16F876 AD comparisation help needed
Results 1 to 3 of 3
    Default 16F876 AD comparisation help needed
    Hi
    First a happy newyear, and a lot off PBP projects
    As I'm a newcomer i would like to have some help from the REAL programmers
    I would like to do the following with a 16F876
    I have 5 AD channels with 5 variables (byte or word)
    I have 5 input I/O 's (pulled up) and 5 outputs (led)s
    If 1 or more inputs goes low the code has to read the representing AD converter and compare the value's
    Then an output has to become High with the AD representing the highest value
    Meanwhile the other's may become active or inactive
    I also need some hysteresis on the comparisation:
    a variable which give the minimum difference between the
    AD values before the output changes, another variable which
    determines the time before changes ( max a few seconds)
    Can anyone set me in the right direction ?
    Walter
    This is quite achieveable, easy and simple too, but short of someone writing the code for you from your description, you have to start somewhere yourself.
    What I do is generally start with a rough block diagram (doesn't have to be a flow chart) as to how I want my code to work... you've pretty much described that, but put in block form. Interconnect the blocks (on paper, back of an envelope or beer mat) so you have some sort of logical flow... (kinda like the block I've appended based on your description).
    Next work out what you've got hanging on what pin of your PIC... then finally try to code each block... and put it to the test on a prototype. If you need to, each large rough Block can be broken down into smaller blocks and a proper flow chart constructed.
    Again, short of writing the code for you, this is where you take over and continue...
    Melanie
    In a world of german electrons
    rough block diagram.pdf
    What a beautiful beer mat, I love those when it's clear that the restaurant owner had to skimp on ink. What did you drink that day?
    Be well - whoever you are.
  1. Problem with AD inputs at PIC16f873a
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 11:01
  2. question regarding an external AD converter
    By dtoohey in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 06:50
  3. PLEASE HELP ME! pic16f876a and AD tlc4541
    By luca_sheva in forum mel PIC BASIC
    Last Post: - 1st February 2005, 18:32
  4. ADC problem
    By NacNud in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 03:27
  5. 16F876 problem... absolutely baffled
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 11th December 2004, 17:07
