Trouble with codes
Results 1 to 3 of 3
    Apr 2015
    Default Trouble with codes
    I ve been trying to solve this for like a month. Finally i got here.I am trying to create new hex file from below code but PIC16 Simulator IDE has given these errors.I've looked everywhere couldn't find anything. Pleas help me to solve this problem . Thank you.
    ; mclock8.asm
    ; "The Propeller" mechanically scanned LED clock
    ; some changes since last version -
    ; modified table etc for compatiblility with 8th LED
    ; watchdog timer used to ensure startup
    ; Bob Blick February 12, 1997
    ; Licensed under the terms of the GNU General Public License, www.gnu.org
    ; No warranties expredded or implied
    ; Bob Blick February 18, 2002
            list    p=16f84a
            radix    hex
            #include    <"p1f84a.inc">
    ; remember to set blast-time options: OSC=regular xtal, WDT=ON
    ; timings all based on 4 MHz crystal
    ; are these equates already in the include file? someday I'll look.
        " w    equ     0    ;"
        " f    equ     1    ;"
    ; Start of available RAM.
    cblock
    safe_w        ;not really temp, used by interrupt svc
    safe_s        ;not really temp, used by interrupt svc
    period_count    ;incremented each interrupt
    period_dup    ;copy of period_count safe from interrupt
    period_calc    ;stable period after hysteresis calc.
    flags        ;b2=int b1=minute b4=edge
    dot_index    ;which column is being displayed
    digit_index    ;which digit is being displayed
    hours        ;in display format, not hex(01-12)
    minutes        ;00 to 59
    bigtick_dbl    ;incremented each interrupt
    bigtick_hi
    bigtick_lo
    keys        ;key value
    scratch        ;scratch value
    tick        ;used by delay
    endc
    ; Start of ROM
            org    0x00        ;Start of code space
            goto    Start
    ; INTERRUPT SERVICE ROUTINE
            org    0x04        ;interrupt vector
    Intsvc    movwf    safe_w        ;save w
            swapf    STATUS,w    ;swap status, w
        movwf    safe_s        ;save status(nibble swap, remember)
    ; done saving, now start working
    ; clear watchdog timer to ensure startup
            clrwdt
    ; increment period count
        incf    period_count,f
            btfsc    STATUS,Z    ;zero set means overflow
        decf    period_count,f
    ; 234375 interrupts every minute. Increment the bigtick each time.
            incf    bigtick_lo,f
            btfsc    STATUS,Z
            incf    bigtick_hi,f
            btfsc    STATUS,Z
            incfsz    bigtick_dbl,f
            goto    Bigtick_out
    ; here? bigtick has rolled over to zero and one minute has passed.
    ; reload bigtick and set a flag for the main counter
            movlw    0xFC        ;234375 = 0x039387
            movwf    bigtick_dbl    ;0 - 0x039387 = 0xFC6C79
            movlw    0x6C
            movwf    bigtick_hi
            movlw    0x79
            movwf    bigtick_lo
            bsf    flags,1        ;notify Keep_time
    Bigtick_out
    ; done working, start restoring
            swapf    safe_s,w    ;fetch status, reswap nibbles
            movwf    STATUS        ;restore status
            swapf    safe_w,f    ;swap nibbles in preparation
            swapf    safe_w,w    ;for the swap restoration of w
            bcf    INTCON,2    ;clear interrupt flag before return
            retfie            ;return from interrupt
    ; CHARACTER LOOKUP TABLE
    ; ignore high bit. set=LED off, clear=LED on, bit0=bottom LED, bit6=top LED
    Char_tbl
            addwf    PCL,f
         "dt    0xC1,0xBE,0xBE,0xBE,0xC1    ; "O" ;
         "dt    0xFF,0xDE,0x80,0xFE,0xFF    ; "1" ;
        " dt    0xDE,0xBC,0xBA,0xB6,0xCE    ; "2" ;
        " dt    0xBD,0xBE,0xAE,0x96,0xB9    ; "3" ;
        " dt    0xF3,0xEB,0xDB,0x80,0xFB    ; "4" ;
        " dt    0x8D,0xAE,0xAE,0xAE,0xB1    ; "5" ;
         "dt    0xE1,0xD6,0xB6,0xB6,0xF9    ; "6" ;
         "dt    0xBF,0xB8,0xB7,0xAF,0x9F    ; "7" ;
         "dt    0xC9,0xB6,0xB6,0xB6,0xC9    ; "8" ;
         "dt    0xCF,0xB6,0xB6,0xB5,0xC3    ; "9" ;
         "dt    0xFF,0xC9,0xC9,0xFF,0xFF    ; ":" ;
    Char_tbl_end
    ; SUBROUTINES STARTING HERE
    ; clear important bits of ram
    Ram_init    movlw    0x07
            movwf    keys
            movlw    0x12        ;why do clocks always start
            movwf    hours        ;at 12:00 ?
