transfer a string from ROM to an array
Page 1 of 2 12 LastLast
Results 1 to 40 of 45
    Italy
    Default transfer a string from ROM to an array
    Hi all,
    I'm using this code to load an array with a certain text string
    inbuff VAR BYTE(100)
    arraywrite inbuff,["Sample test string"]
    I have many different string in variuos parts of the program and this code consumes a lot of space, so I would like to optimize it using macros .
    It's easy to store the string in code space and then with a macro retrieve the address and read it:
    ROM_String1:       PokeCode "Sample test string",0
    ; macro to retrieve the address
    @getaddr	macro Text, Addr
    @ 	movlw low Text
    @ 	movwf Addr
    @ 	movlw High Text
    @ 	movwf Addr + 1
    @ endm
    ; code
    	@ getaddr _ROM_String1, _w0
      repeat
        peekcode w0, x
        if x then
          debug x
          w0=w0+2
      until x=0                                     ' print till end of string '0'
    Sb00:
    Now I have some difficulties to continue: instead of print the string, I need to store it in RAM, the same things that does ArrayWrite.
    So the macro should be modified to accept as parameters, the source ROM string and the destination address in RAM
    Something like
    @ LoadStr _ROM_CfgString, _inbuff
    So calling the macro I can specify any string stored in ROM and any RAM destination where to put it.
    Could anybody help me to complete the macro ?
    Marco
    Default Re: transfer a string from ROM to an array
    How about:
    inBuff VAR BYTE[100]
    i VAR BYTE
    i = 24         ' Start putting the string at inBuff[24] for example
    repeat
      peekcode w0, x
      if x then
        inBuff[i] = x
        debug x
        w0=w0+2
      i=i+1
    until x=0
    Italy
    Hi Enrik, thanks,
    inbuff should be a parameter passed to the macro and not a fixed address.
    I have something like this:
    Outbuff VAR BYTE[100]
    Testbuff VAR BYTE[200]
    etc etc
    I want that Inbuff, Outbuff, TestBuff is a parameter of the macro, so the string can be written anywhere
    I'm not very good at assembly language but can't you just pass it the variable name, like _inBuff, which would be the "start adress" of the array?
    Italy
    There must be some awful mistakes, I can't get this code working
    	CONFIG	OSC = IRCIO67	    ;Internal oscillator block, port function on RA6 and RA7
    	CONFIG	WDT = ON	    	;WDT enabled
    	CONFIG	WDTPS = 64	    	;1:64
    	CONFIG	PWRT = ON	    	;PWRT enabled
    	CONFIG	BOREN = BOHW	    ;Brown-out Reset enabled in hardware only (SBOREN is disabled)
    	CONFIG	BORV = 3	    	;VBOR set to 2.1V
    	CONFIG	MCLRE = OFF	    	;RE3 input pin enabled; MCLR disabled
    	CONFIG	LPT1OSC = OFF	    ;Timer1 configured for higher power operation
    	CONFIG	PBADEN = OFF	    ;PORTB<4:0> pins are configured as digital I/O on Reset
    	CONFIG	XINST = OFF	    	;Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    	CONFIG	LVP = OFF	    	;Single-Supply ICSP disabled
    	CONFIG	STVREN = ON
    	CONFIG	CP0 = ON
    	CONFIG	CP1 = ON
    	CONFIG	CP2 = ON
    	CONFIG	CP3 = ON
    	Define 		USE_LFSR 	1
    	DEFINE		OSC			8
    	DEFINE		DEBUG_REG	PORTB
    	DEFINE		DEBUG_BIT	4
    	DEFINE		DEBUG_BAUD	9600
    	DEFINE		DEBUG_MODE	0
    	OSCCON		=%01110000
    	Led			VAR PORTB.3
    	inbuff		VAR BYTE[100]
    	x			VAR BYTE
    	y			VAR BYTE
    	LS0 		VAR Word
    	LS1 		VAR Word
    	goto	Start
    LoadString	 macro Text, Dest
     	movlw low Text
    	movwf _LS0
     	movlw High Text
     	movwf _LS0 + 1
    	movlw low Dest
    	movwf _LS1
    	movlw High Dest
    	movwf _LS1 + 1
     	L?CALL   _Lstr
    Lstr:
    	y=0
      	repeat
        	peekcode LS0, x
    		LS1(y)=x
    		y=y+1
    	    LS0=LS0+2
        until x=0
    Start:
    	@ LoadString _ROM_CfgString, inbuff
    	debug str inbuff\100,13,10
    	high led
    	low led
    	goto start
    ROM_CfgString:       PokeCode "This a test string",0
    try a forum search "embedded string"
    Italy
    What I can't find how to do, is to pass to the macro the address of an array.
    in asm the array address is
    _inBuff
    or give a new name
    mybuff =_inBuff
    note label in col 0
    make sure you don't overrun your buffer
    Italy
    Hi, I undestand, but I can't put togheter something of working. If you want to have a look to this code, you'll see in my comments where are my doubts.
