Still HSEROUT woes
Results 1 to 35 of 35
    Sep 2005
    Campbell, CA
    Default Still HSEROUT woes
    I'm using an 18F part and have a 1mSec timer interrupt using TMR0.
    I wanted to test everything by building a simple seconds counter. Inside my ISR I would count to 1000, and then set a flag. My PBP program would sit in a tight loop and test for that flag, and when it detected it was set, it would increment a counter and display the running count via the HSEROUT command. The trouble is the interrupt would crash HSEROUT. The first few characters get sent out, then a bunch of garbage. This happens every second, so I have proof that the interrupt is still running.
    I thought my trouble was because I was trashing a system variable inside my assembly-language ISR, so I went back to Tim Box's routine where virturally every PBP variable is saved and restored, and I rewrote the ISR in PBP.
    I STILL have the same problem. Is there some software timing loop inside HSEROUT that is getting screwed up?
    The program is below:
    '* Name : INT_CTRL.BAS *
    '* Author : Tim Box *
    '* Notice : Copyright (c) 2002 TJBSYSTEMS *
    '* : All Rights Reserved *
    '* Date : 28-Sep-02 *
    '* Version : 1.0 *
    '* Notes : *
    '* : Modified by C. Linquist for 18F parts 5/1/04 *
    DEFINE OSC 20 ' Set for 20Mhz operation
    DEFINE NO_CLRWDT 1
    DEFINE _18F8720 1
    DEFINE HSER_RCSTA 90H
    DEFINE HSER_TXSTA 20H
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE CCP1_REG PORTC
    DEFINE CCP1_BIT 2
    DEFINE LOADER_USED 1 ' Bootloader
    Define USE_LFSR 1
    TRISA = %11111111
    TRISB = %11111111
    TRISC = %10010001
    TRISD = %00111000
    TRISE = %00000000
    TRISF = %01111111
    TRISG = %11111100
    TRISH = %00000000
    TRISJ = %10010000
    ADCON2 = %10000010 ' Right justify 10 bit output, Clock = Fosc/32
    ADCON1 = %00010011 ' Set Vref on RA3, 12 chan A/D (AN0-AN11)
    ADCON0 = %00000001 ' Set A/D to ON, chan 0
    PSPCON = %00000000 ' No PSP
    MEMCON = %10000000 ' No External Memory
    CMCON = %00000111 ' No Comparator used, turn it off
    T0CON = %10001000
    INTCON = %11100000 ' Timer0 and Peripheral interrupts enabled
    PIE1 = %00100000 ' USART 1 receive buffer int enable
    CCPR1L = %00010000
    CCPR1H = %00000000 ' Initialize to 0, PWM register
    PR2 = $1F ' PWM register,158 Khz@20Mhz, 7 bits
    T2CON = %00000100 ' Prescale 1 - Needed for PWM
    CCP1CON= %00001100 ' Set up for PWM
    '* Declare variables *
    wsave VAR BYTE $20 SYSTEM ' Save location for the W register if in bank0
    ssave VAR BYTE Bank0 SYSTEM ' Save location for the STATUS register
    psave VAR BYTE Bank0 SYSTEM ' Save location for the PCLATH register
    fsave VAR BYTE Bank0 SYSTEM ' Save location for the FSR register
    R0_2 var WORD BANK0 ' PBP VARS TO SAVE
    R1_2 VAR WORD BANK0
    R2_2 VAR WORD BANK0
    R3_2 VAR WORD BANK0
    R4_2 VAR WORD BANK0
    R5_2 VAR WORD BANK0
    R6_2 VAR WORD BANK0
    R7_2 VAR WORD BANK0
    R8_2 VAR WORD BANK0
    FLAGS_2 VAR BYTE BANK0
    GOP_2 VAR BYTE BANK0
    RM1_2 VAR BYTE BANK0
    RM2_2 VAR BYTE BANK0
    RR1_2 VAR BYTE BANK0
    RR2_2 VAR BYTE BANK0
    TIMER VAR WORd
    X VAR WORD
    Y VAR BYTE
    SecondsCounter VAR BYTE
    TimerFlag VAR BIT