            clrf    minutes
            clrf    dot_index
            clrf    digit_index
            movlw    0xFC
            movwf    bigtick_dbl
            retlw    0
    ; unused pins I am setting to be outputs
    Port_init    movlw    0x00        ;all output, b7=unused
            tris    PORTB        ;on port b attached to LEDs
            movlw    b'00010111'    ;port a has 5 pins. I need 4 inputs
                        ;b0=minutes, b1=10mins, b2=hours
                        ;b3=unused, b4=rotation index
            tris    PORTA        ;on port a
            retlw    0
    ; get timer-based interrupts going
    Timer_init    bcf    INTCON,2    ;clear TMR0 int flag
            bsf    INTCON,7    ;enable global interrupts
            bsf    INTCON,5    ;enable TMR0 int
            clrf    TMR0        ;clear timer
            clrwdt            ;why is this needed? just do it..
            movlw    b'11011000'    ;set up timer. prescaler(bit3)bypassed
            option            ;send w to option. generate warning.
            clrf    TMR0        ;start timer
            retlw    0
    ; test for index in rotation and store period in period_dup
    Check_index    movf    PORTA,w        ;get the state of port a
            xorwf    flags,w        ;compare with saved state
            andlw    b'00010000'    ;only interested in bit 4
            btfsc    STATUS,Z    ;test for edge
            retlw    0        ;not an edge, same as last
            xorwf    flags,f        ;save for next time
            btfsc    flags,4        ;test for falling edge
            retlw    0        ;must have been a rising edge
            movf    period_count,w    ;make a working copy
            movwf    period_dup    ;called period dup
            clrf    period_count    ;a fresh start for next rotation
            clrf    digit_index    ;set to first digit
            clrf    dot_index    ;first column
    ; calculate a period that does not dither or jitter
    ; period will not be changed unless new period is really different
             movf    period_calc,w
            subwf    period_dup,w    ;find difference
            btfss    STATUS,C    ;carry flag set means no borrow
            goto    Calc_period_neg    ;must be other way
            sublw    2        ;allowable deviation = 3
            btfss    STATUS,C    ;borrow won't skip
            incf    period_calc    ;new value much larger than calc
            retlw    0
    Calc_period_neg    addlw    2        ;allowable deviation = 3
            btfss    STATUS,C    ;carry will skip
            decf    period_calc    ;no carry means it must be changed
            retlw    0
    ; change LED pattern based on state of digit_index and dot_index
    Display_now    movlw    0x05
            xorwf    dot_index,w    ;test for end of digit
            movlw    0xFF        ;pattern for blank column
            btfsc    STATUS,Z
            goto    D_lookup_3    ;it needs a blank
            bcf    STATUS,C    ;clear carry before a rotate
            rlf    digit_index,w    ;double the index because each
            addwf    PCL,f        ;takes two instructions
    D_10hr        swapf    hours,w
            goto    D_lookup    ;what a great rush of power
    D_1hr        movf    hours,w        ;I feel when modifying
            goto    D_lookup    ;the program counter
    D_colon        movlw    0x0A
            goto    D_lookup
    D_10min        swapf    minutes,w
            goto    D_lookup
    D_1min        movf    minutes,w
            goto    D_lookup
    D_nothing    retlw    0
    D_lookup    andlw    b'00001111'    ;strip off hi bits
            movwf    scratch        ;multiply this by 5 for lookup
            addwf    scratch,f    ;table base position
            addwf    scratch,f    ;is this cheating?
            addwf    scratch,f    ;I think not.
            addwf    scratch,f    ;I think it is conserving energy!
            btfss    STATUS,Z    ;test for zero
            goto    D_lookup_2    ;not a zero
            movf    digit_index,f    ;this is just to test/set flag
            movlw    0xFF        ;this makes a blank LED pattern
            btfsc    STATUS,Z    ;test if it is 10 hrs digit
            goto    D_lookup_3    ;it's a leading zero
    D_lookup_2    movf    dot_index,w    ;get column
            addwf    scratch,w    ;add it to digit base
            call    Char_tbl    ;get the dot pattern for this column
    D_lookup_3    movwf    PORTB        ;send it to the LEDs
            movlw    0x0C        ;overhead value sub from period
            subwf    period_calc,w    ;compensate for overhead and set
            call    Delay        ;width of digits with this delay
            incf    dot_index,f    ;increment to the next column
            movlw    0x06        ;6 columns is a digit plus space
            xorwf    dot_index,w    ;next digit test
            btfss    STATUS,Z
            retlw    0        ;not a new digit
            clrf    dot_index    ;new digit time
            incf    digit_index,f
            retlw    0        ;Display_now done.