    Anyway the code doesn't compile and give errors ...
    	x			VAR BYTE
    	y			VAR BYTE
    	LS0 		VAR WORD
    	LS1			VAR WORD
    Lp1:
    	@ LoadInbuff _ROM_CfgString, _Inbuff		; I would like to transfer the ROM string in RAM Inbuff
    	goto lp1
    LoadInbuff	 macro Text, Dest
    	CHK?RP _LS0
     	movlw low Text		; here I load in LS0 the ROM address of the source string
    	movwf _LS0
     	movlw High Text
     	movwf _LS0 + 1
    	CHK?RP _LS1			; here I suppose to load in LS1 the address of the destination buffer
     	movlw low Dest		; but I feel something is wrong
    	movwf _LS1
     	movlw High Dest
     	movwf _LS1 + 1
    	L?CALL   _Lstr
    Lstr:
    	y=0
      	do
        	peekcode LS0, x
    		; --->>> what to do here to write the value x to the destination buffer ??
    		if x=0 then exit
    		y=y+1
    	    LS0=LS0+2
        loop
    add this to your code
    ARRAYWRITE inbuff,3,,["123"]
    and then look at the lst file generated
    see how arraywrite works
    01487 LIST
    000004 C00C FFE9 01488 ARRAYWRITE movff R5, FSR0L ; Put the array pointer into FSR0
    000008 C00D FFEA 01489 movff R5 + 1, FSR0H
    00000C 6EEE 01490 movwf POSTINC0 ; Put the char into the array and bump up the address
    00000E CFE9 F00C 01491 movff FSR0L, R5 ; Save new pointer
    000012 CFEA F00D 01492 movff FSR0H, R5 + 1
    the array address goes in like this
    C:\PBP3\EXAMPLES\MARCICK.PBP 00074 ARRAYWRITE inbuff,3,,["123"]
    00192 ARRAYWRITENAME?B _inbuff
    M MOVE?CW _inbuff, R5
    M ifdef USE_LINKER
    M CHK?RP R5
    M movlw low (_inbuff)
    M movwf R5
    M movlw high (_inbuff)
    M movwf (R5) + 1
    you need to emulate this using your own vars don't use r5 of course
    interrupts will need to be disabled too
    ps the forum totally destroys white space you need to look at your xxx.lst file to make it out properly
    Italy
    Richard,
    Thanks for your time but .. if you have some more ... could you please take my sample above and correct it so it works ?
    It's two days I'm turning crazy.
    Anyway thank you
    Marco
    'pic18f45k20
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 4/14/2015                                         *
      CONFIG  FOSC = INTIO67
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRT = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 18
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 512
      CONFIG  CCP2MX = PORTC
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  MCLRE = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
      define OSC 64
     osccon=$70   '64 mhz
     OSCTUNE.6=1
     pause 2000
    Serout2 PORTb.7,84,["ready",13,10]
    Addr var word
     Char var byte
     cnt var byte
    inbuff  var byte[30]
    buff var byte[30]
     Clear
     goto StartLoop ' Required
     String1:
     @ da "This is a string",0
     AnotherString:
     @ da "Here is another string",0
     '------------GetAddress Macro - Location insensitive -------------------------
    GetAddress macro Label, Wout ; Returns the Address of a Label as a Word
       CHK?RP Wout
       movlw low Label
       movwf Wout
       movlw High Label
       movwf Wout + 1
     StartLoop: ' This loop repeats continuously just as a test.
    @ GetAddress _String1, _Addr ' Get address of String
     cnt=0
     gosub StringOut ' Send the String
     Serout2 PORTb.7,84, [13,10] ' New Line
     Serout2 PORTb.7,84, ["inbuff ",str inbuff\cnt ,13,10] ' New Line
    @ GetAddress _AnotherString, _Addr ' Get address of String
     cnt=0
     Serout2 PORTb.7,84,[13,10] ' New Line
     goto StartLoop ' Repeat
     StringOut: ' Send the string out via Hserout
     Readcode Addr, Char ' Get a character
     if Char = 0 then StringDone ' Look for Null char, Stop if found
     buff[cnt]=char
     cnt=cnt+1
     Serout2 PORTb.7,84, [Char] ' Send char
     Addr = Addr + 1 ' Point to next character
     goto StringOut ' Continue with rest of the string
     StringDone:
     ARRAYWRITE inbuff,cnt,,[str buff]
    I do it this way , and use the bounds checking features of arraywrite
    Italy
    Well, any help is appreciated, so thank you anyway, but this is not what I'm asking.
    My intent is not to use Arraywrite because consumes a lot of space.
