PortE problems (PIC18F4455)
Results 1 to 16 of 16
    Mar 2005
    Thanks, I thought I'd tried everyting, but it works fine now.
    Mar 2005
    Now I would like to disable the USB-controller of this pic, because I don't need this feature and I have to use the input pins RC4 and RC5.
    I've read the datasheet and I can disable USB by setting bit3 (USBEN) of the UCON register to zero. The problem is that it looks that PBP doesn't know the commands I want to use. I think i have to use assembly. I tried the following, but I get a warning.
    MOVLW 0h
    MOVWF UCON
    Warning:
    Found opcode in collumn 1. (MOVLW)
    Found opcode in collumn 1. (MOVWF)
    I think my assembly knowledge is very bad
    Reason is that there's no UCON register definition in the PIC18EXT.bas file
    look at the end and add it like this
    TXREG2	VAR	BYTE EXT
    TXSTA	VAR	BYTE EXT
    TXSTA1	VAR	BYTE EXT
    TXSTA2	VAR	BYTE EXT
    UCON    VAR	BYTE EXT <= here
    VELRH	VAR	BYTE EXT
    VELRL	VAR	BYTE EXT
    WDTCON	VAR	BYTE EXT
    WREG	VAR	BYTE EXT
    hey!!! don't place the comment to the right
    Hi Steve,
    I also need to add UCON and UCFG for a PIC 18F4550. Adding the variables in the file mentionned above corrects the undefined error at compile time, but how do those variables get linked with the proper registers?
    Ruben,
    Unless I am mistaken, the USB module is disabled by default. That's why I need to turn it on for USB processing. If you need to use pins C4-5 as IO, you should not have any problems doing so.
    Or did I read the datasheet backwards?
    I think I found a clue from Steve about where the variable would get linked to the actual register:
    http://www.picbasic.co.uk/forum/show...75&postcount=5
    Now I have to find the right file to edit and the right address.
    Interesting, it's in the USB Descriptor and USB18 files.
    I think it is mainly dependant on whether or not the USB Voltage Regulator is enabled (which I forgot to enable).
  1. LCD Problems
    By gtx15 in forum mel PIC BASIC Pro
    Last Post: - 29th September 2007, 03:04
  2. New to PBP and having problems!
    By Lauren Barta in forum mel PIC BASIC Pro
    Last Post: - 12th October 2006, 03:49
  3. 18F6680 and portd problems.
    By jkbh in forum mel PIC BASIC Pro
    Last Post: - 6th June 2005, 10:54
  4. HSEROUT Problems
    By SergioRM in forum mel PIC BASIC Pro
    Last Post: - 7th April 2005, 23:17
  5. Display problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 17th November 2004, 23:36
