transfer a string from ROM to an array
Results 1 to 40 of 45
    Italy
    Default Re: transfer a string from ROM to an array
    Wow, thanks !
    Need a break now. I'll let you know tomorrow or monday, as I test everything.
    Marco
    a cleaned up version
    an even better way
    Italy
    Hi again,
    thanks for the cleaned and full working sample.
    I'm much scared about "its not interrupt proof , other pbp functons may and do use FSR2 and TBLPTR" ....
    I'll try to ask Melabs if it's safe or not.
    Marco
    marco
    I will give you three options
    1. intcon.7=0 ' I'm assuming it was set
    @ Flash2Ram _buff,_String1' Get a String from flash memory
    intcon.7=1
    2 . examine your .lst file and determine if any of your isr routines use FSR2 or TBLPTR
    if none of them do then don't worry (this is the most likely case)
    3. there are two other indirect addressing pointers FSR0 and FSR1 maybe one of them would be free
    as groucho would say if you don't like these I have others
    this is the best I can offer without seeing your code
    Looking at the DT-INTS_18 file Darrel is declaring variables for saving the FSR's:
    fsave0H     var WORD  BANK0  SYSTEM   ' locations for FSR registers
    fsave1H     var WORD  BANK0  SYSTEM
    fsave2H     var WORD  BANK0  SYSTEM
    fsave0L     var WORD  BANK0  SYSTEM   ' low priority FSR locations
    fsave1L     var WORD  BANK0  SYSTEM
    fsave2L     var WORD  BANK0  SYSTEM
    There's also a section towards the end that says
    ; ---[See if we need to save TBLPTR]------------------------------------------
    Which sets a flag SAVE_TBLPTR = 1 when any PBP command that uses TBLPTR is used and in the ReEnterPBP-18 file he's declaring variables for TBLPTR like:
        TBLPTRU_H     VAR HP_Vars[31]
          TBLPTRU_SaveH VAR TBLPTRU_H.lowbyte
        TBLPTR_H      VAR HP_Vars[32]
          TBLPTRH_SaveH VAR TBLPTR_H.highbyte
          TBLPTRL_SaveH VAR TBLPTR_H.lowbyte
    And then, further down in that file:
    @ if Save_TBLPTR == 1
        TBLPTRU_SaveH = TBLPTRU
        TBLPTRH_SaveH = TBLPTRH
        TBLPTRL_SaveH = TBLPTRL
    @ endif
    So, to me, it looks like DT-INTS is handling all that stuff and you would/should only need to worry about it of you're using the FSR's or TBLPTR in any other ASM routines which would mean that DT-INTS does't detect them being used and therefor doesn't save them.
    Of course I may have it all wrong in which case I hope someone who can understand the ASM in DT-Ints better then me can explain what's going on.
    thanks for that henrik I never thought to look at how dt ints works . dt's code leaves nothing to chance ,I'm left humbled again
  1. String of characters(array) to decimal value
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 20th June 2012, 15:30
  2. Replies: 3
    Last Post: - 3rd December 2011, 23:48
  3. Array of string to send with TX int ?
    By amgen in forum General
    Last Post: - 18th August 2011, 17:56
  4. How to send a string with another string inside it?
    Last Post: - 13th May 2011, 18:11
  5. Manipulation of string array
    By Benny007 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 21:50
