Counter
Results 1 to 7 of 7
Thread: Counter
    Jan 2008
    Default Counter
    Anyone have a simple example of how I can do something like this but with larger numbers then 65535?
    Counter VAR WORD
    Loop:
    Counter = Counter + 1
    lcdout $FE, line1,"Counter:", #Counter
    PAUSE 100
    Goto Loop
    Default Re: Counter
    Well, the obvious, if using an 18F part
    Counter VAR LONG
    Main:   ' Don't use Loop as a label, it's a reserved word.
    lcdout $FE, line1,"Counter:", DEC Counter    ' I think there's a problem with using # with LONG
    PAUSE 100
    Goto Main
    If you don't have an 18F part and all you want is a simple counter then perhaps something like this might work (not tested), it should count to 655 milions and a bit beyond:
    TenThousands VAR WORD
    Ones VAR WORD
    Ones = Ones + 1
    If Ones = 10000 THEN
      Ones = 0
      TenThousands = TenThousands + 1
    LCDOUT $FE, line1, Counter: "
    IF TenThousands > 0 THEN
      LDCOUT DEC TenThousands, DEC4 Ones
      LCDOUT DEC Ones
    Jan 2008
    Default Re: Counter
    The code works perfect on a 16F886, thank you Henrik!
    Default Re: Counter
    I'll bet that even if you own PBP3 and a 18F series chip, the code Henrik posted, will be using less memory and will be much faster than using Long variables.
    Default Re: Counter
    Thanks for the feedback Fredrick!
    Just a note, you don't need PBP3 to use LONGs, support for that were added in v2.5.
    You do need an 18F part though. But, as Ioannis said, for a simple counter like that it's probably not worth the "cost" having them enabled.
    Default Re: Counter
    Right, my error. Its been too long, right?
    Aug 2003
    Default Re: Counter
    It does work for display, I did 15 digit numbers with a 16F628 the same way it was done on paper in school
    with allowance for 16 digit result for a character LCD
    Just a shame if you wanted the result in a variable, but you could probably write a good & proper calculator.
    123456789012345 *
    012345678901234
    _______________
    _______________
  1. counter
    By daydream in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2012, 04:52
  2. Counter
    By brenda in forum mel PIC BASIC Pro
    Last Post: - 27th October 2008, 08:57
  3. counter
    By jankraak in forum General
    Last Post: - 11th October 2008, 15:37
  4. Counter
    By ALI_ALVANDPOUR in forum mel PIC BASIC Pro
    Last Post: - 13th October 2007, 19:49
  5. Replies: 1
    Last Post: - 27th September 2007, 19:15
