Siemens SDA5708
Results 1 to 8 of 8
Thread: Siemens SDA5708
    Apr 2015
    Default Siemens SDA5708
    Hi everybody,
    After almost 10 years of inactivity I'm back and with pleasure I see that the forum is still alive.
    I do not even remember my old nick, I will search if some my old posts are still there.
    Let's get to the point. I have here in front of me a Siemens SDA5708-24 display 8 character 7x5 dot matrix LED display.
    Some of you has any experience with this display ?
    Cheers
    Roberto
    Default Re: Siemens SDA5708
    Not me, I don't know if you have this but I did find this page on google:
    http://sbprojects.com/knowledge/footprints/sda5708.php
    ;  Demo program to interface with the SDA5708-24 alpha numeric display
    ;  Designed to run on the 6802 Nano computer
    ;  Author: San Bergmans
    ;  www.sbprojects.com
                    .CR     6800
                    .OR     $F000
                    .TF     SDA5708.S19,S19,32
    ;  Declarations
    PIA_A           .EQ     $80             PIA Port A data register
    PIA_B           .EQ     $81             PIA Port B data register
    CON_A           .EQ     $82             PIA Port A control register
    CON_B           .EQ     $83             PIA Port B control register
    ; PIA_A.0 = Display's -Reset line       Output
    ; PIA_A.1 = Display's -Load line        Output
    ; PIA_A.2 = Display's Clock line        Output
    ; PIA_A.3 = Display's Data line         Output
    TEMP            .EQ     $00,$01         Used as temporary data register
    SHIFT_DATA      .EQ     $00             Data to be shifted out
    BIT_COUNT       .EQ     $01             Data bit counter
    SAVE_X          .EQ     $02,$03         Location to save the X register
    CURSOR          .EQ     $04             Character pointer (0..7)
    SDA_BRIGHT      .EQ     %1110.0000      Control word value for brightness
    ;  ROUTINE   :  RESET
    ;  FUNCTION  :  Get started
    RESET           LDS     #$007F          Initialize the stack
                    LDAA    #%0000.0100     PIA_A bits 0..3 are going to be
                    STAA    CON_A            outputs. But before we switch mode
                    LDAB    #%0000.1111      we must ensure that the data
                    STAB    PIA_A            register holds 1's to avoid spikes
                    CLRA                    Now it's save to switch from inputs
                    STAA    CON_A
                    STAB    PIA_A
                    LDAA    #%0000.0100     Finally select data register again
                    STAA    CON_A
                    LDAA    #%1111.1110     Send a -Reset signal to the display
                    STAA    PIA_A
                    LDAA    #%1111.1111
                    STAA    PIA_A
                    LDAA    #SDA_BRIGHT     Set preselected display brightness
                    JSR     WRITE_DSP
                    CLRA                    Reset cursor to 0
                    STAA    CURSOR
    ;  ROUTINE   :  MAIN
    ;  FUNCTION  :  Main program loop
    MAIN            LDX     #TEXT           Load text pointer in index register
                    LDAA    0,X             Print 1st character
                    JSR     ASCII_2_DSP
                    LDAA    1,X             Print 2nd character
                    JSR     ASCII_2_DSP
                    LDAA    2,X             Print 3rd character
                    JSR     ASCII_2_DSP
                    LDAA    3,X             Print 4th character
                    JSR     ASCII_2_DSP
                    LDAA    4,X             Print 5th character
                    JSR     ASCII_2_DSP
                    LDAA    5,X             Print 6th character
                    JSR     ASCII_2_DSP
                    LDAA    6,X             Print 7th character
                    JSR     ASCII_2_DSP
                    LDAA    7,X             Print last character
                    JSR     ASCII_2_DSP
    .4EVER          JMP     .4EVER
    TEXT            .AS     "SDA-5708"      This text is displayed!
