DT-INTS and SSP1_INT
Results 1 to 4 of 4
    New Jersey
    Default DT-INTS and SSP1_INT
    I'm able to use the following interrupts from DT-INTS:
    1. RX1_INT
    2. RX2_INT
    3. TX1_INT
    4. TX2_INT
    5. TMR1_INT
    6. TMR0_INT
    When I try to use SSP1_INT, the program hangs waiting for the code to execute in the MSSP1 interrupt. I can remove the interrupt and use a GOSUB to execute the MSSP1 module but can't figure out why using the interrupt isn't working. I can confirm that the code goes past the
    @ INT_ENABLE SSP1_INT
    but it never goes into the SSP1 interrupt. Any thoughts?
    Default Re: DT-INTS and SSP1_INT
    Registers not defined right?
    SSP is on my ToDo list, never tried that.
    New Jersey
    I assume the registers are set correctly since the MSSP modules work correctly with GOSUB's. I can't figure this problem out. It's a stumper.
    Some pins are shared with other features. Seeing code would help.
  1. DT-ints-18, How to ...
    Last Post: - 7th January 2014, 21:41
  2. DT INTs which int to use??
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 13th March 2012, 01:23
  3. out of memory using DT-ints-14 and 16F610
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 7th January 2011, 04:30
  4. Problem with Dt Ints Interrupts
    By Quin in forum mel PIC BASIC Pro
    Last Post: - 18th July 2008, 20:21
  5. DT-ints-18 - new version
    By dip1 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2007, 21:09
