Guys, I'm debugging the mistakes I made when prototyping a PCB. I say I made, the schematic tested out OK in the DRC check, but the board failed to pick up some nets and thus I'm missing a few tracks to some components. However I've trouble shouted through the board and The PIC is running fine, I have comms through an FTDI 232RL chip, and it reads the 18B20 sensor and an corresponding monitoring LED flashes away to confirm the code is running, but the LCD simply lights up with the backlight and doesn't display anything at all.
I've traced the routing for the 4 bit data lines using a multi-meter for continuity, and using a scope I get negative pulses on enable pin, and positive pulses on the R/W pin - these are around 1.2s frequency which seem slow given that the pic is running at 40 Mhz with a 10 Mhz xtal. There are no solid blocks regardless if the contrast is grounded or taken high (or 4k7 placed between it and the 5v rail). If I replace the PIC back on the development board it works fine ! and the schematic for the LCD was taken from the manual for the EasyPIC5 board - any suggestions or further testing I can do.
