Servos not serving
Results 1 to 10 of 10
    Jun 2011
    Indian Harbour Nova Scotia
    Default Servos not serving
    I have two servos running off a 16F887 with no issues. Both toggle back and forth at roughly a 90 degree angle, in about 2 seconds.
    I changed commands for a 12F675, mounted same on a prototype board with hefty 5 volt power supply/converter. With one servo connected (to GP1), everything is fine. With TWO connected, it's as if the time period was extended by a factor of 100: each servo does a little "tick" in about 1 second: at that rate, it will take 10 minutes or more to swing 90 degrees. Not only that but there is chattering where they can suddenly move 10 degrees. If I swap servos, same thing occurs. There is NO voltage drop on the MCU or servos when #2 is added. There is no NOISE on the power lines. Different servos create the same problem.
    On a scope I cannot see any change whatsoever. The pulses are there, varying 1.0 to about 1.5 mS, and the overall period is 20 mS. (It's a little lower, frequency is about 65 Hz instead of 50 Hz). The program is attached for the 12F675. Even when the servos are chattering, the waveforms look okay.
    Am I missing something? Is this a software or a hardware (ie MCU) problem?
    Default Re: Servos not serving
    Did you make sure the combined current is not too much?
    Jan 2013
    Texas USA
    Is your MCLR tied high?
    See this link.
    http://support.melabs.com/threads/10...ighlight=servo
    TABSoft
    Jun 2011
    When I was exercising I was thinking of my problem, checked the spec sheet but saw that GPIO can handle 25 mA each, total 125 mA for all I/O. I was way below that with two servos.
    After more checking, I was shocked to see that NOW, neither of my servos worked, so programmed the chip again with (apparently) no problems, except servos no work. Checked power: 12 volts onto board, 7.3 volts coming off 5 volt regulator! Geez. Don't know why I blew a regulator. It's a heat-sunk T0-220, all my circuitry checks out as not having shorts or anything and my 5 volt regulator never got hot.
    So I popped the 12F675 into my MikroElektronika Easy Pic V7, programmed the chip: didn't work. Threw the chip out, put in a new one and all is well: both servos work as specified.
    Thanks Tabsoft for pointing out my earlier question, same problem, 6 months ago. I'm losing it. BTW, MCLR is tied high through a 10K resistor. I will investigate WHY my circuit doesn't work.
    Obviously my prototype board - which I designed, built, and populated - is not...done right. Mea Culpa.
    Thanks for those who responded.
    may be just try this one ...
    ' Name        : ServosDumpTruck675X3.pbp
    ' Compiler    : PICBASIC PRO Compiler 3.074
    ' Development PIC  : 40-pin 16F887
    ' Target PIC  : 12F675 8 pin
    ' Hardware    : Mikro Elektronika EasyPic V7
    ' Oscillator  : 4MHz internal clock
    ' Keywords    : servo, dump truck, X3
    ' Description : PICBASIC PRO program for control of 3 (or more) servos
         __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _BODEN_ON
     DEFINE OSCCAL_1K 1
    '****Aliases*****
    servo1   Var     GPIO.1 ' Alias servo pin
    servo2   var     GPIO.2
    servo3   var     GPIO.4 ' can't use gp3...input only.
    '***Constants and Variables ***
    PWCCW   con     120    'CCW Pulse Width:  100 mS * 4 Mhz period (10uS)=1.0mS  def 100
    PWCW    con     240    'CW pulse width:   200 mS * 10uS=2.0 mS      def 200
    Refresh con     20      '20 mS refresh= 50 Hz
    pulse   var     byte
    '****Initialize****
       ADCON0		= 0
       ansel		= 0          'all digital i/o
       cmcon=%00000111  'turn off comparators
       GPIO 		= 0
       trisio 		= %00001000
     '  Low Servo1	    ' Initialize servos
     '  Low Servo2
     '  low servo3
    '****Main Program****
    Start:
    For Pulse= PWCW TO PWCCW STEP -1
    	 Low Servo1
         PulsOut servo1,pulse
    	 Low Servo2
         pulsout servo2,pulse
         Low Servo3
         pulsout servo3,pulse
         Pause Refresh - pulse - pulse - pulse
    next pulse
    for Pulse= PWCCW TO PWCW step 1
        Low Servo1
        PulsOut servo1,Pulse
        Low Servo2
        Low Servo3
    next pulse
    goto Start
    NOW ...