    DEFINE INTHAND INT_CODE 'Tell PBP Where your code starts on an interrupt
    T0CON = %10001000
    PIE1 = %00100000 ' Usart1 int enabled
    TimerFlag = 0
    Timer = 0
    X = 0
    SecondsCounter = 0
    GOTO OVER_INT_CODE
    asm
    INT_CODE
    MOVF R0,W
    MOVWF _R0_2
    MOVF R0 + 1,W
    MOVWF _R0_2 + 1
    MOVF R1,W
    MOVWF _R1_2
    MOVF R1 + 1,W
    MOVWF _R1_2 + 1
    MOVF R2,W
    MOVWF _R2_2
    MOVF R2 + 1,W
    MOVWF _R2_2 + 1
    MOVF R3,W
    MOVWF _R3_2
    MOVF R3 + 1,W
    MOVWF _R3_2 + 1
    MOVF R4,W
    MOVWF _R4_2
    MOVF R4 + 1,W
    MOVWF _R4_2 + 1
    MOVF R5,W
    MOVWF _R5_2
    MOVF R5 + 1,W
    MOVWF _R5_2 + 1
    MOVF R6,W
    MOVWF _R6_2
    MOVF R6 + 1,W
    MOVWF _R6_2 + 1
    MOVF R7,W
    MOVWF _R7_2
    MOVF R7 + 1 ,W
    MOVWF _R7_2 + 1
    MOVF R8,W
    MOVWF _R8_2
    MOVF R8 + 1 ,W
    MOVWF _R8_2 + 1
    IFDEF T2
    MOVF T2,W
    MOVWF _T2_2
    IFDEF FLAGS
    MOVF FLAGS,W
    MOVWF _FLAGS_2
    IFDEF GOP
    MOVF GOP,W
    MOVWF _GOP_2
    IFDEF RM1
    MOVF RM1,W
    MOVWF _RM1_2
    IFDEF RM2
    MOVF RM2,W
    MOVWF _RM2_2
    IFDEF RR1
    MOVF RR1,W
    MOVWF _RR1_2
    IFDEF RR2
    MOVF RR2,W
    MOVWF _RR2_2
    endasm
    ;%%%%%%%%%%%%%%%%%%%%%%%%% Interrupt handler written in PBP %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
    IF INTCON.2 = 1 THEN
    TMR0H = $EC
    TMR0L = $77
    Timer = Timer + 1
    IF Timer >= 1000 THEN
    TimerFlag = 1
    Timer = 0
    INTCON.2 = 0
    MOVF _R0_2,W
    MOVWF R0
    MOVF _R0_2 + 1,W
    MOVWF R0 + 1
    MOVF _R1_2,W
    MOVWF R1
    MOVF _R1_2 + 1,W
    MOVWF R1 + 1
    MOVF _R2_2,W
    MOVWF R2
    MOVF _R2_2 + 1,W
    MOVWF R2 + 1
    MOVF _R3_2,W
    MOVWF R3
    MOVF _R3_2 + 1,W
    MOVWF R3 + 1
    MOVF _R4_2,W
    MOVWF R4
    MOVF _R4_2 + 1,W
    MOVWF R4 + 1
    MOVF _R5_2,W
    MOVWF R5
    MOVF _R5_2 + 1,W
    MOVWF R5 + 1
    MOVF _R6_2,W
    MOVWF R6
    MOVF _R6_2 + 1,W
    MOVWF R6 + 1
    MOVF _R7_2,W
    MOVWF R7
    MOVF _R7_2 + 1,W
    MOVWF R7 + 1
    MOVF _R8_2,W
    MOVWF R8
    MOVF _R8_2 + 1,W
    MOVWF R8 + 1
    IFDEF FLAGS
    MOVF _FLAGS_2,W
    MOVWF FLAGS
    IFDEF FLAGS
    MOVF _GOP_2,W
    MOVWF FLAGS
    IFDEF RM1
    MOVF _RM1_2,W
    MOVWF RM1
    IFDEF RM2
    MOVF _RM2_2,W
    MOVWF RM2
    IFDEF RR1
    MOVF _RR1_2,W
    MOVWF RR1
    IFDEF RR2
    MOVF _RR2_2,W
    MOVWF RR2
    IFDEF T2
    MOVF _T2_2,W
    MOVWF T2
    Movf psave,w ; Restore the PCLATH reg
    Movwf PCLATH
    swapf ssave,w ; Restore the STATUS reg
    movwf STATUS
    swapf wsave,f
    swapf wsave,w ; Restore W reg
    Retfie ; Exit the interrupt routine
    OVER_INT_CODE:
    Topp:
    IF TimerFlag = 1 THEN
    SecondsCounter = SecondsCounter + 1
    HSEROUT ["Seconds = ",#SecondsCounter,13,10]
    TimerFlag = 0
    INTCON.7 = 1 ; Turn global ints back on
    Goto Topp
    Charles Linquist
    May 2006
    Del Rio, TX, USA
    Charles,
    It's late, so I have only taken the briefest look, but a couple of things jumped out.
    1) You never actually saved wsave, ssave, psave and fsave at the beginning of your ISR.
    2) You defined wsave, ssave, psave and fsave(and all the rest) as if you are using a PIC16. Change $20 and bank0 to banka for all of the context variables.
