transfer a string from ROM to an array
Results 1 to 40 of 45
    Italy
    Default Re: transfer a string from ROM to an array
    well, I was not understanding why I had to increment the pointer by two when reading data ...
    I have subsituted now pokecode with da and peekcode with readcode and saved another kb .. thanks !
    Marco
    this might do what you want
    note with the da method char values must be<128 ie 7 bit ascii
    just noticed I left an arraywrite in there it can/should be removed and the bit setting the 0 at end of the string was fixed too
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 4/14/2015                                         *
      CONFIG  FOSC = INTIO67
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRT = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 18
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 512
      CONFIG  CCP2MX = PORTC
      CONFIG  PBADEN = OFF
      CONFIG  LPT1OSC = OFF
      CONFIG  HFOFST = ON
      CONFIG  MCLRE = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
      define OSC 64
     osccon=$70   '64 mhz
     OSCTUNE.6=1
     pause 2000
    Serout2 PORTb.7,84,["ready",13,10]
    Addr var word
     Char var byte
     cnt var word
    inbuff  var byte[30]
    buff var byte[30]
     Clear
     goto StartLoop ' Required
     String1:
     @ da "This is a string",0
     AnotherString:
     @ da "Here is another string",0
     '------------GetAddress Macro - Location insensitive -------------------------
    GetAddress macro Label, Wout ; Returns the Address of a Label as a Word
       CHK?RP Wout
       movlw low Label
       movwf Wout
       movlw High Label
       movwf Wout + 1
    Loadb	 macro buffer
    	CHK?RP _cnt
     	movlw low buffer
    	movwf FSR2L
     	movlw High buffer
     	movwf FSR2H
     ARRAYWRITE buff,["123"]
     StartLoop: ' This loop repeats continuously just as a test.
    @ GetAddress _String1, _Addr ' Get address of String
    @ Loadb    _inbuff
    CNT=0
     gosub StringOut ' Send the String
     Serout2 PORTb.7,84, ["inbuff "," c ",hex CNT," ",str inbuff\CNT ,13,10] ' New Line
    @ GetAddress _AnotherString, _Addr ' Get address of String
    @ Loadb    _inbuff
    CNT=0
     goto StartLoop ' Repeat
     StringOut: ' Send the string out via Hserout
     Readcode Addr, Char ' Get a character
     if Char = 0 then StringDone ' Look for Null char, Stop if found
     bfill:
     asm
     	CHK?RP _Char
     	movf _Char ,w
        movwf  POSTINC2
     endasm
     cnt=cnt+1
     Addr = Addr + 1 ' Point to next character
     goto StringOut ' Continue with rest of the string
     StringDone:
     asm
     	movlw 0
        movwf   INDF2
      endasm
    Italy
    Wow, thanks !
    Need a break now. I'll let you know tomorrow or monday, as I test everything.
    Marco
    a cleaned up version
    an even better way
    Italy
    Hi again,
    thanks for the cleaned and full working sample.
    I'm much scared about "its not interrupt proof , other pbp functons may and do use FSR2 and TBLPTR" ....
    I'll try to ask Melabs if it's safe or not.
    Marco
    marco
    I will give you three options
    1. intcon.7=0 ' I'm assuming it was set
    @ Flash2Ram _buff,_String1' Get a String from flash memory
    intcon.7=1
    2 . examine your .lst file and determine if any of your isr routines use FSR2 or TBLPTR
    if none of them do then don't worry (this is the most likely case)
    3. there are two other indirect addressing pointers FSR0 and FSR1 maybe one of them would be free
    as groucho would say if you don't like these I have others
    this is the best I can offer without seeing your code
  1. String of characters(array) to decimal value
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 20th June 2012, 15:30
  2. Replies: 3
    Last Post: - 3rd December 2011, 23:48
  3. Array of string to send with TX int ?
    By amgen in forum General
    Last Post: - 18th August 2011, 17:56
  4. How to send a string with another string inside it?
    Last Post: - 13th May 2011, 18:11
  5. Manipulation of string array
    By Benny007 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 21:50