    1) be sure your servos supply can hold ... 3 Amps short peaks ( not a typo !!! ) ... the EP7 7805 looks a bit weak for that !!!
    2) see where the LOW commands have to be placed.
    3) your " pause refresh " value looked a bit strange ...
    Jan 2013
    Texas USA
    Alain,
    I guess I'm missing something in your "Pause Refresh - Pulse - Pulse - Pulse" statement.
    The "Pause" amount for loop # 1 will be "20 - 240 - 240 - 240 = 68ms"
    For loop #2 it will be "20 - 239 - 239 - 239 = 71ms"
    So to turn 90deg it will take 15.16 seconds?
    Is this right?
    Total Pause (ms):	   15.16
    Total Pause(Value): 15160
    Pulse	Pause
    Value Value
    240	68
    239	71
    238	74
    237	77
    236	80
    235	83
    234	86
    233	89
    232	92
    231	95
    230	98
    229	101
    228	104
    227	107
    226	110
    225	113
    224	116
    223	119
    222	122
    221	125
    220	128
    219	131
    218	134
    217	137
    216	140
    215	143
    214	146
    213	149
    212	152
    211	155
    210	158
    209	161
    208	164
    207	167
    206	170
    205	173
    204	176
    203	179
    202	182
    201	185
    200	188
    199	191
    198	194
    197	197
    196	200
    195	203
    194	206
    193	209
    192	212
    191	215
    190	218
    189	221
    188	224
    187	227
    186	230
    185	233
    184	236
    183	239
    182	242
    181	245
    180	248
    179	251
    178	254
    177	1
    176	4
    175	7
    174	10
    173	13
    172	16
    171	19
    170	22
    169	25
    168	28
    167	31
    166	34
    165	37
    164	40
    163	43
    162	46
    161	49
    160	52
    159	55
    158	58
    157	61
    156	64
    155	67
    154	70
    153	73
    152	76
    151	79
    150	82
    149	85
    148	88
    147	91
    146	94
    145	97
    144	100
    143	103
    142	106
    141	109
    140	112
    139	115
    138	118
    137	121
    136	124
    135	127
    134	130
    133	133
    132	136
    131	139
    130	142
    129	145
    128	148
    127	151
    126	154
    125	157
    124	160
    123	163
    122	166
    121	169
    120	172
    TABSoft
    Quote Originally Posted by Tabsoft View Post
    Alain,
    you're right ! I missed time scaling
    should be
    Pause Refresh - ((pulse + pulse + pulse)/100)
    note Refresh could simply be 15ms ( as precise 50 Hz repeating signal is not compulsory - only the 1.2 - 2.4 ms "1" level - )
    your travel time will simply be ...
    (240-120)* 20ms = 2.4 seconds ...
    Jun 2011
    Just wanted to say thanks to all for your insightful comments and programming hints. I printed off the stuff for later perusal and comparison to my program. I'm a "minimalist", I program with the least amount of code required (thus don't always initialize) and even build circuits with low parts counts. That's where I get into trouble...
    Thanks again.
    Jan 2013
    Texas USA
    If you want the duty cycle to be as close to 50Hz you can do this to account for the Pulsout statements, Low xx statements, For/next logic and the Pause statement.
    Change the Refresh constant value to 20000 'microseconds
    Then use this for the pause.
    Pauseus Refresh - (((pulse + pulse) + (pulse / 3)) * 10)
    This should keep the total duty cycle time to 20ms +/- (~100) microseconds.
    TABSoft
    Queenidog, Here is a program I wrote some time ago for a couple of kids to test some servos for there robot in the FIRST competition. It is a minimalist program I wrote during lunch one day. It might help. Oh I forgot, Also attached is a schematic I updated a couple of years ago. Enjoy...
    EN82fn
  1. Connecting PIC to servos
    Last Post: - 4th February 2015, 01:56
  2. Servos and Plusin math
    Last Post: - 21st May 2012, 09:28
  3. Problem with servos
    By ncet20 in forum General
    Last Post: - 11th October 2011, 14:22
  4. Hot Servos
    Last Post: - 6th August 2010, 18:32