    3) You should use the movff command for all the context saving. It does not effect the STATUS reg. (see the datasheet example under interrupts)
    4) If you need to save a FSR, you should be saving FSRXH and FSRXL. (It doesn't at first glance look like you need to since I didn't see any commands/reference that use that register) Read the datasheet in the Memory Organization section about Data Addressing Modes (particularly Indirect Addressing)
    Start with these items. If I have some time tomorrow I'll take a closer look.
    Good night,
    Sep 2005
    Campbell, CA
    I forgot to modify Tim Box's routine.
    Here is the modified version. I went ahead and used movff instructions for ALL the registers, even the PBP ones.
    The code below has some strange behavior: It prints
    "secsecsecsecsecsec..." on the screen at one second intervals which proves that the interrupt is still running, but HSEROUT apparently gets trashed when an interrupt occurs.
    Also, I have added a USART interrupt to the mix. Hitting any key kills the routine.
    I'm stuck!
    Here is the updated code
    DEFINE NO_CLRWDT 1
    DEFINE _18F8720 1
    DEFINE CCP1_BIT 2
    Define USE_LFSR 1
    DEFINE ADC_BITS 10
    DEFINE ADC_SAMPLEUS 50
    TRISA = %11111111 'AUX1,VM12,V12,V3,V5
    TRISB = %11111111 'PDAT,PCLK,TACH6,TACH5,TACH4,TACH3,TACH2,TACH1
    TRISC = %10010001 'RX1,TX1,SDO,SDA,LEDTG,PWMOUT,LEDFG,TACH7
    TRISD = %00111000 'LED5R,LED3R,TACH8,TACH9,CTS1,RTS1,LED12G,LEDM12G
    TRISE = %00000000 'LEDV2R,LEDV2G,LED3G,LED5G,LEDFR,LEDTR,LEDM12R,LED 12R
    TRISF = %01111111 'OPTO1,FlowSig,POT2,POT1,Temp4,Temp3,Temp2,Temp1
    TRISG = %11111100 'NC,NC,NC,XPGP3,XPCP1,RX2,TX2,OPTO2
    TRISH = %00000000 'PINT2,PINT1,LCDRS,LCDRW,LCDDB7,LCDDB6,LCDDB5,LCDD B4
    TRISJ = %10010000 'SWitchIN,LEDout,LEDout,XCTSin,XPReset,LCDe,RLY,PI NT3
    T0CON = %10001000
    CCPR1L = %00010000
    wsave VAR BYTE BANKA SYSTEM ' Save location for the W register if in BANKA
    ssave VAR BYTE BANKA SYSTEM ' Save location for the STATUS register
    R0_2 var WORD BANKA ' PBP VARS TO SAVE
    R1_2 VAR WORD BANKA
    R2_2 VAR WORD BANKA
    R3_2 VAR WORD BANKA
    R4_2 VAR WORD BANKA
    R5_2 VAR WORD BANKA
    R6_2 VAR WORD BANKA
    R7_2 VAR WORD BANKA
    R8_2 VAR WORD BANKA
    FLAGS_2 VAR BYTE BANKA
    GOP_2 VAR BYTE BANKA
    RM1_2 VAR BYTE BANKA
    RM2_2 VAR BYTE BANKA
    RR1_2 VAR BYTE BANKA
    RR2_2 VAR BYTE BANKA
    TIMER VAR WORd
    X VAR WORD
    Y VAR BYTE
    TimerFlag VAR BIT
    KeyHitFlag VAR BIT
    T0CON = %10001000
    TimerFlag = 0
    Timer = 0
    X = 0
    SecondsCounter = 0
    KeyHitFlag = 0
    GOTO OVER_INT_CODE
    asm
    MOVFF WREG,wsave ; copy W to wsave register
    MOVFF STATUS,ssave
    CLRF STATUS ; change to bank 0 regardless of current bank
    INT_CODE
    MOVFF R0,_R0_2
    MOVFF R0+1,_R0_2+1
    MOVFF R1,_R1_2
    MOVFF R1+1,_R1_2+1
    MOVFF R2,_R2_2
    MOVFF R2+1,_R2_2+1
    MOVFF R3,_R3_2
    MOVFF R3+1,_R3_2+1
    MOVFF R4,_R4_2
    MOVFF R4+1,_R4_2+1
    MOVFF R5,_R5_2
    MOVFF R5+1,_R5_2+1
    MOVFF R6,_R6_2
    MOVFF R6+1,_R6_2+1
    MOVFF R7,_R7_2
    MOVFF R7+1,_R7_2+1
    MOVFF R8,_R8_2
    MOVFF R8+1,_R8_2+1
    IFDEF T2
    MOVFF T2,_T2_2
    IFDEF FLAGS
    MOVFF FLAGS,_FLAGS_2
    IFDEF GOP
    MOVFF GOP,_GOP_2
    IFDEF RM1
    MOVFF RM1,_RM1_2
    IFDEF RM2
    MOVFF RM2,_RM2_2
    IFDEF RR1
    MOVFF RR1,_RR1_2
    IFDEF RR2
    MOVFF RR2,_RR2_2
    endasm
    TMR0H = $EC ; Reload TMR0 to 65535 - 5000
