Embedded Strings in your Code Space
Results 1 to 40 of 50
    Maybe this...
    StringOut:  ' Send the string out via Hserout
        Readcode Addr, TwoChars       ' Get the 14 bit packed characters
        IF TwoChars <> 0 then
            Char = TwoChars >> 7      ' Separate first char
            if Char then              ' Look for Null char, Don't send if found
               hserout [Char]         ' Send first char
            Char = TwoChars & $7F     ' Separate second char
               hserout [Char]         ' Send the second char
           Addr = Addr + 1            ' Point to next two characters
           goto StringOut	          ' Continue with rest of the string
    hmmpff... is it me or
    is unecesary since we check both character anyway???
    But it has to stop sometime.
    When you add a final ,0 to the end of the line, DA generates a 0x0000 word. So only if the whole word is 0 will it consider it the end of the "string".
    Any other 0 characters within the "string" are ignored.
    Got it..
        IF TwoChars then
            Addr=Addr+1
            Goto StringOut
    NARGH forget the above. It depend on the previous and the next string... wich doesn't happen with my first version with DT...mmm
    Forgotten
    Well, if we want to create and send a mix of String and Numeric Value, da is not the one to use even if it gives some codespace advantages.
    O.K. for Text String only. So i'll stick to my first solution that used dt
    Thanks for the tips anyway !
    Aug 2005
    Michigan, USA
    Hi Guys,
    Hope you don't mind me butting in...
    I've been using a similar method for 18F' devices in assembler for awhile now and I wonder if you might need to account for the occasional odd length character string to make sure the address is word aligned before placing it back into TOS?
    Regards, Mike
    ;  Example macro usage
            _Title  "K8LH Az/El Controller\r\n\n"
            _Print  "Satellite AOS:\r\n"
            _Print  "Satellite LOS:\r\n"
    ;  print the in-line string using Stack Pointer & TBLPTR
    PutString
    	movff	TOSH,TBLPTRH	; copy SP address to TBLPTR
    	movff	TOSL,TBLPTRL	;
    	clrf	TBLPTRU		;
    PutNxt	tblrd	*+		; get character
    	movf	TABLAT,W	; last character (00)?
    	bz	PutXit		; yes, exit
    	rcall	Put232		; else, print character
    	bra	PutNxt		; do another
    PutXit	btfsc	TBLPTRL,0	; odd address?
    	tblrd	*+		; yes, make it even (fix PC)
    	movf	TBLPTRH,W	;
    	movwf	TOSH		; update the return stack
    	movf	TBLPTRL,W	;
    	movwf	TOSL		;
            return                  ;
    Oct 2003
    Australia
    Default Nice Code DT
    I'm using this for my LCD display, but what if....
    I want to send two lines of text to my LCD?
    Normally we would send $FE, $C0 to start the second line but coding this doesn't work using your example....
    @ da "First line",$FE,$C0,"Second Line",0
    I see you guys are doing this when sending serial data, by adding 13,10,0 to the string.
    Cheers
    J
  1. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Please help with storing strings in codespace
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 02:02
