Hi, I undestand, but I can't put togheter something of working. If you want to have a look to this code, you'll see in my comments where are my doubts.
Anyway the code doesn't compile and give errors ...
Code:inbuff VAR BYTE[100] x VAR BYTE y VAR BYTE LS0 VAR WORD LS1 VAR WORD Lp1: @ LoadInbuff _ROM_CfgString, _Inbuff ; I would like to transfer the ROM string in RAM Inbuff debug str inbuff\100,13,10 goto lp1 ASM LoadInbuff macro Text, Dest CHK?RP _LS0 movlw low Text ; here I load in LS0 the ROM address of the source string movwf _LS0 movlw High Text movwf _LS0 + 1 CHK?RP _LS1 ; here I suppose to load in LS1 the address of the destination buffer movlw low Dest ; but I feel something is wrong movwf _LS1 movlw High Dest movwf _LS1 + 1 L?CALL _Lstr endm ENDASM Lstr: y=0 do peekcode LS0, x ; --->>> what to do here to write the value x to the destination buffer ?? if x=0 then exit y=y+1 LS0=LS0+2 loop return ROM_CfgString: PokeCode "This a test string",0