    TMR0L = $77
    Timer = Timer + 1
    TimerFlag = 1
    IF PIR1.5 = 1 THEN
    KeyHitFlag = 1
    INTCON.2 = 0 ; Clear the timer flag
    MOVFF _R0_2,R0
    MOVFF _R0_2 + 1,R0 + 1
    MOVFF _R1_2,R1
    MOVFF _R1_2 + 1,R1 + 1
    MOVFF _R2_2,R2
    MOVFF _R2_2 + 1,R2 + 1
    MOVFF _R3_2,R3
    MOVFF _R3_2 + 1,R3 + 1
    MOVFF _R4_2,R4
    MOVFF _R4_2 + 1,R4 + 1
    MOVFF _R5_2,R5
    MOVFF _R5_2 + 1,R5 + 1
    MOVFF _R6_2,R6
    MOVFF _R6_2 + 1,R6 + 1
    MOVFF _R7_2,R7
    MOVFF _R7_2 + 1,R7 + 1
    MOVFF _R8_2,R8
    MOVFF _R8_2 + 1,R8 + 1
    IFDEF FLAGS
    MOVFF _FLAGS_2,FLAGS
    IFDEF FLAGS
    MOVFF _GOP_2,FLAGS
    IFDEF RM1
    MOVFF _RM1_2,RM1
    IFDEF RM2
    MOVFF _RM2_2,RM2
    IFDEF RR1
    MOVFF _RR1_2,RR1
    IFDEF RR2
    MOVFF _RR2_2,RR2
    IFDEF T2
    MOVFF _T2_2,T2
    MOVFF ssave,STATUS ; Restore the STATUS reg
    MOVFF wsave,W ; Restore W reg
    OVER_INT_CODE:
    Topp:
    TimerFlag = 0
    Timer = 0
    IF KeyHitFlag = 1 THEN
    HSERIN [Y]
    HSEROUT[Y]
    KeyHitFlag = 0
    INTCON.7 = 1 ; Turn global Ints back on
    Goto Topp
    Charles Linquist
    i'm out of stock of this PIC but i'd notice few things here..
    DEFINE _18F8720 1  ' <- What is the purpose of this one
    Define USE_LFSR 1 ' <- try to remove it
    i'll try to surf in the ASM... i'll try. Yuk! i agree sometimes we don't have choice
    Post
    mmm,
    asm
    MOVFF STATUS,ssave
    INT_CODE
    MOVFF R0,_R0_2
    MOVFF R0+1,_R0_2+1
    should be..
    asm
    INT_CODE
        MOVFF STATUS,ssave
        MOVFF R0,_R0_2
        MOVFF R0+1,_R0_2+1
    Sep 2005
    Campbell, CA
    Steve, you are absolutely correct. One of my edits went awry.
    Unfortunately, when I put the INT_CODE line in the correct place,
    nothing changes. Still no joy.
    And mister_e,
    The lines are part of my "standard" header file. I can't tell you why they
    are there. Probably some legacy issue. Anyway. I took them out.
    No change in behavior.
    Charles Linquist
    O.k then i'll try again
    Beeing said i already heard of some care about the Tim's routine.. i just don't remind where but.. humm.
    Now i'm very bad and slow in assembler debugging so, apologies..
    just an idea... how about replacing the Hserout by a TXREG=Char loop. Just by seeing the output of it, it seems the routine just redo the Hserout line without keeping track of what have been already sent...
    OR it have to exist a character pointer variable in the HSEROUT macro somewhere... if so, you probably didn't save it in the INT Handler... mmm interesting....
    pfff... maybe
           INTCON = 0
           INTCON = %11100000
           TimerFlag = 0
           Timer = 0
           INTCON = 0
           HSERIN [Y]
           HSEROUT[Y]
           INTCON = %11100000
           KeyHitFlag = 0
    ah come on brain cell (no s)... wake up...
    TMR0L = $77
    Timer = Timer + 1
    TimerFlag = 1
    IF PIR1.5 = 1 THEN
    KeyHitFlag = 1
    where the PIR1.5 is cleared?
    Sep 2005
    Campbell, CA
    In the PBP program. HSERIN clears the flag.
    Charles Linquist
    yeah right but how about if you move the main HSERIN to the interrupt routine?
    May 2006
    Del Rio, TX, USA
    What happens if you remove the line?:
    DEFINE NO_CLRWDT 1
    When I plugged you code into MPLAB and ran the sim, it gave me a watchdog timeout.
    but if the watchdog timer is not set in the config fuse, it won't change anything... at least i guess.
