transfer a string from ROM to an array - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Default Re: transfer a string from ROM to an array
    this works
    @ da "say \"Hello\"\0"
  2. #42
    Italy
    where ?
    da – Data ASCII.
    Generates a packed 14-bit number representing two 7-bit ASCII characters.
    4.14 da – STORE STRINGS IN PROGRAM MEMORY (PIC12/16 MCUs)
    Funny, but if you try it you'll see the unwanted 00 added
    db is ok
  3. #43
    db is definitely an easier way to pack a mixed string data statement like "say",34,"hello",34,0 . funny I could never see the point of db until now
  4. #44
    Italy
    PICs always have hidden surprises ....
    Ok, understood also indirect addressing now, thanks for your patience :-)
  5. #45
    Aug 2004
    Hi:
    I use this routine to send eeprom stored msg's to display LCD.
    It can be modified to send then to a string...
    I hope this helps...
    'USED VARS:
    SDAT VAR PORTD.1 'I2C EEPROM DATA 'ADJUST TO USED PINS AND
    SCLK VAR PORTD.0 'I2C EEPROM CLOCK 'MAKE THEM INPUTS IN USED TRIS REG.
    CHAR VAR BYTE
    SLAVE VAR BYTE
    EEADDR VAR WORD
    SLAVE = $A0 'EEPROM SLAVE ADDRESS
    '***** SUB TO DISPLAY MSGS STORED IN EEPROM ****************
    MSG_DISP:
    GOSUB CLRDISP 'CLEAR SCREEN
    MSG:
    LEENXT: I2CREAD SDAT,SCLK,SLAVE,EEADDR,[CHAR] 'SIN CLEAR
    IF CHAR => $80 THEN
    LCDOUT $FE,CHAR
    GOTO INCADD
    IF CHAR <> 0 THEN
    LCDOUT CHAR
    INCADD: EEADDR = EEADDR + 1
    GOTO LEENXT
    'TO CALL THE ROUTINE:
    'SET EEPROM ADDRES:
    'YOUR STRING CAN HAVE ANY LENGTH AND MUST BE TERMINATED WITH A NULL CHAR
    '"00"
    EEADDR = $0350 'WHEREVER YOUR STRING STARTS
    GOSUB MSG_DISP
    ' YOU MUST USE AN EEPROM WITH WORD ADDRESS (25LC32A,OR BIGGER)
    'PROGRAMM YOUR EEPROM WITH MSGS ENDED WITH 00 (NULL) AND TAKE NOTE OF
    'THE START ADDRESSES.
    'AND THATS ALL...
    Greetings...
    Ruben de la Pena V.
  1. String of characters(array) to decimal value
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 20th June 2012, 14:30
  2. Replies: 3
    Last Post: - 3rd December 2011, 22:48
  3. Array of string to send with TX int ?
    By amgen in forum General
    Last Post: - 18th August 2011, 16:56
  4. How to send a string with another string inside it?
    Last Post: - 13th May 2011, 17:11
  5. Manipulation of string array
    By Benny007 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 20:50
