Tmr1
Results 1 to 8 of 8
Thread: Tmr1
    May 2012
    Merseyside, UK
    Default Re: Tmr1
    Hmmmm...
    Back to drawing board then..
    TY for help.... least now I know I cant do it....
    or use a 555 on outside of pic lol
    Aug 2003
    Default Re: Tmr1
    You said in your other thread you're using GPS,
    You can easily know how long it was since someone pushed a button.
    Rather than use timer1 which might mess with software serial at a low
    crystal frequency, I would ignore GPS time which might not be present,
    and just count serial bursts which should arrive each second.
    Count 1200 serial bursts no matter what the content and go to sleep.
    Aug 2003
    Default Re: Tmr1
    ...Reset the count to zero any time a button is pushed (meaning someone is using it and they get a new 20 minutes).
    Looks like editing posts is turned off.
    I read again, and it wasn’t GPS, but you have “PAUSE 400” in a subroutine you’re calling, so you could increment a count
    to a bit more than double the 1200 in that routine.
  1. TMR1 issue
    By Lestat in forum General
    Last Post: - 29th August 2012, 15:41
  2. Tmr1
    By BobSpencerr in forum General
    Last Post: - 13th May 2008, 20:19
  3. TMR1 How it works?
    Last Post: - 12th January 2007, 14:24
  4. tmr1 on 16f690
    By dan gill in forum mel PIC BASIC Pro
    Last Post: - 25th November 2006, 21:58
  5. TMR1 question
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 7th May 2006, 01:44