    Sep 2005
    Campbell, CA
    mister_e,
    You insight is very helpful! Interrupts were, indeed killing the HSEROUT routine. Setting INTCON to "0" just before the HSEROUT allows the characters to be output properly.
    Grabbing the character with HSERIN inside the ISR works as well!
    This helps a lot, but I don't believe that I can disable ints during serial transmission. MAYBE I can work around this.
    It would be nice to know if I have a bug in my ISR, or if PBP itself has a bug that prevents HSEROUT from being an interruptable routine.
    By the way. Everyone else seems to have found a nice way to include formatted code without putting it "in line". Could you please tell me how to do that?
    Charles Linquist
    Great!!!
    look the following link for VB code
    http://www.picbasic.co.uk/forum/misc.php?do=bbcode
    Sep 2005
    Campbell, CA
    Just to answer the random notes around the thread and also to summarize:
    The watchdog timer was disabled during programming.
    The interrupt worked exactly as expected (that is, it DID provide a 'tick' every
    millisecond).
    Writing the interrupt in pure assembly, saving Wreg,STATUS, FSR0L, and FSR0H
    produced EXACTLY the same result as using a modified "Tim Box" routine which saves the same registers as above PLUS all the PBP registers.
    Does this prove that HSEROUT cannot be interrupted? I have a question in to MELabs.
    Charles Linquist
    May 2006
    Del Rio, TX, USA
    Default Interrupts no problem with HSEROUT Here.
    Charles and Steve,
    I took Charles code and made a couple of slight changes (in italics) to accomadate a different PIC (PIC18F4620) and to send out a longer string of serial data. It ran just as expected.
    Here is the code I ran:
    DEFINE  OSC 40 'Oscillator speed in MHz: 3(3.58) 4 8 10 12 16 20 24 25 32 33 40
    ;define LOADER_USED 1
    @        __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
    @        __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    @        __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
    @        __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    ;DEFINE NO_CLRWDT 1
    Define USE_LFSR 1
    T0CON = %10001000
    W_HP_Save         var byte    BANKA  ' Save location for W in BANKA
    STATUS_HP_Save    var byte    BANKA  ' Save location for STATUS register in BANKA
    BSR_HP_Save       var byte    BANKA  ' Save location for BSR register in BANKA
    R1_2 VAR WORD BANKA
    R2_2 VAR WORD BANKA
    R3_2 VAR WORD BANKA
    R4_2 VAR WORD BANKA
    R5_2 VAR WORD BANKA
    R6_2 VAR WORD BANKA
    R7_2 VAR WORD BANKA
    R8_2 VAR WORD BANKA
    TIMER VAR WORd
    X VAR WORD
    Y VAR BYTE
    TimerFlag VAR BIT
    KeyHitFlag VAR BIT
    T0CON = %10001000
    TimerFlag = 0
    Timer = 0
    X = 0
    SecondsCounter = 0
    KeyHitFlag = 0
    GOTO OVER_INT_CODE
    asm
    INT_CODE
        movwf   _W_HP_Save                 ; 1 copy W to W_HP_Save register
        movff   STATUS, _STATUS_HP_Save    ; 2 copy status reg to STATUS_HP_Save
        movff   BSR, _BSR_HP_Save          ; 3 copy BSR to BSR_HP_Save
    	MOVFF R0,_R0_2
    	MOVFF R0+1,_R0_2+1
    	MOVFF R1,_R1_2
    	MOVFF R1+1,_R1_2+1
    	MOVFF R2,_R2_2
    	MOVFF R2+1,_R2_2+1
    	MOVFF R3,_R3_2
    	MOVFF R3+1,_R3_2+1
    	MOVFF R4,_R4_2
    	MOVFF R4+1,_R4_2+1
    	MOVFF R5,_R5_2
    	MOVFF R5+1,_R5_2+1
    	MOVFF R6,_R6_2
    	MOVFF R6+1,_R6_2+1
    	MOVFF R7,_R7_2
    	MOVFF R7+1,_R7_2+1
    	MOVFF R8,_R8_2
    	MOVFF R8+1,_R8_2+1
    	IFDEF T2
    	MOVFF T2,_T2_2
    	IFDEF FLAGS
    	IFDEF GOP
    	MOVFF GOP,_GOP_2
    	IFDEF RM1
    	MOVFF RM1,_RM1_2
    	IFDEF RM2
    	MOVFF RM2,_RM2_2
    	IFDEF RR1
    	MOVFF RR1,_RR1_2
    	IFDEF RR2
    	MOVFF RR2,_RR2_2
    endasm
    TMR0L = $77
    Timer = Timer + 1
    TimerFlag = 1
    IF PIR1.5 = 1 THEN
    KeyHitFlag = 1
    	MOVFF _R0_2,R0
    	MOVFF _R1_2,R1
    	MOVFF _R2_2,R2
    	MOVFF _R3_2,R3
    	MOVFF _R4_2,R4
    	MOVFF _R5_2,R5
    	MOVFF _R6_2,R6
    	MOVFF _R7_2,R7
    	MOVFF _R8_2,R8
    	IFDEF FLAGS
    	IFDEF FLAGS
    	MOVFF _GOP_2,FLAGS
    	IFDEF RM1
    	MOVFF _RM1_2,RM1
    	IFDEF RM2