    ;  ROUTINE   :  WRITE_DSP
    ;  FUNCTION  :  Write 8 bit data in A to display controler
    WRITE_DSP       PSHA                    Save affected registers
                    PSHB
                    STAA    SHIFT_DATA
                    LDAB    #8              Setup bit counter
                    STAB    BIT_COUNT
                    LDAB    PIA_A           Get a copy of current PIA lines
                    ANDB    #%1111.1011     Make Clock line low
                    STAB    PIA_A
                    ANDB    #%1111.1101     Make LOAD line low
                    STAB    PIA_A
    .LOOP           ORAB    #%0000.1000     In case data must be high
                    LSRA    SHIFT_DATA      Get databit
                    BCS     .BIT_HIGH       Data must be high!
                    ANDB    #%1111.0111     Make data bit low
    .BIT_HIGH       STAB    PIA_A
                    ORAB    #%0000.0100     Pulse clock line high/low
                    STAB    PIA_A
                    ANDB    #%1111.1011
                    STAB    PIA_A
                    DEC     BIT_COUNT       Do all bits
                    BNE     .LOOP
                    ORAB    #%0000.0010     Make LOAD line high again which
                    STAB    PIA_A            copies shift register to display
                    ORAB    #%0000.1100     Finally make clock+data high
                    STAB    PIA_A
                    PULB                    Restore affected registers
                    PULA
                    RTS
    ;  ROUTINE   :  ASCII_2_DSP
    ;  FUNCTION  :  Send ASCII to current digit
    ;               A = ASCII character
    ;               CURSOR = Digit to print to
    ;               CURSOR is incremented afterwards (wraps to 0 after 7)
    ASCII_2_DSP     PSHA                    Save affected registers
                    PSHB
                    STX     SAVE_X
                    TAB                     Save ASCII character in B
                    LDAA    CURSOR          Setup display pointer
                    ORAA    #%1010.0000     Make it a digit selector
                    JSR     WRITE_DSP       Send digit address to display
                    SUBB    #' '            Table starts at space, skipping the
                    CLRA                     control characters
                    STAB    TEMP+1          Save Character-" "
                    ASLB                    Each table entery is 7 bytes long
                    ROLA                     so we must multiply the character
                    ASLB                     by 7 before we can use it as index
                    ROLA
                    ASLB
                    ROLA
                    SUBB    TEMP+1          We multiplied by 8 instead of 7, so
                    SBCA    #0               we'll have to subtract once
                    ADDB    #ASCII_TABLE    Add ASCII table offset to the index
                    ADCA    /ASCII_TABLE
                    STAA    TEMP            Then use it as an index
                    STAB    TEMP+1
                    LDX     TEMP
                    LDAB    #7              Count the number of display rows
    .LOOP           LDAA    0,X             Get bit pattern
                    JSR     WRITE_DSP        and write it to the display
                    INX                     Increment table index
                    DECB                    Decrement row pointer
                    BNE     .LOOP           Continue until all rows are done
                    LDAA    CURSOR          Increment the display's cursor
                    INCA                     but limit range from 0 to 7
                    ANDA    #%0000.0111
                    STAA    CURSOR
                    LDX     SAVE_X          Restore the affected registers
                    PULB                     again
                    PULA
                    RTS
    ;  ASCII TABLE
    ASCII_TABLE     .DA     #%00000         Space   $20
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00100         !       $21
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00000
                    .DA     #%00100
                    .DA     #%01010         "       $22
                    .DA     #%01010
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%01010         #       $23
                    .DA     #%01010
                    .DA     #%11111
                    .DA     #%01010
                    .DA     #%11111
                    .DA     #%01010
                    .DA     #%01010
                    .DA     #%00100         $       $24
                    .DA     #%01111
                    .DA     #%10100
                    .DA     #%01110
                    .DA     #%00101
                    .DA     #%11110
                    .DA     #%00100
                    .DA     #%11000         %       $25
                    .DA     #%11001
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%10011
                    .DA     #%00011
                    .DA     #%00000         &       $26
                    .DA     #%01000
                    .DA     #%10100
                    .DA     #%01000
                    .DA     #%10101
                    .DA     #%10010
                    .DA     #%01101
                    .DA     #%00100         '       $27
                    .DA     #%00100
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00010         (       $28
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%01000
                    .DA     #%01000
                    .DA     #%00100
                    .DA     #%00010
                    .DA     #%01000         )       $29
                    .DA     #%00100
                    .DA     #%00010
                    .DA     #%00010
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%00000         *       $2A
                    .DA     #%10101
                    .DA     #%01110
                    .DA     #%00100
                    .DA     #%01110
                    .DA     #%10101
                    .DA     #%00000
                    .DA     #%00000         +       $2B
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%11111
