Embedded Strings in your Code Space
Results 1 to 40 of 50
    mytekcontrols's Avatar
    mytekcontrols Guest
    Question I would like to use Bruce's message table code, but...
    Hi Bruce,
    I have been studying your code that you posted here on doing message tables from assembly code, and quite frankly I am baffled by parts of it. This wouldn't be problem if I could use it as is, but I really need to have the pointer increments to be by 1 (i.e.; 0,1,2,3,4,5,6, ect.).
    Here are some snippits of your code with some questions I have next to them. If you get a chance can you please explain what is going on?
    ; This section appears to be locating the message table, but Im not
    ; really sure specifically what is going on especially with the first part
    ; where you are moving Upper msg_table into TBLPTRU
    ; (what is UPPER? I've used HIGH and LOW before, but never UPPER).
    ; TBLPTR is obviously short for Table Pointer.
       movlw   UPPER msg_table
       movwf   TBLPTRU
       movlw   HIGH msg_table
       movwf   TBLPTRH
       movlw   LOW msg_table
       movwf   TBLPTRL
    ; Now here we seem to be adding an offset into the message table using
    ; the same pointers we previously set to what I am asuming is the base
    ; address of our message table. This is where the beginning of a particular
    ; message resides within the table (correct?). Now here comes the questions
    ; of particular interest to me; does the fact that your pointers are in 16 byte
    ; increments mean that each message string can only be up to 16 bytes long?
    ; Or can the pointer be changed to any increment desired?
      movf    _ptr_pos,W	;prt_pos must hold message address
       addwf   TBLPTRL,F
       clrf    WREG
       addwfc  TBLPTRH,F
       addwfc  TBLPTRU,F
    ; Ok now that we have our index to a message set, we can begin retrieving
    ; the characters one by one, until we see the EOM character "~". What is
    ; tblrd   *+ or more specifically *+ (is this doing a read and then increment?)
    ; Oh and what is "goto   $-2" doing? (specifically $-2).
    Next_Char
       tblrd   *+
       movff   TABLAT,_temp
       bra     Test_EOM      ;test for EOM character
    Continue
       movf	  _temp,W	 ;move temp to w
       movwf  TXREG		 ;send it
       btfss  TXSTA,TRMT	 ;wait for data TX
       goto   $-2
       bra	  Next_Char      ;fetch next message character from table
    ; This part is fairly obvious, although there are some more of those $-2
    ; which I don't understand the purpose of, and what does "\r"
    ; and "\n" do? Actually to be more specific since I can see your comments,
    ; what my question really is; what or how does moving a literal of "\r" into
    ; W actually move the data (which I assume is a character from the table).
    Test_EOM
       movlw  "~"            ;check for EOM character
       cpfseq  _temp, 1	 ;compare temp with w, if temp = ~ then end
       bra     Continue      ;no EOM, so continue
       movlw   "\r"		 ;move data into TXREG
       movwf   TXREG	 ;send carriage return
       goto    $-2
       movlw   "\n"		 ;move data into TXREG
       movwf   TXREG	 ;send line feed
       goto    $-2
       return                ;finished with message, return to caller
    If I was better versed in the assembly aspects of the 18F series I could probably figure this out on my own, but I only recently began working with this series of PIC chips.
    Any help you can offer is appreciatted.
    Hi Michael,
    Download the PICmicro® 18C MCU Family Reference Manual... or just the chapters you need from here;
    http://www.microchip.com/stellent/id...GE&nodeId=2054
    There's a whole section on table read/write with detailed explanations that should answer every question you have.
    Much easier than me re-typing it all. If you have questions after reading section 8 let me know.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    mytekcontrols Guest
    Lightbulb Another approach...
    Hi Darrel - Hi Bruce,
    Darrel I checked out your new message table code for 16 bit pics. Very Nice!
    Bruce I read up on the info you linked me to, and I have a pretty good grasp of what you are doing in your code. I also figured out that the GOTO $-2 is just a slick way to skip backwards without having to use a labeled reference.