    	MOVFF _RM2_2,RM2
    	IFDEF RR1
    	MOVFF _RR1_2,RR1
    	IFDEF RR2
    	MOVFF _RR2_2,RR2
    	IFDEF T2
    	MOVFF _T2_2,T2
        movff   _BSR_HP_Save, BSR          ; Restore the BSR reg
        movf    _W_HP_Save, W              ; Restore W
        movff   _STATUS_HP_Save, STATUS    ; Restore the STATUS reg
    OVER_INT_CODE:
    Topp:
    HSEROUT ["abcdefghijklmnopqrstuvwxyz1234567890ABCDEFGHIJKLMNOPQRSTUVWZYZ1234567890",_
    		rep "1"\10,rep "2"\10,rep "3"\10,rep "4"\10,rep "5"\10,13,10]
    TimerFlag = 0
    Timer = 0
    HSERIN [Y]
    HSEROUT[Y]
    KeyHitFlag = 0
    Goto Topp
    Here is the output:
    So...
    I don't think it's a problem with the HSEROUT being interrupted.
    Nicely done! That show and confirm my assembler limitation and some basic register knowledge. I really have to work harder on that.
    May 2006
    Del Rio, TX, USA
    Correction: The HSEROUT works as expected, the HSERIN does not. But I was really only looking at the interaction between interrupts and HSEROUT to begin with. I'll take a closer look at the HSERIN now.
    May 2006
    Del Rio, TX, USA
    Well, Just moving
    HSERIN [Y]
    HSEROUT[Y]
    into the ISR solved the HSERIN as mentioned.
    Despite getting it working on my equipment, we still don't know why it isn't working for Charles. I'd like to know why the difference.
    well let's see it in the simplest way... an Interrupt flag have been set, it jump to the ISR but he's not clear before going out... what happen? it return back to the ISR as soon as possible.
    As it's just a single character.. HSERIN can be changed to
    x=RCREG
    While RCREG : Discard=RCREG : Wend
    or few lines of assembler...
    OUF, at least i wasn't too far.. that's good for my own self esteem
    Sep 2005
    Campbell, CA
    I can deal with the requirement to read the RCREG from within the ISR, but having to shut off the interrupts while running HSEROUT is more problematic. I have to run full-duplex in my application. That is why I needed it interrupt-driven in the first place!
    Charles Linquist
    Sep 2005
    Campbell, CA
    SteveB:
    Confirming - I took your code and loaded it into my 8720. It works as expected, except that it doesn't handle USART interrupts (as you mentioned). I'm thinking that your routine works better because you saved/restored BSR, while I was was saving/restoring FSR0L and FSR0H.
    I have an email to MELABS. Maybe they can shed some light on this.
    When we are done, I think we will have a good framework for how to deal with interrupts in the 18F series!
    Charles Linquist
    Sep 2005
    Campbell, CA
    PROBLEM SOLVED!
    I have been conversing with Tim Box. Although he no longer writes in PBP, he had some great insights.
    I'll be able to write a short tutorial on using interrupts with 18F parts and PBP tonight.
    Many thanks to all who contributed!
    Charles Linquist
    Hangover, Germany
    ...I'm using interrupts with the 18Fxxxx and...
    the WSAVE...etc-part in front of a interrupt-handler is ONLY neccessary for PICs with up to 2048 words ? (PIC16F872). Bigger PICs don't need the code in the beginning, it is placed by PBP. The restore-code before the retfie is only used for PICs <PIC18, because they know the "retfie 1"-solution to restore all this silly registers, saved by an interrupt... (PBP doesn't support high/low-priority-Ints, so no other interrupt is used!)
    But don't try to use PBP inside a interrupt-service-routine !
    Once all PBP variable saved.. you can use PBP statement inside the ISR
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=960&stc=1&d=1152565276 ">
    18Fs are different right, but how... i can't say, as now the regular method work for my requirement... as now. So i guess i should look deeper in that one in case i need something like this.
    In this case, there's no big stuff to do in the ISR... so, my question is... is this longer to do only a pure assembler routine... or messing 'round with the known 'once the PBP variables are saved...' stuff. mmm
    I miss something in that one anyways... i'll go deeper on my side too. Maybe i could help.