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00000
                    .DA     #%00000         ,       $2C
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%01100
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%00000         -       $2D
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%11111
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000         .       $2E
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%01100
                    .DA     #%01100
                    .DA     #%00000         /       $2F
                    .DA     #%00001
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%10000
                    .DA     #%00000
                    .DA     #%00100         0       $30
                    .DA     #%01010
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01010
                    .DA     #%00100
                    .DA     #%00100         1       $31
                    .DA     #%01100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%01110
                    .DA     #%01110         2       $32
                    .DA     #%10001
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%10000
                    .DA     #%11111
                    .DA     #%11111         3       $33
                    .DA     #%00001
                    .DA     #%00010
                    .DA     #%00110
                    .DA     #%00001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%00010         4       $34
                    .DA     #%00110
                    .DA     #%01010
                    .DA     #%10010
                    .DA     #%11111
                    .DA     #%00010
                    .DA     #%00010
                    .DA     #%11111         5       $35
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%11110
                    .DA     #%00001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%01111         6       $36
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%11110
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%11111         7       $37
                    .DA     #%00001
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%01110         8       $38
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%01110         9       $39
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01111
                    .DA     #%00001
                    .DA     #%00001
                    .DA     #%11110
                    .DA     #%00000         :       $3A
                    .DA     #%01100
                    .DA     #%01100
                    .DA     #%00000
                    .DA     #%01100
                    .DA     #%01100
                    .DA     #%00000
                    .DA     #%00000         ;       $3B
                    .DA     #%01100
                    .DA     #%01100
                    .DA     #%00000
                    .DA     #%01100
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%00010         <       $3C
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%10000
                    .DA     #%01000
                    .DA     #%00100
                    .DA     #%00010
                    .DA     #%00000         =       $3D
                    .DA     #%00000
                    .DA     #%11111
                    .DA     #%00000
                    .DA     #%11111
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%01000         >       $3E
                    .DA     #%00100
                    .DA     #%00010
                    .DA     #%00001
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%01110         ?       $3F
                    .DA     #%10001
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00000
                    .DA     #%00100
                    .DA     #%01110         @       $40
                    .DA     #%10001
                    .DA     #%10101
                    .DA     #%10111
                    .DA     #%10000
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%00100         A       $41
                    .DA     #%01010
                    .DA     #%10001
                    .DA     #%11111
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%11110         B       $42
                    .DA     #%01001
                    .DA     #%01001
                    .DA     #%01110
                    .DA     #%01001
                    .DA     #%01001
                    .DA     #%11110
                    .DA     #%01110         C       $43
                    .DA     #%10001
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%11110         D       $44
                    .DA     #%01001
                    .DA     #%01001
                    .DA     #%01001
                    .DA     #%01001
                    .DA     #%01001
                    .DA     #%11110
                    .DA     #%11111         E       $45
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%11100
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%11111
                    .DA     #%11111         F       $46
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%11100
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%01111         G       $47
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10111
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%10001         H       $48
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%11111
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01110         I       $49
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%01110
                    .DA     #%01110         J       $4A
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%10100
                    .DA     #%01000
                    .DA     #%10001         K       $4B
                    .DA     #%10010
                    .DA     #%10100
                    .DA     #%11000
                    .DA     #%10100
                    .DA     #%10010
                    .DA     #%10001
                    .DA     #%10000         L       $4C
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%11111
                    .DA     #%10001         M       $4D
                    .DA     #%11011
                    .DA     #%10101
                    .DA     #%10101
