Hserin / out Woes..
Results 1 to 12 of 12
    May 2012
    Merseyside, UK
    Default Hserin / out Woes..
    Hi All..
    Am using this code as a simple password check on a serial link :-
    hserout [":- "]
                hserin 65535,bed, [pass (0)]: hserout [pass (0)]
                hserin 65535,bed, [pass (1)]: hserout [pass (1)]
                hserin 65535,bed, [pass (2)]: hserout [pass (2)]
                hserin 65535,bed, [pass (3)]: hserout [pass (3)]
                hserin 65535,bed, [pass (4)]: hserout [pass (4)]
                hserin 65535,bed, [pass (5)]: hserout [pass (5)]
                hserin 65535,bed, [pass (6)]: hserout [pass (6)]
                hserin 65535,bed, [pass (7)]: hserout [pass (7)]
                hserin 65535,bed, [pass (8)]: hserout [pass (8),10,13]
                IF ("2" = pass(0))and ("9" = pass(1))and ("9" = pass(2))and ("7" = pass(3))and ("9" = pass(4))and ("2" = pass(5))and ("4" = pass(6))and ("5" = pass(7))and ("8" = pass(8)) THEN correct
    There are nine decimal digits which have to be correct.... but some times it fails on the last digit, but not always ?? If I cut the pass word to 4 digits it fails also on the last digit ????
    My question is... is there a more elegant way of doing the above? I still want to see each char as typed...wich rules out a string of words.
    But more I need it to be reliable..I am using a 4 Meg Xtal my defines are :-
        DEFINE OSC 4	'Set oscillator in MHz
        'OSCCON = $60     '4 Megs
        DEFINE HSER_RCSTA 90H   'Set receive status and control
        DEFINE HSER_TXSTA 24H   'Set transmit status and control
        DEFINE HSER_BAUD 9615   'Baud Rate
        ADCON1 = 7 ' Turns Analogs off
        CMCON0 = 7 'Disable both comparators
        ANSEL = 0  ' Set all analog pins to digital
    thank you for looking....
    Default Re: Hserin / out Woes..
    I'm not sure if the DEFINE HSER_BAUD accepts non standard baudrates, I suspect it does since it kind of works. What's with the 9615 anyway?
    I don't know what would make it fail on the last character - sometimes. Are you typing in, and sending, the characters one by one, ie there's 100ms or whatever between each character?
    Anyway, here's an alternative aproach I just wrote. I have not tested it, not even compiled it so take it for what it is.
    Key VAR BYTE
    CorrectKey VAR BYTE[9]
    KeyIndex VAR BYTE
    PassFail VAR BIT
    Pass CON 1
    Fail CON 0
    CorrectKey[0] = "2"
    CorrectKey[1] = "9"
    CorrectKey[2] = "9"
    CorrectKey[3] = "7"
    CorrectKey[4] = "9"
    CorrectKey[5] = "2"
    CorrectKey[6] = "4"
    CorrectKey[7] = "5"
    CorrectKey[8] = "8"
    hserout [":- "]
    PassFail = Pass
    For KeyIndex = 0 to 8
    	HSERIN 65535, bed, Key
    	HSEROUT Key
    	IF Key <> CorrectKey[KeyIndex] THEN
    		PassFail = Fail
    NEXT
    IF PassFail = Pass THEN
    	HSEROUT[10, 13, "Correct key entered",10, 13]
    	HSEROUT[10, 13, "Wrong key entered", 10, 13]
    Jan 2013
    Texas USA
    Here is another approach that allows you to wait for all of the characters to be entered before testing the password.
    It also makes use of arraywrite to enter the Master Password.
    MasterPass var byte[9]
    pass var byte[9]
    PassTest var bit
    i var byte
    '    ADCON1 = 7 ' Turns Analogs off
    '    CMCON0 = 7 'Disable both comparators
    '    ANSEL = 0  ' Set all analog pins to digital
        arraywrite MasterPass,["299792458"]
        'Test for 299792458
        PassTest = 1
        for i = 0 to 8
            pass[i] = 0
        next i
        hserout [":- "]
        for i = 0 to 8
            hserin 65535, bed, [pass(i)]
            hserout [pass(i)]
        next i
        'Check Password with Master
        for i = 0 to 8
            if pass(i) <> MasterPass(i) then PassTest = 0
        next i
        if PassTest = 1 then correct
        hserout [13,10,"NO WAY!!",13,10]
    correct:
        hserout [13,10,"Correct!",13,10]
    bed:
        hserout ["Timeout",13,10]
     bye:
    TABSoft
    May 2012
    Merseyside, UK
    Thanks for the replies.....
    Will try then out later.... have been working away!
    BR
    Andy
    May 2012
    Merseyside, UK
    hi All...
    Have played with my code a little more....
    Have come to conclusion that the serial port is seeing 0xFf before I type any password... I found by putting a 232 sniffer on the ports !!!
    Ie the password is 9 chars but the first on occasionally is 0xFF ????
    any Ideas ? anyone ?
    Tomorrow O will go back to Serin / Serout see how that gets on !
    Thank you for help !
    For reliable communications, I always clear the receive buffer before transmitting a request to any perif. That way if you have some noise on the comm lines, it won't be interpreted as bad data.
    EN82fn
  1. SPI woes
    Last Post: - 27th September 2013, 14:04
  2. Capture woes...
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2011, 08:36
  3. LCDOut Woes
    By LetTheSmokeOut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 01:45
  4. ICD Woes
    By spad13m in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 05:56
  5. Still HSEROUT woes
    Last Post: - 11th July 2006, 21:13