    May 2006
    Del Rio, TX, USA
    OK, I've been using an 18F4620 with multiple, prioritized interrupts for a while without any problems. So here a couple of things I know for sure regarding assembly interrupts.
    1. PBP does not save context for the 18F4620 (and presumably all the PIC18s), which has >2K program space (The PIC18F2620 and PIC18F4620 each have 64 Kbytes of Flash memory and can store up to 32,768 single-word instructions.). Here are some snippets from the .lst file with some explanatory comments. It clearly shows that PBP does not enter any additional code into Assembly Interrupts.
      Here are the Defines
                            00008 ; Define statements.
                            00009 ; C:\PIC_CODE\MICROC~1\PIC18F~1\CUR\MAIN.BAS    00013   DEFINE  OSC 40 'Oscillator speed in MHz: 3(3.58)
                            00010 #define         OSC              40
                            00011 ; C:\PIC_CODE\MICROC~1\PIC18F~1\CUR\INTERRUPT_HANDLER.BAS       00009   DEFINE  INTHAND  HP_INT_ENTRY
                            00012 #define         INTHAND           HP_INT_ENTRY
                            00013 ; C:\PIC_CODE\MICROC~1\PIC18F~1\CUR\INTERRUPT_HANDLER.BAS       00010   DEFINE  INTLHAND  LP_INT_ENTRY
                            00014 #define         INTLHAND                  LP_INT_ENTRY
      Here is the beginning of the program (000000) with the interrupt vectors making an immediate jump to the interrupt routines
                            00125 ; Oscillator is 40MHz
      000000                01132     ORG RESET_ORG               ; Reset vector at 0
      000000 6A18           01137         clrf    FLAGS           ; Clear all flags on reset
      000002 EFC1 F001      01142         goto    INIT            ; Finish initialization
      000008                01153     ORG RESET_ORG + 8           ; High priority interrupt vector at 8
      000008 EFCF F001      01154         goto    INTHAND         ; Goto high priority user interrupt handler
      000018                01167     ORG RESET_ORG + 18h         ; Low priority interrupt vector at 18h
      000018 EFDC F001      01168         goto    INTLHAND        ; Goto low priority user interrupt handler
      Here is the beginning of the Interrupt handlers.  The code you see is all generated from my original code, no PBP code has been inserted to save context
                            00394 ;---[This creates the Hight Priority Interrupt Service Routine (HPISR)]---------
      00039E                00395 HP_INT_ENTRY
      00039E 6E49           00396     movwf   _W_HP_Save                 ; 1 copy W to W_HP_Save register
      0003A0 CFD8 F042      00397     movff   STATUS, _STATUS_HP_Save    ; 2 copy status reg to STATUS_HP_Save
      0003A4 CFE0 F028      00398     movff   BSR, _BSR_HP_Save          ; 3 copy BSR to BSR_HP_Save
                            00399     ;Interrupt Code
      0003A8 EFF2 F001      00400     goto    CountTicks
      0003AC                00401 ReturnFromHP
      0003AC C028 FFE0      00402     movff   _BSR_HP_Save, BSR          ; Restore the BSR reg
      0003B0 5049           00403     movf    _W_HP_Save, W              ; Restore W
      0003B2 C042 FFD8      00404     movff   _STATUS_HP_Save, STATUS    ; Restore the STATUS reg
      0003B6 0010           00405     Retfie                             ; Exit the interrupt routine
                            00406 ;-------------------------------------------------------------------------------