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001         N       $4E
                    .DA     #%10001
                    .DA     #%11001
                    .DA     #%10101
                    .DA     #%10011
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01110         O       $4F
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%11110         P       $50
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%11110
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%01110         Q       $51
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10101
                    .DA     #%10010
                    .DA     #%01101
                    .DA     #%11110         R       $52
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%11110
                    .DA     #%10100
                    .DA     #%10010
                    .DA     #%10001
                    .DA     #%01110         S       $53
                    .DA     #%10001
                    .DA     #%10000
                    .DA     #%01110
                    .DA     #%00001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%11111         T       $54
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%10001         U       $55
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%10001         V       $56
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01010
                    .DA     #%01010
                    .DA     #%00100
                    .DA     #%10001         W       $57
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10101
                    .DA     #%10101
                    .DA     #%01010
                    .DA     #%10001         X       $58
                    .DA     #%10001
                    .DA     #%01010
                    .DA     #%00100
                    .DA     #%01010
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001         Y       $59
                    .DA     #%10001
                    .DA     #%01010
                    .DA     #%01010
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%11111         Z       $5A
                    .DA     #%00001
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%10000
                    .DA     #%11111
                    .DA     #%01111         [       $5B
                    .DA     #%01000
                    .DA     #%01000
                    .DA     #%01000
                    .DA     #%01000
                    .DA     #%01000
                    .DA     #%01111
                    .DA     #%00000         \       $5C
                    .DA     #%10000
                    .DA     #%01000
                    .DA     #%00100
                    .DA     #%00010
                    .DA     #%00001
                    .DA     #%00000
                    .DA     #%11110         ]       $5D
                    .DA     #%00010
                    .DA     #%00010
                    .DA     #%00010
                    .DA     #%00010
                    .DA     #%00010
                    .DA     #%11110
                    .DA     #%00100         ^       $5E
                    .DA     #%01010
                    .DA     #%10001
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000         _       $5F
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%11111
                    .DA     #%00100         '       $60
                    .DA     #%01000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000         a       $61
                    .DA     #%01110
                    .DA     #%00001
                    .DA     #%01101
                    .DA     #%10011
                    .DA     #%10001
                    .DA     #%01111
                    .DA     #%10000         b       $62
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10110
                    .DA     #%11001
                    .DA     #%10001
                    .DA     #%11110
                    .DA     #%00000         c       $63
                    .DA     #%00000
                    .DA     #%01111
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%01111
                    .DA     #%00001         d       $64
                    .DA     #%00001
                    .DA     #%00001
                    .DA     #%01101
                    .DA     #%10011
                    .DA     #%10001
                    .DA     #%01111
                    .DA     #%00000         e       $65
                    .DA     #%00000
                    .DA     #%01110
                    .DA     #%10001
                    .DA     #%11110
                    .DA     #%10000
                    .DA     #%01110
                    .DA     #%00110         f       $66
                    .DA     #%01001
                    .DA     #%01000
                    .DA     #%11100
                    .DA     #%01000
                    .DA     #%01000
                    .DA     #%01000
                    .DA     #%00000         g       $67
                    .DA     #%01111
                    .DA     #%10001
                    .DA     #%10011
                    .DA     #%01101
                    .DA     #%00001
                    .DA     #%01110
                    .DA     #%10000         h       $68
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10110
                    .DA     #%11001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%00000         i       $69
                    .DA     #%00100
                    .DA     #%00000
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00000         j       $6A
                    .DA     #%00010
                    .DA     #%00000
                    .DA     #%00010
                    .DA     #%00010
                    .DA     #%10010
                    .DA     #%01100
                    .DA     #%10000         k       $6B
                    .DA     #%10000
                    .DA     #%10001
                    .DA     #%10010
                    .DA     #%11100
                    .DA     #%10010
                    .DA     #%10001
                    .DA     #%01100         l       $6C
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%01110
                    .DA     #%00000         m       $6D
