Hserin / out Woes..
Results 1 to 12 of 12
    May 2012
    Merseyside, UK
    Default Re: Hserin / out Woes..
    MY Defines are now :-
    DEFINE HSER_RCSTA 90H 'Set receive status and control
    DEFINE HSER_TXSTA 24H 'Set transmit status and control
    DEFINE HSER_BAUD 9615 'Baud Rate
    DEFINE HSER_CLROERR 1 ' Clear Buffer
    Jan 2013
    Texas USA
    Andy,
    You can always just use a "HSERIN" bogus statement to throw away anything in the buffer before you execute your regular "HSERIN" statements.
    Since the EUSART has a 2 byte buffer you may need to do two of the bogus "HSERIN" statements with timeouts just to make sure you don't get stuck waiting.
    TABSoft
    May 2012
    Merseyside, UK
    Hi
    Thanks for reply ...
    Will try tomorrow and post what happens ...
    Thank you for advice
    Andy
    Just keep in mind that if there is no garbage data in the RX buffer then the bogus statement will throw away the real data when it comes so if you go down that route make sure you specify a very low timeout value for the initial bogus statement.
    Here's another way to flush the buffer:
    RCIF VAR PIR1.3    ' Alias to the RX Interrupt flag for USART 1 on an 18F25k22
    Dummy VAR BYTE
    WHILE RCIF
       Dummy = RCREG1
    WEND
    May 2012
    Merseyside, UK
    Quote Originally Posted by Tabsoft View Post
    Andy,
    Hi
    I just put your suggestion in place and it seems to be working for me .... I just used 50 as a time out figure... thank you!
    I will try the other suggestions also thank you as always Henrik
    For now I need sleep !!!!!
    Br
    Andy
  1. SPI woes
    Last Post: - 27th September 2013, 14:04
  2. Capture woes...
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2011, 08:36
  3. LCDOut Woes
    By LetTheSmokeOut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 01:45
  4. ICD Woes
    By spad13m in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 05:56
  5. Still HSEROUT woes
    Last Post: - 11th July 2006, 21:13
