Cannot reset Timer0 properly
Results 1 to 4 of 4
    Default Cannot reset Timer0 properly
    I can't figure out what other flag I need to reset to use Timer0 a 2nd time.
    Timer0 works for 50mS on the first keypress of the upper left button on the keypad. But it keeps on going on the second keypress.
    @   __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @   __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
    @   __CONFIG    _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_1_2L & _VREGEN_ON_2L
    @   __CONFIG    _CONFIG2H, _WDT_OFF_2H
    @   __CONFIG    _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    @   __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 48
    ADCON1 = %00001111                      ' A/D CONTROL REGISTER 1
    '   Bit 7-6 Unimplemented: Read as ‘0’
    '   Bit 5   VCFG1: Voltage Reference Configuration bit (VREF- source)
    '               0 = VSS
    '               1 = Vref- (AN2)
    '   Bit 4   VCFG0: Voltage Reference Configuration bit (VREF+ source)
    '               0 = VSS
    '               1 = Vref+ (AN3)
    '   Bit 3-0 PCFG3:PCFG0: A/D Port Configuration Control bits:
    '               1111 = All digital
    '               1110 = All digital, AN0 analog
    '               1101 = All digital, AN0 & AN1 analog
    INTCON2 = %00000000                     ' INTERRUPT CONTROL REGISTER 2
    '   Bit 7   RBPU: PORTB Pull-up Enable bit
    '               1 = All PORTB pull-ups are disabled
    '               0 = PORTB pull-ups are enabled provided that the pin is an input
    '                   and the corresponding WPUB bit is set.
    '   Bit 6   INTEDG0: External Interrupt 0 Edge Select bit
    '               1 = Interrupt on rising edge
    '               0 = Interrupt on falling edge
    '   Bit 5   INTEDG1: External Interrupt 1 Edge Select bit
    '   Bit 4   INTEDG2: External Interrupt 2 Edge Select bit
    '   Bit 3   Unimplemented: Read as ‘0’
    '   Bit 2   TMR0IP: TMR0 Overflow Interrupt Priority bit
    '               1 = High priority
    '               0 = Low priority
    '   Bit 1   Unimplemented: Read as ‘0’
    '   Bit 0   RBIP: RB Port Change Interrupt Priority bit
    '               1 = High priority
    '               0 = Low priority
    T0CON = %10000011                       ' TIMER0 CONTROL REGISTER
    '   Bit 7   TMR0ON: Timer0 On/Off Control bit
    '               1 = Enables Timer0
    '               0 = Stops Timer0
    '   Bit 6   T08BIT: Timer0 8-Bit/16-Bit Control bit
    '               1 = Timer0 is configured as an 8-bit timer/counter
    '               0 = Timer0 is configured as a 16-bit timer/counter
    '   Bit 5   T0CS: Timer0 Clock Source Select bit
    '               1 = Transition on T0CKI pin
    '               0 = Internal instruction cycle clock (CLKO)
    '   Bit 4   T0SE: Timer0 Source Edge Select bit
    '               1 = Increment on high-to-low transition on T0CKI pin
    '               0 = Increment on low-to-high transition on T0CKI pin
    '   Bit 3   PSA: Timer0 Prescaler Assignment bit
    '               1 = Timer0 prescaler is NOT assigned. Timer0 clock input
    '                   bypasses prescaler.
    '               0 = Timer0 prescaler is assigned. Timer0 clock input comes from
    '                   prescaler output.
    '   Bit 2-0 T0PS2:T0PS0: Timer0 Prescaler Select bits
    '               111 = 1:256 Prescale value
    '               110 = 1:128 Prescale value
    '               101 = 1:64 Prescale value
    '               100 = 1:32 Prescale value
    '               011 = 1:16 Prescale value
    '               010 = 1:8 Prescale value
    '               001 = 1:4 Prescale value
    '               000 = 1:2 Prescale value
    INCLUDE "DT_INTS-18.bas"            ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"         ' Include if using PBP interrupts
            INT_Handler   TMR0_INT,  _EndTimer,    PBP,  no
        INT_CREATE                      ; Creates the interrupt processor
        TRISA = %00000000
        TRISB = %11110000               '  Set columns to input, rows to output
        TRISC = %00000000
        TRISD = %00000000
        TRISE = %00000000
    TimerLed    VAR PORTD.1
        LOW TimerLed
        GOTO Main
    StartTimer:
        TMR0H = 109                     ' 50 mS Timer
        TMR0L = 144
        INTCON.2 = 0
        HIGH TimerLed
    @ INT_ENABLE  TMR0_INT              ; enable Timer 0 interrupts
    EndTimer:
        LOW TimerLed
    KeypadInput:
        PORTB = %00001110               ' Row 1
        IF PORTB.4 = 0 THEN             ' Column 1
            GOSUB StartTimer
            WHILE PORTB.4 = 0: WEND
        GOSUB KeypadInput               ' Scan 4 x 4 keypad
    '       Future logic goes here.
        GOTO Main
    (my first attempt at resetting the interrupt flag myself)
    PIC 18F4550
    Lab X1 board
    PBP v2.60c
    MPASM v5.46
    Default Re: Cannot reset Timer0 properly
    Hi Robert,
    I see two problems.
    1) The interrupt service routine ends with a RETURN, it really needs to end with an @ INT_RETURN
    2) In the interrupt "declaration" you have the Clear Flag option set to no so DT-INTS will not clear the flag. Are you saying that you want to do it yourself? In that case you need to do it in the interrupt service routine.
    Jan 2013
    Texas USA
    Right on Henrik.
    I came up with the same items. Had just converted the code to work on my HW and was testing.
    These suggested changes seem to work here on my setup Robert.
    TABSoft
    I hate outsmarting myself. I intentionally replaced that RETURN, argh...
    I had also replaced the YES flag. I should have stepped away and taken a break, to take a different look at my code a few minutes later. I somehow thought more was going on and had to handle the flag myself, I obviously didn't. The interrupt won't take off again unless I call Start.
    DEFINE OSC 48
    '               0 = VSS
    '               1 = Vref- (AN2)
    '               0 = VSS
    '               1 = Vref+ (AN3)
    '               1 = High priority
    '               0 = Low priority
    '               1 = High priority
    '               0 = Low priority
    '               0 = Stops Timer0
    '                   prescaler output.
            INT_Handler   TMR0_INT,  _EndTimer,    PBP,  yes
        TRISA = %00000000
        TRISC = %00000000
        TRISD = %00000000
        TRISE = %00000000
        LOW TimerLed
        GOTO Main
    StartTimer:
        TMR0L = 144
        HIGH TimerLed
    EndTimer:
        LOW TimerLed
    @ INT_RETURN
    KeypadInput:
            GOSUB StartTimer
        GOTO Main
    Eeesh, thanks guys! It works perfectly now.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  2. Why first time string doesn't come properly?
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2009, 09:30
  3. Pic does not work properly
    By Armando Herjim in forum General
    Last Post: - 29th June 2006, 04:08
  4. I think my interrupt is not saving context properly?
    By royly in forum mel PIC BASIC Pro
    Last Post: - 6th December 2004, 17:21
