Tmr1
Results 1 to 8 of 8
Thread: Tmr1
    May 2012
    Merseyside, UK
    Default Tmr1
    Hi all
    Quick question
    Thinking of using TMR1 on a 16f688 device for a time out (PIC stays on after a button push for 20mins then goes sleep)
    Would this do that ?
    Or would you suggest another method that may be better.... Operators are forgetting to turn field loggers off!!
    Thank you
    Andy
    Default Re: Tmr1
    Yes, you can do that.
    But you're not going to get 20 minutes out of it in one go, unless you clock it externally with a very low frequency of course. Instead you're going to set it up so it overflows 10, 25, 50, 100, whatever times per second and count the number of overflows, either using interrupts or by polling the interrupt flag - depending on how the rest of the program i structured.
    May 2012
    Merseyside, UK
    Default Re: Tmr1
    Hmmmm...
    Back to drawing board then..
    TY for help.... least now I know I cant do it....
    or use a 555 on outside of pic lol
    Aug 2003
    Default Re: Tmr1
    You said in your other thread you're using GPS,
    You can easily know how long it was since someone pushed a button.
    Rather than use timer1 which might mess with software serial at a low
    crystal frequency, I would ignore GPS time which might not be present,
    and just count serial bursts which should arrive each second.
    Count 1200 serial bursts no matter what the content and go to sleep.
    Aug 2003
    Default Re: Tmr1
    ...Reset the count to zero any time a button is pushed (meaning someone is using it and they get a new 20 minutes).
    Looks like editing posts is turned off.
    I read again, and it wasn’t GPS, but you have “PAUSE 400” in a subroutine you’re calling, so you could increment a count
    to a bit more than double the 1200 in that routine.
    May 2012
    Merseyside, UK
    Default Re: Tmr1
    Hi Art
    Will try your suggestions later.... Would you believe my PC has died now. So need fix that first !! Typing this on the Mac. PBP not mac friendly!
    Thank you for suggestions
    Aug 2003
    Default Re: Tmr1
    I run a Windows partition on my Mac specifically for dev environments so that particular installation can’t see the internet
    because it doesn’t have the wifi module or network interface drivers installed.
    Everyone knows that as soon as a Windows PC sees the internet it breaks
    May 2012
    Merseyside, UK
    Default Re: Tmr1
    CQ CQ CQ VK4FAST…..
    You may have a point…. LOL
    Watch this space
    Best 73 de Andy (G7IIF)
  1. TMR1 issue
    By Lestat in forum General
    Last Post: - 29th August 2012, 16:41
  2. Tmr1
    By BobSpencerr in forum General
    Last Post: - 13th May 2008, 21:19
  3. TMR1 How it works?
    By ngeronikolos in forum mel PIC BASIC Pro
    Last Post: - 12th January 2007, 15:24
  4. tmr1 on 16f690
    By dan gill in forum mel PIC BASIC Pro
    Last Post: - 25th November 2006, 22:58
  5. TMR1 question
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 7th May 2006, 02:44
