I hate outsmarting myself. I intentionally replaced that RETURN, argh...
I had also replaced the YES flag. I should have stepped away and taken a break, to take a different look at my code a few minutes later. I somehow thought more was going on and had to handle the flag myself, I obviously didn't. The interrupt won't take off again unless I call Start.
Code:@ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H @ __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_1_2L & _VREGEN_ON_2L @ __CONFIG _CONFIG2H, _WDT_OFF_2H @ __CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H @ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L DEFINE OSC 48 ADCON1 = %00001111 ' A/D CONTROL REGISTER 1 ' Bit 7-6 Unimplemented: Read as ‘0’ ' Bit 5 VCFG1: Voltage Reference Configuration bit (VREF- source) ' 0 = VSS ' 1 = Vref- (AN2) ' Bit 4 VCFG0: Voltage Reference Configuration bit (VREF+ source) ' 0 = VSS ' 1 = Vref+ (AN3) ' Bit 3-0 PCFG3:PCFG0: A/D Port Configuration Control bits: ' 1111 = All digital ' 1110 = All digital, AN0 analog ' 1101 = All digital, AN0 & AN1 analog INTCON2 = %00000000 ' INTERRUPT CONTROL REGISTER 2 ' Bit 7 RBPU: PORTB Pull-up Enable bit ' 1 = All PORTB pull-ups are disabled ' 0 = PORTB pull-ups are enabled provided that the pin is an input ' and the corresponding WPUB bit is set. ' Bit 6 INTEDG0: External Interrupt 0 Edge Select bit ' 1 = Interrupt on rising edge ' 0 = Interrupt on falling edge ' Bit 5 INTEDG1: External Interrupt 1 Edge Select bit ' 1 = Interrupt on rising edge ' 0 = Interrupt on falling edge ' Bit 4 INTEDG2: External Interrupt 2 Edge Select bit ' 1 = Interrupt on rising edge ' 0 = Interrupt on falling edge ' Bit 3 Unimplemented: Read as ‘0’ ' Bit 2 TMR0IP: TMR0 Overflow Interrupt Priority bit ' 1 = High priority ' 0 = Low priority ' Bit 1 Unimplemented: Read as ‘0’ ' Bit 0 RBIP: RB Port Change Interrupt Priority bit ' 1 = High priority ' 0 = Low priority T0CON = %10000011 ' TIMER0 CONTROL REGISTER ' Bit 7 TMR0ON: Timer0 On/Off Control bit ' 1 = Enables Timer0 ' 0 = Stops Timer0 ' Bit 6 T08BIT: Timer0 8-Bit/16-Bit Control bit ' 1 = Timer0 is configured as an 8-bit timer/counter ' 0 = Timer0 is configured as a 16-bit timer/counter ' Bit 5 T0CS: Timer0 Clock Source Select bit ' 1 = Transition on T0CKI pin ' 0 = Internal instruction cycle clock (CLKO) ' Bit 4 T0SE: Timer0 Source Edge Select bit ' 1 = Increment on high-to-low transition on T0CKI pin ' 0 = Increment on low-to-high transition on T0CKI pin ' Bit 3 PSA: Timer0 Prescaler Assignment bit ' 1 = Timer0 prescaler is NOT assigned. Timer0 clock input ' bypasses prescaler. ' 0 = Timer0 prescaler is assigned. Timer0 clock input comes from ' prescaler output. ' Bit 2-0 T0PS2:T0PS0: Timer0 Prescaler Select bits ' 111 = 1:256 Prescale value ' 110 = 1:128 Prescale value ' 101 = 1:64 Prescale value ' 100 = 1:32 Prescale value ' 011 = 1:16 Prescale value ' 010 = 1:8 Prescale value ' 001 = 1:4 Prescale value ' 000 = 1:2 Prescale value INCLUDE "DT_INTS-18.bas" ' Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR0_INT, _EndTimer, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM TRISA = %00000000 TRISB = %11110000 ' Set columns to input, rows to output TRISC = %00000000 TRISD = %00000000 TRISE = %00000000 TimerLed VAR PORTD.1 LOW TimerLed GOTO Main StartTimer: TMR0H = 109 ' 50 mS Timer TMR0L = 144 HIGH TimerLed @ INT_ENABLE TMR0_INT ; enable Timer 0 interrupts RETURN EndTimer: LOW TimerLed @ INT_RETURN KeypadInput: PORTB = %00001110 ' Row 1 IF PORTB.4 = 0 THEN ' Column 1 GOSUB StartTimer WHILE PORTB.4 = 0: WEND ENDIF RETURN Main: GOSUB KeypadInput ' Scan 4 x 4 keypad ' Future logic goes here. GOTO Main END
Eeesh, thanks guys! It works perfectly now.
