as henrik said
inBuff VAR BYTE[100]
in asm the array address is
_inBuff
or give a new name
mybuff =_inBuff
note label in col 0
make sure you don't overrun your buffer
_inBuff
or give a new name
mybuff =_inBuff
note label in col 0
Hi, I undestand, but I can't put togheter something of working. If you want to have a look to this code, you'll see in my comments where are my doubts.
Anyway the code doesn't compile and give errors ...
Code:inbuff VAR BYTE[100] x VAR BYTE y VAR BYTE LS0 VAR WORD LS1 VAR WORD Lp1: @ LoadInbuff _ROM_CfgString, _Inbuff ; I would like to transfer the ROM string in RAM Inbuff debug str inbuff\100,13,10 goto lp1 ASM LoadInbuff macro Text, Dest CHK?RP _LS0 movlw low Text ; here I load in LS0 the ROM address of the source string movwf _LS0 movlw High Text movwf _LS0 + 1 CHK?RP _LS1 ; here I suppose to load in LS1 the address of the destination buffer movlw low Dest ; but I feel something is wrong movwf _LS1 movlw High Dest movwf _LS1 + 1 L?CALL _Lstr endm ENDASM Lstr: y=0 do peekcode LS0, x ; --->>> what to do here to write the value x to the destination buffer ?? if x=0 then exit y=y+1 LS0=LS0+2 loop return ROM_CfgString: PokeCode "This a test string",0
add this to your code
ARRAYWRITE inbuff,3,,["123"]
and then look at the lst file generated
see how arraywrite works
the array address goes in like this01487 LIST
000004 C00C FFE9 01488 ARRAYWRITE movff R5, FSR0L ; Put the array pointer into FSR0
000008 C00D FFEA 01489 movff R5 + 1, FSR0H
00000C 6EEE 01490 movwf POSTINC0 ; Put the char into the array and bump up the address
00000E CFE9 F00C 01491 movff FSR0L, R5 ; Save new pointer
000012 CFEA F00D 01492 movff FSR0H, R5 + 1
C:\PBP3\EXAMPLES\MARCICK.PBP 00074 ARRAYWRITE inbuff,3,,["123"]
00192 ARRAYWRITENAME?B _inbuff
M MOVE?CW _inbuff, R5
M ifdef USE_LINKER
M CHK?RP R5
M movlw low (_inbuff)
M movwf R5
M movlw high (_inbuff)
M movwf (R5) + 1
you need to emulate this using your own vars don't use r5 of course
interrupts will need to be disabled too
ps the forum totally destroys white space you need to look at your xxx.lst file to make it out properly
Richard,
Thanks for your time but .. if you have some more ... could you please take my sample above and correct it so it works ?
It's two days I'm turning crazy.
Anyway thank you
Marco
I do it this way , and use the bounds checking features of arraywriteCode:'pic18f45k20 '**************************************************************** '* Name : UNTITLED.BAS * '* Author : [select VIEW...EDITOR OPTIONS] * '* Notice : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 4/14/2015 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** '* Name : UNTITLED.BAS * '* Author : [select VIEW...EDITOR OPTIONS] * '* Notice : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 4/14/2015 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** #CONFIG CONFIG FOSC = INTIO67 CONFIG FCMEN = OFF CONFIG IESO = OFF CONFIG PWRT = OFF CONFIG BOREN = SBORDIS CONFIG BORV = 18 CONFIG WDTEN = ON CONFIG WDTPS = 512 CONFIG CCP2MX = PORTC CONFIG PBADEN = OFF CONFIG LPT1OSC = OFF CONFIG HFOFST = ON CONFIG MCLRE = ON CONFIG STVREN = ON CONFIG LVP = OFF CONFIG XINST = OFF CONFIG DEBUG = OFF CONFIG CP0 = OFF CONFIG CP1 = OFF CONFIG CP2 = OFF CONFIG CP3 = OFF CONFIG CPB = OFF CONFIG CPD = OFF CONFIG WRT0 = OFF CONFIG WRT1 = OFF CONFIG WRT2 = OFF CONFIG WRT3 = OFF CONFIG WRTC = OFF CONFIG WRTB = OFF CONFIG WRTD = OFF CONFIG EBTR0 = OFF CONFIG EBTR1 = OFF CONFIG EBTR2 = OFF CONFIG EBTR3 = OFF CONFIG EBTRB = OFF #ENDCONFIG define OSC 64 osccon=$70 '64 mhz OSCTUNE.6=1 pause 2000 Serout2 PORTb.7,84,["ready",13,10] Addr var word Char var byte cnt var byte inbuff var byte[30] buff var byte[30] Clear goto StartLoop ' Required String1: @ da "This is a string",0 AnotherString: @ da "Here is another string",0 '------------GetAddress Macro - Location insensitive ------------------------- ASM GetAddress macro Label, Wout ; Returns the Address of a Label as a Word CHK?RP Wout movlw low Label movwf Wout movlw High Label movwf Wout + 1 endm ENDASM StartLoop: ' This loop repeats continuously just as a test. @ GetAddress _String1, _Addr ' Get address of String cnt=0 gosub StringOut ' Send the String Serout2 PORTb.7,84, [13,10] ' New Line Serout2 PORTb.7,84, ["inbuff ",str inbuff\cnt ,13,10] ' New Line @ GetAddress _AnotherString, _Addr ' Get address of String cnt=0 gosub StringOut ' Send the String Serout2 PORTb.7,84,[13,10] ' New Line Serout2 PORTb.7,84, ["inbuff ",str inbuff\cnt ,13,10] ' New Line pause 500 goto StartLoop ' Repeat StringOut: ' Send the string out via Hserout Readcode Addr, Char ' Get a character if Char = 0 then StringDone ' Look for Null char, Stop if found buff[cnt]=char cnt=cnt+1 Serout2 PORTb.7,84, [Char] ' Send char Addr = Addr + 1 ' Point to next character goto StringOut ' Continue with rest of the string StringDone: ARRAYWRITE inbuff,cnt,,[str buff] return end
Well, any help is appreciated, so thank you anyway, but this is not what I'm asking.
My intent is not to use Arraywrite because consumes a lot of space.
With this sample code that now works I transfer a ROM string to an array, but I want also the destination array to be a parameter passed to the macro.
So with a single macro I could transfer to inbuff or testbuff or any buffer Is declared.
Code:Define USE_LFSR 1 DEFINE OSC 8 DEFINE DEBUG_REG PORTB DEFINE DEBUG_BIT 4 DEFINE DEBUG_BAUD 9600 DEFINE DEBUG_MODE 0 OSCCON =%01110000 inbuff VAR BYTE[100] x VAR BYTE y VAR BYTE LS0 VAR WORD LS1 VAR WORD goto Lp1 ASM LoadInbuff macro Text CHK?RP _LS0 movlw low Text ; here I load in LS0 the ROM address of the source string movwf _LS0 movlw High Text movwf _LS0 + 1 L?CALL _Lstr endm ENDASM Lstr: y=0 do peekcode LS0, x inbuff(y)=x if x=0 then exit y=y+1 LS0=LS0+2 loop return Lp1: @ LoadInbuff _ROM_CfgString debug str inbuff\100,13,10 goto lp1 ROM_CfgString: PokeCode "This a test string",0
I understand but pbp does not allow pointers like in C . the only way I can see for this to be done is to have either a user cmd or asm code that actually mimics arraywrite's array loading method anyway .I'm sure something like that could be made accept a pointer to the array to be loaded .
I'm just having trouble seeing any point to this. my prog with arraywite 1041 bytes , with arraywrite commented out 951 bytes ,surely 90 bytes is pretty good I'm sure my asm attempts would be much worse than that
I have to ask why do this at all . I can't see a good reason to read a string from flash into ram ,surely its best shuffled off to its destination directly . if it needs to be altered before its used was it really a good move putting it in flash memory in the first place.
have a look at this thread post#50 where I update portions of an array with EXT modifiers and arraywrite . the fixed unchanging parts could be in flash
http://www.picbasic.co.uk/forum/showthread.php?t=19420
perhaps if you provide a little more detail .....
