
    Oct 2009
    Thanks for the further info guys.
    @Tabsoft - it's a 4 line 20 chr back lit display. I use them in all my projects and like I mentioned, works fine on the development board do something is screwed on the board, something that is taking the lines high or low and stopping the signals getting through.
    I've traced out the schematic and compared it to the board and there are quite a few mistakes, not with the LCD part as that pings out but some nets were missed in the PCB layout module when the schematic was converted, but this was with a custom part, so that might of been human error on my part. I'm going to redraw the schematic, and re-work the PCB layout and check everything three times before sending the gerbers off. Still I have some posh new green and white coasters to put my cup of tea on so I guess all was not wasted
    Thanks again for every ones contributions
    Jan 2013
    Texas USA
    Good luck there, sir.
    Nothing like PCB Coasters! I have a few myself.
    BTW what Schematic/PCB software are you using?
    TABSoft
    Oct 2009
    I use DipTrace. Up until now it's been excellent and I've produced several working boards from it.
    To be honest I think it's 50:50 human error / software error The nets show up for the custom part in the schematic, but were missing in the layout... still having spent two days now trying to sort this I think it's passed debugging and time to start from scratch
    Jan 2012
    Grid EN19MV
    Quote Originally Posted by Tabsoft View Post
    I get some of that green felt from the fabric store and glue it on the back so they don't scratch the coffee table......
    -Stephen Hawking
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 22:18
  2. Replies: 2
    Last Post: - 5th November 2009, 17:07
  3. glcd display vs lcd display
    By davids in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2009, 18:16
  4. number of PIC pins & 7-seg display
    By archendekta in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 09:00
  5. LCD DB4-DB7 4bit mode change pins?
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 01:36
