Embedded Strings in your Code Space
Results 1 to 40 of 50
Threaded View
  1. #36
    Question
    Using pin 25 RC6/TX and monitoring with MCS serial communicator at 9600 baud I get a repeating string of garbage characters. Hserout ["hello"] test result was the same. Isn't there an issue with hserout and inverted output?
    In the mean time playing around I found this code works:
    StringOut: ' Send the string out via serout
    Readcode Addr, TwoChars ' Get the 14 bit packed characters
    Char = TwoChars >> 7 ' Separate first char
    if Char = 0 then StringDone ' Look for Null char, Stop if found
    Gosub Out ' Send first char
    Char = TwoChars & $7F ' Separate second char
    Gosub out ' Send the second char
    Addr = Addr + 1 ' Point to next two characters
    Goto StringOut ' Continue with rest of the string
    StringDone:
    out:
    Serout PORTE.1,N2400,[char]:Return
    I'm trying to find a way to select ASCI character tag pairs based on a numerical index something like my flawed example below.
    Lookup index,["A1","A2","A3","A4","B1","B2","B3","B4"....... ..],#tag
    I can use codespace strings if there is no simpler way to go.
    Homerclese
  1. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Please help with storing strings in codespace
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 01:02