    ; a short delay routine
    Delay        movwf    tick
    Delay_loop    decfsz    tick,f
            goto    Delay_loop    ;w is not damaged, so Delay can
            return            ;be recalled without reloading
    ; test for keypress and call time adjust if needed
    Check_keys    movf    PORTA,w        ;get port "a"
            xorwf    keys,w        ;compare with previous
            andlw    b'00000111'    ;only care about button pins
            btfsc    STATUS,Z    ;zero set=no buttons
            retlw    0        ;return
            xorwf    keys,f        ;store key value
            movlw    0x64        ;a fairly long delay will
            movwf    scratch        ;prevent key bounces
    Key_delay    movlw    0xFF
            call    Delay
            decfsz    scratch
            goto    Key_delay
            btfss    keys,2        ;test "minutes" button
            goto    Inc_mins
            btfss    keys,1        ;test "tens" button
            goto    Inc_tens
            btfss    keys,0        ;test "hours" button
            goto    Inc_hours
            retlw    0        ;must be a glitch. yeah, right!
    ; increment ten minutes
    Inc_tens    movlw    0x0A
            movwf    scratch        ;scratch has ten
    Inc_tens_loop    call    Inc_mins
            decfsz    scratch
            goto    Inc_tens_loop    ;another minute added
            retlw    0
    ; increment one hour
    Inc_hours    movlw    0x12
            xorwf    hours,w
            btfsc    STATUS,Z
            goto    Inc_hours_12
            movlw    0x07        ;this part gets a little sloppy
            addwf    hours,w
            movlw    0x07
            btfss    STATUS,DC
            movlw    1
            addwf    hours,f
            retlw    0
    Inc_hours_12    movlw    0x01
            movwf    hours
            retlw    0
    ; increment the time based on flags,1 as sent by interrupt routine
    ; Inc_mins loop also used by time-setting routine
    Keep_time    btfss    flags,1        ;the minutes flag
            retlw    0        ;not this time
            bcf    flags,1        ;clear the minutes flag
    Inc_mins    movlw    0x07        ;start incrementing time
            addwf    minutes,w    ;add 7 minutes into w
            btfsc    STATUS,DC    ;did adding 7 cause digit carry?
            goto    Sixty_mins    ;then test for an hour change
            incf    minutes        ;otherwise add 1 for real
            retlw    0        ;and go back
    Sixty_mins    movwf    minutes        ;save the minutes
            movlw    0x60        ;test for 60
            xorwf    minutes,w    ;are minutes at 60?
            btfss    STATUS,Z
            retlw    0        ;no? go back
            clrf    minutes        ;otherwise zero minutes
            goto    Inc_hours    ;and increment hours
    ; End of subroutines
    ; Program starts here
    Start        call    Ram_init    ;set variables to nice values
            call    Port_init    ;set port directions
            call    Timer_init    ;start timer based interrupt
    ; Done initializing, start the endless loop.
    Circle                    ;begin the big loop
    ; detect falling edge on PORTA,4 to determine rotary index
    ; calculate rotation period and store in period_dup
    ; compare with working period(period_calc) and adjust if way different
            call    Check_index
    ; check display state and change if needed
            call    Display_now
    ; check keyboard and adjust time
            call    Check_keys
    ; check minute flag and increment time if a minute has passed
            call    Keep_time
    ; gentlemen, that's a clock, keep it rolling
            goto    Circle        ;you heard the man, get going!
    ; end of file
    mclock8.txt This is the original of the code.
    Jan 2012
    Grid EN19MV
    Default Re: Trouble with codes
    Umm this is a forum for PicBasicPro, not PIC16 simulator OR assembler.
    Let me Google that for you:
    -Stephen Hawking
    addwf PCL,f
    probably needs to be
    addwf PCL,f
  1. codes for PI control of a DC motor?
    By powerelect in forum mel PIC BASIC Pro
    Last Post: - 28th August 2012, 10:09
  2. Decoding OBDII trouble codes
    Last Post: - 13th September 2011, 08:57
  3. HM2007 codes
    By pagi in forum mel PIC BASIC Pro
    Last Post: - 25th July 2007, 14:45
  4. Codes
    By Eng. Baby heart in forum General
    Last Post: - 13th July 2006, 22:35
  5. Advice on PS/2 Scan Codes
    By penelopepug in forum mel PIC BASIC Pro
    Last Post: - 13th January 2006, 18:05
