TIMER1 intterupt of PIC 16f88 in C
Results 1 to 3 of 3
    May 2015
    Default TIMER1 intterupt of PIC 16f88 in C
    Hi;
    I'm trying to work ultrasonic sensor (HCSR-04) with PIC16f88. Since other interrutps (RB0 and INT0) were used I'm trying to operate HCSR04 with Timer1.When I connected trigger and echo to oscillator everyting seems OK. I can see trigger and corresponding echo related with distance. I think interrupt never occurs. When I read data sheet of microcontroller I understand as RB6 is related with TMR1 interrupt. Here is my code.
    #include <xc.h>
    #define _XTAL_FREQ 8000000 // crystal freq defined as 8 Mhz
    int b;
    void main()
    OSCCON = 0b01111000;// 8 Mhz selected Internal Oscillator Freq
    INTCON = 0b11000000; // GIE and PEIE is enabled
    TRISB = 0b01000000;// RB6 selected as input(echo connected here)
    T1CON = 0b01001000; // // System clock is derived from Timer1 oscillator with
    // 1:1 prescale value and oscillator is enabled
    PIE1bits.TMR1IE=1; // tmr1 overflow is enabled
    ei(); // interrupt is enabled
    while(1)
    TMR1H = 0; //Setting Initial Value of Timer
    TMR1L = 0; //Setting Initial Value of Timer
    b = 0; // TM1 value is taken in b (look at interrupt at below)
    RB5=1;
    __delay_us(10); //trigger is sent
    RB5=0;
    __delay_ms(100); //Waiting for ECHO
    if(b>2 && b<=20) // If measured distance is between 2-20 cm led
    // at RB1 blinks
    RB1=1;
    __delay_ms(500);
    RB1=0;
    if(b>20 ) // If measured distance is higher than 20 cm led // at RB2 blinks
    RB2=1;
    __delay_ms(500);
    RB2=0;
    } // while closed
    }// main closed
    void interrupt echo()
    if(PIR1bits.TMR1IF == 1) // Code enters if when flag condition occured
    //PIE1bits.TMR1IE=0; // I also tried with that but it didn’t work
    T1CONbits.TMR1ON = 1; //Start Timer
    if(RB6 == 0) //If ECHO is LOW
    T1CONbits.TMR1ON = 0; //Stop Timer
    b = (TMR1L | (TMR1H<<8))/58; //Calculate Distance
    PIR1bits.TMR1IF=0; //Clear PORTB On*Change Interrupt flag
    //PIE1bits.TMR1IE=1;// Enable is opened if it is closed at top
    Default Re: TIMER1 intterupt of PIC 16f88
    There are a few here that use "C", but the most of us use Pic Basic. I suggest you try over at the MicroChip forums.
    Default Re: TIMER1 intterupt of PIC 16f88 in C
    timer1 is not turned on until the interrupt fires therefore it can't trigger an interrupt. the whole concept is flawed
    why no just use portb int on change (its available on a pic16f88 ) portb.rb4:7
  1. help hpwm in pic 16F88
    By selim in forum mel PIC BASIC Pro
    Last Post: - 25th March 2010, 17:51
  2. DT inst. interrupt & Timer0 with pic 16F88
    By aratti in forum mel PIC BASIC Pro
    Last Post: - 17th December 2009, 21:23
  3. timer1 help
    By robertpeach in forum mel PIC BASIC Pro
    Last Post: - 10th September 2009, 09:05
  4. 16F88 code locking pic ?
    By ruijc in forum General
    Last Post: - 2nd December 2007, 23:41
  5. Stepper motor control using PIC 16F88
    By tonykeys in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2006, 20:09