                    .DA     #%00000
                    .DA     #%11010
                    .DA     #%10101
                    .DA     #%10101
                    .DA     #%10101
                    .DA     #%10101
                    .DA     #%00000         n       $6E
                    .DA     #%00000
                    .DA     #%10110
                    .DA     #%11001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%00000         o       $6F
                    .DA     #%00000
                    .DA     #%01110
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01110
                    .DA     #%00000         p       $70
                    .DA     #%11110
                    .DA     #%10001
                    .DA     #%11001
                    .DA     #%10110
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%00000         q       $71
                    .DA     #%01111
                    .DA     #%10001
                    .DA     #%10011
                    .DA     #%01101
                    .DA     #%00001
                    .DA     #%00001
                    .DA     #%00000         r       $72
                    .DA     #%00000
                    .DA     #%10110
                    .DA     #%11001
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%10000
                    .DA     #%00000         s       $73
                    .DA     #%00000
                    .DA     #%01111
                    .DA     #%10000
                    .DA     #%01110
                    .DA     #%00001
                    .DA     #%11110
                    .DA     #%00100         t       $74
                    .DA     #%00100
                    .DA     #%01110
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00101
                    .DA     #%00010
                    .DA     #%00000         u       $75
                    .DA     #%00000
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10011
                    .DA     #%01101
                    .DA     #%00000         v       $76
                    .DA     #%00000
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01010
                    .DA     #%00100
                    .DA     #%00000         w       $77
                    .DA     #%00000
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%10101
                    .DA     #%10101
                    .DA     #%01010
                    .DA     #%00000         x       $78
                    .DA     #%00000
                    .DA     #%10001
                    .DA     #%01010
                    .DA     #%00100
                    .DA     #%01010
                    .DA     #%10001
                    .DA     #%00000         y       $79
                    .DA     #%00000
                    .DA     #%10001
                    .DA     #%10001
                    .DA     #%01111
                    .DA     #%00010
                    .DA     #%01100
                    .DA     #%00000         z       $7A
                    .DA     #%00000
                    .DA     #%11111
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%11111
                    .DA     #%00011         {       $7B
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%01000
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00011
                    .DA     #%00100         |       $7C
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00000
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%11000         }       $7D
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%00010
                    .DA     #%00100
                    .DA     #%00100
                    .DA     #%11000
                    .DA     #%01000         ~       $7E
                    .DA     #%10101
                    .DA     #%00010
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%00000
                    .DA     #%11111         sqaure  $7F
                    .DA     #%11111
                    .DA     #%11111
                    .DA     #%11111
                    .DA     #%11111
                    .DA     #%11111
                    .DA     #%11111
    ;  Vectors
                    .OR     $FFF8
                    .DA     RESET           IRQ     (Not used)
                    .DA     RESET           SWI     (Not used)
                    .DA     RESET           NMI     (Not used)
                    .DA     RESET           Reset
                    .LI     OFF
    I know it's in Assembler, but at least it has comments and shows how to use the device.
    Apr 2015
    Demon, thank you for yr reply.
    Yes I saw it but unfortunately I don't know assembler.
    Any help will be appreciated.
    Bye
    Roberto
    Jan 2013
    Texas USA
    Not able to test this since I don't have the SDA5708, but this might get you started.
    For a 16F887.
    SDA5708_Test.bas
    TABSoft
    Apr 2015
    @ Acetronics2
    Thank you for the link but unfortunately it needs to be member to see or download the code
    @ Tabsoft
    Thank you for the code. I'll try it. Do you think I could use an 877 ? I believe I do not need the extra features of the 887.
    I'll check for the hardware.
    Bye
    Roberto
    Jan 2013
    Texas USA
    I don't see any reason you couldn't use an 877.
    You'll just have to adjust for the specific 877 hardware.
    The test program only takes 1070 words of flash, so no problem there.
    TABSoft
    Jan 2013
    Texas USA
    You just have to be mindful of the size of the datatable.
    As is, it takes 672 code words of space to store just the table.
    There are ways to compress the table, but maybe for another discussion.
    TABSoft
  1. Siemens TC35
    By savnik in forum GSM
    Last Post: - 4th December 2010, 22:27
  2. Siemens LCD
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 25th September 2009, 21:58
  3. Siemens GSM/GPRS Modules
    By dhanush in forum General
    Last Post: - 1st August 2009, 16:46
  4. Siemens c55 sms control help please
    By camolas in forum mel PIC BASIC Pro
    Last Post: - 20th August 2008, 01:13
  5. AT Command for SIEMENS AX72 - Help !
    By charudatt in forum GSM
    Last Post: - 23rd July 2006, 07:42
