Embedded Strings in your Code Space - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
  1. #41
    Well, if we want to create and send a mix of String and Numeric Value, da is not the one to use even if it gives some codespace advantages.
    O.K. for Text String only. So i'll stick to my first solution that used dt
    Thanks for the tips anyway !
  2. #42
    Aug 2005
    Michigan, USA
    Hi Guys,
    Hope you don't mind me butting in...
    I've been using a similar method for 18F' devices in assembler for awhile now and I wonder if you might need to account for the occasional odd length character string to make sure the address is word aligned before placing it back into TOS?
    Regards, Mike
    ;  Example macro usage
            _Title  "K8LH Az/El Controller\r\n\n"
            _Print  "Satellite AOS:\r\n"
            _Print  "Satellite LOS:\r\n"
    ;  print the in-line string using Stack Pointer & TBLPTR
    PutString
    	movff	TOSH,TBLPTRH	; copy SP address to TBLPTR
    	movff	TOSL,TBLPTRL	;
    	clrf	TBLPTRU		;
    PutNxt	tblrd	*+		; get character
    	movf	TABLAT,W	; last character (00)?
    	bz	PutXit		; yes, exit
    	rcall	Put232		; else, print character
    	bra	PutNxt		; do another
    PutXit	btfsc	TBLPTRL,0	; odd address?
    	tblrd	*+		; yes, make it even (fix PC)
    	movf	TBLPTRH,W	;
    	movwf	TOSH		; update the return stack
    	movf	TBLPTRL,W	;
    	movwf	TOSL		;
            return                  ;
  3. #43
    Oct 2003
    Australia
    Default Nice Code DT
    I'm using this for my LCD display, but what if....
    I want to send two lines of text to my LCD?
    Normally we would send $FE, $C0 to start the second line but coding this doesn't work using your example....
    @ da "First line",$FE,$C0,"Second Line",0
    I see you guys are doing this when sending serial data, by adding 13,10,0 to the string.
    Cheers
    J
  4. #44
    using DA it won't work. Da pack two ascii character in a 14bit packet... 2X7Bits
    $FE (wich should be write h'FE') is over the 127 dec or 7F Hex.
    What you can do is to use something else something like
    DA "first line",1,2,"Second Line",0
    If char = 1 then char = $FE
    If char = 2 then char = $C0
  5. #45
    Question
    I use DEBUG to get to my serial pic LCD readout at 2400 baud. I have been trying to replace the hserout functions in the "string storage" thread with my usual debug output with no luck. I get repeating characters but not the expected string. I see now where there may be an issue because of the 14 bit word length but how to correct this is not clear.
    Homerclese
  6. #46
    and when you use HSEROUT ["HELLO"] it works or not?
  7. #47
    Question
    Using pin 25 RC6/TX and monitoring with MCS serial communicator at 9600 baud I get a repeating string of garbage characters. Hserout ["hello"] test result was the same. Isn't there an issue with hserout and inverted output?
    In the mean time playing around I found this code works:
    StringOut: ' Send the string out via serout
    Readcode Addr, TwoChars ' Get the 14 bit packed characters
    Char = TwoChars >> 7 ' Separate first char
    if Char = 0 then StringDone ' Look for Null char, Stop if found
    Gosub Out ' Send first char
    Char = TwoChars & $7F ' Separate second char
    Gosub out ' Send the second char
    Addr = Addr + 1 ' Point to next two characters
    Goto StringOut ' Continue with rest of the string
    StringDone:
    out:
    Serout PORTE.1,N2400,[char]:Return
    I'm trying to find a way to select ASCI character tag pairs based on a numerical index something like my flawed example below.
    Lookup index,["A1","A2","A3","A4","B1","B2","B3","B4"....... ..],#tag
    I can use codespace strings if there is no simpler way to go.
    Homerclese
  8. #48
    Yes. HSEROUT & HSERIN work with non-inverted data. There is no way
    to force inverted when using the hardware USART without an external
    inverter.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  9. #49
    Jun 2006
    California
    This was a new one on me. I was trying to work DT’s "STRINGS.PBP" code for the first time and ran across an error from MPASM, the likes of which I had never seen before.
    “The Microchip assembler (MPASM) only allows up to 62 characters for path and file name. Current length is 72 characters”
    AHHHH ??Now, I am not 100% efficient on doing a forum search, but I could not find anything like this. Stumped big time and no where to go.
    Contacted the author and low and behold I had my code buried 5 levels deep into subdirectories on my C:\ drive. Each subdirectory had long names, hence 72 characters by the time I got to the directory where I placed my "STRINGS.PBP" code. Changed the subdirectory names to shorter lengths and bingo, works fine. Even though all my projects have worked fine over the years, one needs to think how and where they store their projects,
    Thought I would share this little “tidbit” just incase someone else runs into it.
  10. #50
    Quote Originally Posted by DavidK View Post
    You aren't the 1st one to get bitten by that one. That used to bite me every once in awhile for no particular reason...and would stump me for literally hours each time.
    To cure it, awhile back I started a completely separate partition just for MPLAB, PBP, MCS, PICKIT2, all my programming stuff and keep it all in the root directory.
    Even if I do have to type something out at the command line, the line ends up being relatively short. Not to mention, I can 'dynamically' adjust the partition size with Partition Magic since the partition is so small. And I backup the whole thing at PC startup with a simple ZIP batch file straight to a thumbdrive. Practically bullet proof...and transportable...
  1. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Please help with storing strings in codespace
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 02:02