    Well of course after getting my brain filled with a bit more knowledge I decided to try my hand at writing yet another variation on message string handling, but not without problems (and a smoking head). Check out this code:
    DEFINE LOADER_USED 1
    DEFINE OSC 40               ' change to suit oscillator speed
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 19200      ' change to suit baud rate
    message var byte[40]
    stringsize var byte
    x var byte
    temp var byte
    Clr
        Call getSTR
    @ data "This is a string",0
        Gosub putSTR
    '    Call getSTR
    '@ data "yet another string again",0
    '    Gosub putSTR
    Done:
       Goto Done
    putSTR:
        For x = 0 To (stringsize-1)
        temp = message[x]
        Hserout [temp]
        Next x
        Hserout [$0D,$0A]       ; send carriage return + line feed
        stringsize = 0          ; reset for next message
    asm
    _getSTR
        LFSR    FSR0,_message   ; set message array base address
    ;copy return address to TBLPTR and then pop it off the stack
        movf    TOSU,W
        movwf   TBLPTRU
        movf    TOSH,W
        movwf   TBLPTRH
        movf    TOSL,W
        movwf   TBLPTRL
        POP
    ;TBLPTR should now be pointing to 1st character in string
    Next_Char
        tblrd   *+              ; table read and post increment TBLPTR
        movf    TABLAT,W        ; retrieve character to W register
        movwf   POSTINC0        ; xfer to message array and increment FSR
        incf    _stringsize,F   ; keep track of message string size
        movf    TABLAT,W        ; Is character = 0?
        bnz     Next_Char       ; If not, then get next character
    ;use incremented value of TBLPTR as new return address (push it)
        movf   TBLPTRU,W
        movwf   TOSU
        movf   TBLPTRH,W
        movwf   TOSH
        movf   TBLPTRL,W
        movwf   TOSL
        PUSH
    endasm
    It's more of a variation of what Darrel's code does. Only I wanted to try using the POP and PUSH functions on the PIC18F to allow me to have embedded message strings (this is a pet peeve of mine). Anyway if you run the code as is (leave the 2nd message string commented out) everything works great. However if you try to use more then one message (uncomment the 2nd message string) then all hell breaks loose, and you end up with garbled messages and a runaway processor.
    Any ideas what I am doing wroung?
    Well.. that certainly is a creative approach. I guess you did do some
    reading ehh..;o]
    Initialize your stringsize variable before you start incrementing it.
    Move the PUSH up to the entry point of the section "before" modifying
    TOS.
    See how this works.
    stringsize var byte
    stringsize = 0      ; <-- initialize to zero here. Don't wanna incf if it's not
    x var byte          ; starting at zero
    temp var byte
    Clr
        Call getSTR
        Gosub putSTR
        Call getSTR
        Gosub putSTR
    Done:
       Goto Done
    putSTR:
        temp = message[x]
        Hserout [temp]
        Next x
    asm
    _getSTR
        movf    TOSU,W
        movwf   TBLPTRU
        movf    TOSH,W
        movwf   TBLPTRH
        movf    TOSL,W
        movwf   TBLPTRL
        POP
    Next_Char
        PUSH ; <--- moved up to here
        movf   TBLPTRU,W
        movwf   TOSU
        movf   TBLPTRH,W
        movwf   TOSH
        movf   TBLPTRL,W
        movwf   TOSL
        ; PUSH
    endasm
    -Bruce
    tech at rentron.com
    This is getting interesting, and now I have a few new ideas too.
    But, I think We've gone past melanie's original post of "Which PBP Compiler are you using?". So I've SPLIT it into a new thread "Embedded Strings in your Code Space". In the "mel PIC BASIC Pro" forum.
    Sorry if it caused any confusion.
    More from me soon,
    &nbsp;&nbsp;&nbsp;Darrel
    mytekcontrols Guest
    Thumbs up It works!!!!
    Thanks Bruce, it works great!
