DHT Sensor Library
Results 1 to 9 of 9
    Jan 2013
    Texas USA
    Default Re: DHT Sensor Library
    Sorry for the delayed response.
    Here is the library for PBP3.
    PBP3_DHT_LIB_v004.zip
    Enjoy.
    TABSoft
    How to remove unused sensors?
    I'm using only one, but when I comment out DHT_Sensor2 and others, code won't compile.
    Or I should leave these as is?
    Oct 2009
    LOL - I've not been on this forum for years, and today received notification of your post... How you doing ?
    Like I said I've not been active on here for some years, and no longer program in PBP so I'm rusty when it comes to the workings
    Comments taken form that library file file suggest
    '-- To REMOVE SENSORS perform the following:                              --
    '--   1. Change the "AM2302_MAX_SENSORS" constant to the correct number.  --
    '--   2. Comment out the appropriate "AM2302_Sensor_x" Alias lines.       --
    '--   3. In the "AM2302_Read" subroutine in the library file,             --
    '--      edit the "select case AM2302_Sensor_Num" block, comment out the  --
    '--      "Case x" portion for the sensor number you want to remove.       --
    '--   4. Comment out the entire "AM_Readx" subroutine at the end          --
    '--      of this library file for the sensor you want to remove.          --
    and this needs editing
    '*** EDIT THIS SELECT CASE BLOCK TO ADD/REMOVE SENSORS (see instructions) ***
            case 1           'Sensor #1
                gosub Read_AM1
            case 2           'Sensor #2
                gosub Read_AM2
            case 3           'Sensor #2
                gosub Read_AM3
            case 4           'Sensor #2
                gosub Read_AM4
        end select
    Looking at the code for the version of thermostat that I used as a test platform when Tabsoft was developing the library the main program has this line in the set up area of the code (using include "AM2302_LIB_v024.bas" )
    ;----[AM2302 ]------------------------------------------------------------------
    AM2302_MAX_SENSORS con 4                        ' Number of Sensors Used
    I then used a word array for the temp and humidity values
    AM2302_H          var word[4]                   ' AM2302 sensors - Humidity values
      AM2302H1        var AM2302_H[0]
      AM2302H2        var AM2302_H[1]
      AM2302H3        var AM2302_H[2]
      AM2302H4        var AM2302_H[3]
    AM2302_T          Var Word[4]                   ' AM2302 sensors - temperatures
      AM2303T1        Var AM2302_T[0]
      AM2303T2        Var AM2302_T[1]
      AM2303T3        Var AM2302_T[2]
      AM2303T4        Var AM2302_T[3]
    I guess if using just the one sensor this could be a straight word variable
    I then have a link to a subroutine
    for cn=1 to 4
    Pid_channel=cn-1
    AM2302_Sensor_Num = cn
    gosub read_dht
    And the subroutine it links to is
    read_dht:
        gosub AM2302_Read
        AM2302_H[Pid_channel]= AM2302_Hum
        AM2302_T[Pid_channel]= AM2302_Temp
        if AM2302_Temp/10=0  then return
        serout2 portB.0, 84, [$1B,"[H"]
        serout2 portB.0, 84,[$1b, "[", dec cn+1, "B"]
        serout2 portB.0, 84, [$1B,"[11C"]
        serout2 portB.0, 84, [dec AM2302_Temp/10,".",dec AM2302_Temp//10]
        serout2 portB.0, 84, [$1B,"[17C"]
        serout2 portB.0, 84, [dec AM2302_Hum/10,"%"]
    Ignore all the serial out commands, I was using a serial to GLCD adapter at the time. The gosub called in the above subroutine is in the library file.
    Hopefully that dissection of my old program helps ? I sold my old EasyPic5 board at the beginning of September this year, and uninstalled PBP years ago, so have no means to test, but the code ran for a few years in the controller before I move to the dark side and ported the code to an Arduino Mega to take advantage of colour TFT screens.
    OK
    Scampy, thanks for the visit.Can I get you a cup of coffee? Pertaining to TFTs, I started working with the Nextion touch screens. There is an article series still running in Nuts and Volts Magazine controlling the Nextion with PBP3 that might interest you. Myself, I also moved to bigger challenges with MPLABX & XC8/XC16.
    Thanks!
    Will this library measure negative temperature?
    I'm integrating that AM2302 into my VFD clock, as outdoors sensor...
  1. Replies: 6
    Last Post: - 14th October 2013, 13:27
  2. DHT 11 Humidity & Temperature Sensor
    By jefrem in forum mel PIC BASIC
    Last Post: - 30th July 2013, 20:15
  3. Dht 11 & dht 22
    By DavidK in forum Off Topic
    Last Post: - 15th May 2012, 15:57
  4. SD card library?
    By Alexey in forum mel PIC BASIC Pro
    Last Post: - 7th February 2012, 12:28
  5. Library tools? Library Specs?
    By PickyBiker in forum mel PIC BASIC Pro
    Last Post: - 21st May 2010, 03:54
Members who have read this thread : 4
