lcd1602blc by Velleman
Results 1 to 2 of 2
    Feb 2005
    GREECE
    Question lcd1602blc by Velleman
    hello my friends,
    Does no one know something about the LCD1602BLC product by Velleman.
    Some specifications:
    backlight: LED
    LCD type + colour: STN grey
    features:
    5 x 8 dots with cursor
    built-in controller (KS0066U or equivalent)
    +5V power supply
    1/16 duty cycle
    BKL to be driven by pin1, pin2, or pin15, pin16 or A, K
    absolute maximum rating:
    power supply (Vdd-Vss): -0.3 ~ 5.5V
    input voltage (Vi): -0.3 ~ Vdd
    electronic:
    input voltage (Vdd): 4.7 ~ 5.5V (at +5V) / 2.7 ~ 5.3V (at +3.3V)
    supply current (Idd): 1.5mA typ. (at Vdd = 5V)
    recommended LCD driving voltage (Vdd-V0): 4.3 ~ 4.7V (at 25°)
    LED forward voltage (Vf): 4.2V typ. (at 25°C)
    LED forward current (If): 120mA (at 25°C)
    mechanical:
    module dimensions: 80.0 x 36.0mm
    viewing area: 64.0 x 13.8mm
    dot size: 0.55 x 0.50mm
    character size: 2.95 x 4.35mm
    pin assignment:
    GND: 1 (Vss)
    +5V: 2 (Vdd)
    contrast adjustment: 3 (V0)
    H/L register select signal: 4 (RS)
    H/L read/write signal: 5 (R/W)
    H/L enable signal: 6 (E)
    H/L data bus lines: 7 ~ 14 (DB0 ~ DB7)
    +4.2V for BKL: 15 (A)
    power supply for BKL (0V): 16 (K)
    http://www.velleman.be/
    Can I use this kind of LCD with my 16f628?I have never use lcd with my pic!!
    Is something inportant that I have to know about LCDs?
    Nikos
    this one is suppose to be Hitachi compatible... in fact it is... 'cause i have some here (40X2) with that controller and it works as is... no problem no nothing.
  1. VM142 velleman mini PLC
    By MikkelH in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 17:01
  2. Replies: 1
    Last Post: - 17th March 2006, 16:25
  3. VELLEMAN Pic Programmer/Checker
    By Squibcakes in forum General
    Last Post: - 8th February 2006, 18:35
  4. PBP compatible with Velleman k8048 programmer?
    By Henque19 in forum General
    Last Post: - 19th January 2006, 14:20