    And now here it is utilizing your RS232 code:
    temp var byte
       CALL USART_Init
        Call prntSTR
        Call prntSTR
        Call prntSTR
    @ data "and one more time!",0
    Done:
       Goto Done
    asm
    _USART_Init
        movlw   B'00100100'     ; initialize USART
        movwf   TXSTA           ; 8-bit, Async, High Speed
        movlw   .129            ; value for 19200 bps @ 40MHz
        movwf   SPBRG           ; set SPBRG for 19200 bps @ 40MHz
        movlw   B'10010000'     ; enable USART
        movwf   RCSTA
    _prntSTR
        movf    TOSU,W
        movwf   TBLPTRU
        movf    TOSH,W
        movwf   TBLPTRH
        movf    TOSL,W
        movwf   TBLPTRL
        POP
    Next_Char
        movff   TABLAT,_temp    ; fetch character from message string
        bra     Test_EOM        ; go test for EOM character
    Continue                    ; If not EOM then...
        movf    _temp,W         ; move character into TXREG and...
        movwf   TXREG           ; send it!
        btfss   TXSTA,TRMT      ; has it been transmitted?
        goto    $-2             ; If not, keep checking
        bra     Next_Char       ; fetch next message character from table
    Test_EOM
        movlw   .0              ; check for EOM character
        cpfseq  _temp,W         ; compare temp with w, if temp = 0 then end
        bra     Continue        ; no EOM, so continue
        movlw   "\r"            ; move carriage return into TXREG and...
        movlw   "\n"            ; move line feed into TXREG and...
        PUSH
        movf   TBLPTRU,W
        movwf   TOSU
        movf   TBLPTRH,W
        movwf   TOSH
        movf   TBLPTRL,W
        movwf   TOSL
    endasm
    This is real sweet, because all you have are 2 lines of code to send a message, and without any limitations as to how many or where they are located (assuming it fits in the program space).
    Well this is what I wanted in the first place, all it took was a bit of head scratching and some terrific help from you and Darrel. Heck until I started reading through the PIC18F reference material, I had assumed that there was no way to PUSH and POP a PIC chip (BTW, that is a great link to all kinds of good information).
    Next: Do the same thing for an LCD. Anyone got some good LCD asm code and an LCD to try it on?
    (yet another challenge for some brave soul)
    EDIT: Opps!! Darrel I guess you'll have to move this as well... Sorry
    see ya,
    You know.. I just noticed from your earlier example that Clr wasn't returning
    an error. So just out of curiosity, I tried this.
    PBP v2.46, MPASM v4.01. Compiled for 18F452.
    DEFINE OSC 20
    ptr_pos	VAR BYTE
    temp	VAR BYTE
    x       VAR BYTE
    Yahoo           '
    NoWay          '
    YeahSoWhat  ' <-- none of this returns an error..?
        High 0
        low 0
        goto Main
    Anyone else get an error returned with this?
    -Bruce
    tech at rentron.com
    Any single word lines in PBP automaticaly become a Label. Even though they don't show up in MicroCode Studio until they have a colon ":" after them.
    So it should have been CLEAR. But it won't show up as an error if it's not.
    I guess the move went well, it seems to still be notifying us, and replies are going to the new thread. That's the first time I've split a thread, so I wasn't sure.
    Back to the topic, this isn't quite what I had thought of earlier, but the code changed since then. I haven't had a chance to try it yet, but it does compile.
    So assuming everything is working, I wanted to add one thing that gets you closer to that 1 line "embedded message strings" that you're looking for.
    Here's a simple macro that should do the same thing that you have now, but only takes 1 line (of PBP code) to do it. It needs to be before Main:
    SendStr  macro Astring
        call _prntSTR
        data Astring,0
    Now in the "Main" code, it'll look like this...
       CALL USART_Init
    @ SendStr "This is a string"
    @ SendStr "yet another string again"
    @ SendStr "and one more time!"
    OR, of course it could also be...
    Darrel
  1. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Please help with storing strings in codespace
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 02:02