                            00407
                            00408
                            00409         ENDASM?
                            00410
                            00411
                            00412 ; C:\PIC_CODE\MICROC~1\PIC18F~1\CUR\INTERRUPT_HANDLER.BAS       00040   ASM
                            00413
                            00414         ASM?
                                M         RST?RP
                                M     if (PREV_BANK != 0)
                                M         movlb   0
                                M PREV_BANK = 0
                                M     endif
                            00415
                            00416 ;---[This creates the Low Priority Interrupt Service Routine (LPISR)]-----------
      0003B8                00417 LP_INT_ENTRY
      0003B8 6E4A           00418     movwf   _W_LP_Save                 ; 1 copy W to W_LP_Save register
      0003BA CFD8 F043      00419     movff   STATUS, _STATUS_LP_Save    ; 2 copy status reg to STATUS_LP_Save
      0003BE CFE0 F029      00420     movff   BSR, _BSR_LP_Save          ; 3 copy BSR to BSR_LP_Save
      0003C2 EF3C F002      00421     goto    StartSerialBuffer
      0003C6                00422 ReturnFromLP
      0003C6 C029 FFE0      00423     movff   _BSR_LP_Save, BSR          ; Restore the BSR reg
      0003CA 504A           00424     movf    _W_LP_Save, W              ; Restore W
      0003CC C043 FFD8      00425     movff   _STATUS_LP_Save, STATUS    ; Restore the STATUS reg
      0003D0 0010           00426     Retfie                             ; Exit the interrupt routine
                            00427 ;-------------------------------------------------------------------------------
    2. W, and STATUS must be saved and restored, along with any other variable/register you may change inside your ISR. Why? There is normally no way to know exactly when an interrupt will occur (hence the name). So, there is no way for the ISR to really know what the current code is doing with items like W, STATUS, FSRs, BSR (or PCLATH for PIC16), etc. Without saving and restoring these items, when the ISR gets done, the state of these things may be different than when it began, and the program will behave unpredictably
    3. With PIC18s, if High/Low priority interrupts are used, you need to save the context separately for both. See above, but with the addition that the low priority ISR can be interrupted by the high priority ISR. (See the bottom of the above code snippet)
    4. What makes PIC18s interrupts different than PIC16s? A couple of items (though not exhaustive by any means):
      1. Interrupts can be prioritized into high and low. If not using low priority interrupts, then it is very similar to how PIC16s handle interrupts
      2. Memory Organization: The way the Banks and SFR are organized in the PIC18s is fundamentally different than PIC16s. If you don't understand the difference you are bound to have some problems.
    5. Unless the PBP command has a critical timing issue (like with the software comm items), interrupts should not create any problems with the commands if the context is saved properly. Now, if the command does not rely on critical timing, but is used in a time critical manner, interrupts could create some problems related with delays (In this case, you could use INTCON to disable interrupts until the time critical bit of code was done, then re-enable). I would venture to say that most delays, if the ISR is kept as short as possible, will be completely transparent, especially if running at a fast clock rate.
    6. If PBP code is used inside the ISR, the special PBP variables should be saved for the save reasons stated above for W, STATUS, etc. The way I have done this is to start with the items listed in PBPPIC18.RAM, then once the code has been compiled, look at the .lst file and see if I've missed any. It's a bit tedious, but I end up pretty sure I got them all.
    I will be curious to see what Charles posts from his conversations with Tim Box. As I said earlier, I've been using assembly interrupts in my project with no issues on the PIC18F4620. I've got a Timer using high priority interrupts and a serial buffer using low priority interrupts. It runs at 40MHz, and the serial baud is 115200. Apart from the interrupts, some of the other items include the ubiquitous LCD (actually a salvaged VFD), an I2C RTC and EEPROM, button matrix, and some ADC inputs. So, I would have figured if the interrupts were causing problems, they would have showed up by now.
    Neat explanation to me. i'm waiting for some PIC18F8720 even if not recommended for new design) and some PIC18F8722 as suggested.
    I saw some Errata one the 8720 so far... maybe a cause but at this point unsure... so no flame please
    Ii have ton's of assumptions but i keep'em for me now.. just to keep things quiete.
    I have a stupid test to suggest... it's a test ONLY... how about using ON INTERRUPT to see if there's any progress.. from what i feel, as now the snip we have shouldn't have so much problem to work with... if there's progress... an ASM file is still generated... NO?
    Forget me if i'm wrong.
    Sep 2005
    Campbell, CA
    This is all good stuff, and I wanted to compile all that I have learned over the past few days and present it tonight. But now, I'm waiting for an explanation of a few more things from Leonard Zerman, one of the writers of PBP. I should have some really neat tips to post tomorrow night.
    Charles Linquist
    it's just pretty bad none of the Melabs team post few time in here... At least, having using it few times before, i agree that they provide a pretty nice e-mail support.
    Maybe this will help.
    DT_INTS-18
    http://www.picbasic.co.uk/forum/showthread.php?p=23031
    Why i had that feeling that you already worked on that and... harder on the last days
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=881&d=1148640458">
    Thanks Darrel!
    Yes I did! &nbsp; On both accounts.
    Thanks Steve!
    May 2006
    Del Rio, TX, USA
    Thumbs up Well Done!
    Darrel,
    I think your link to DT_INTS-18 is worth a separate post in the Code Examples section. (Possibly even in the PBP Extensions section as well)
    Based on the time on your post, it looks like you have spent at least one late night/early morning (no doubt more) getting this ready for "Prime Time". Know that there are many who appreciate your time and effort. I recall a post where Melanie suggested to someone to look into how many solutions vs. questions folks like yourself, Bruce, and the like, post. It certainly drives home the point that this forum is fortunate to have generous, knowledgeable people involved.
    More than just use your code, let's hope folks actually take a good look at the inner workings and learn from it.
    (Sorry, I haven't got any cool dancing letter's LOL.)
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 17:44
  2. hserin and sms controller
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 15:49
  3. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 19:12
  4. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 16:26
  5. Controlling an 240x128 LCD Touchpanel Display
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 7th June 2006, 23:36