    With this sample code that now works I transfer a ROM string to an array, but I want also the destination array to be a parameter passed to the macro.
    So with a single macro I could transfer to inbuff or testbuff or any buffer Is declared.
    	Define 		USE_LFSR 	1
    	DEFINE		OSC			8
    	DEFINE		DEBUG_BIT	4
    	DEFINE		DEBUG_MODE	0
    	OSCCON		=%01110000
    	x			VAR BYTE
    	y			VAR BYTE
    	LS0 		VAR WORD
    	LS1			VAR WORD
    	goto Lp1
    	CHK?RP _LS0
    	movwf _LS0
     	movlw High Text
     	movwf _LS0 + 1
    	L?CALL   _Lstr
    Lstr:
    	y=0
      	do
    	    	peekcode LS0, x
    		inbuff(y)=x
    		if x=0 then exit
    		y=y+1
    		LS0=LS0+2
    	loop
    Lp1:
    	goto lp1
    I understand but pbp does not allow pointers like in C . the only way I can see for this to be done is to have either a user cmd or asm code that actually mimics arraywrite's array loading method anyway .I'm sure something like that could be made accept a pointer to the array to be loaded .
    I'm just having trouble seeing any point to this. my prog with arraywite 1041 bytes , with arraywrite commented out 951 bytes ,surely 90 bytes is pretty good I'm sure my asm attempts would be much worse than that
    I have to ask why do this at all . I can't see a good reason to read a string from flash into ram ,surely its best shuffled off to its destination directly . if it needs to be altered before its used was it really a good move putting it in flash memory in the first place.
    have a look at this thread post#50 where I update portions of an array with EXT modifiers and arraywrite . the fixed unchanging parts could be in flash
    http://www.picbasic.co.uk/forum/showthread.php?t=19420
    perhaps if you provide a little more detail .....
    Italy
    Hi Richard,
    yes, strings need to be altered before use.
    Well, I had about 3K free on 64k (PIC18F4680) and needed to add more code, so I was looking for some tricks to save space and make a diet to the actual code.
    I have noted that if I substitute an arraywrite entry (for a string of about 100 char) with the method above, I save around 600 bytes of code. I have about 10 difefrent strings, so the total saved space is several KB.
    To be honest I can't understand why there is so much difference between the two methods ....
    Also I have noted this: in a blank project like the sample above, the difference between the two methods is about 150 bytes. Inside my 63KB project, the difference is more than 600 bytes.
    So it probably depends where the instruction and the buffer are located (bank switching, etc). For thei sreason I wonder also if the method above with the macro is correct or can bring to unexpected behavours in some situations .....
    For example: why did you say before "interrupts need to be disabled" ? Context is fully saved and restored in the interrupt routines. Also I use "PBP Instant Interrupt" of that great Darrel that should be bullet-proof.
    Marco
    I was thinking that if were to read the flash using TABLPU reg and index through the ram array using fsr0 then I'm not convinced that method is interrupt proof
    but your not doing that anyway
    I expect you realise that pokecode uses twice the memory to store a string compared to da
    Last edited by richard; - 17th April 2015 at 09:52. Reason: got interrupted by customer / and lost plot
    Italy
    well, I was not understanding why I had to increment the pointer by two when reading data ...
    I have subsituted now pokecode with da and peekcode with readcode and saved another kb .. thanks !
    Marco
    this might do what you want
    note with the da method char values must be<128 ie 7 bit ascii
    just noticed I left an arraywrite in there it can/should be removed and the bit setting the 0 at end of the string was fixed too
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRT = OFF
      CONFIG  BORV = 18
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 512
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  MCLRE = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
      define OSC 64
     osccon=$70   '64 mhz
     OSCTUNE.6=1
     pause 2000
    Addr var word
     Char var byte
     cnt var word
    inbuff  var byte[30]
    buff var byte[30]
     Clear
     String1:
     AnotherString:
       CHK?RP Wout
       movlw low Label
       movwf Wout
       movlw High Label
       movwf Wout + 1
    Loadb	 macro buffer
    	CHK?RP _cnt
     	movlw low buffer
    	movwf FSR2L
     	movlw High buffer
     	movwf FSR2H
     ARRAYWRITE buff,["123"]
    @ Loadb    _inbuff
    CNT=0
     Serout2 PORTb.7,84, ["inbuff "," c ",hex CNT," ",str inbuff\CNT ,13,10] ' New Line
    @ Loadb    _inbuff
    CNT=0
     bfill:
     asm
     	CHK?RP _Char
     	movf _Char ,w
        movwf  POSTINC2
     endasm
     cnt=cnt+1
     StringDone:
     asm
     	movlw 0
        movwf   INDF2
      endasm
    Italy
    Wow, thanks !
    Need a break now. I'll let you know tomorrow or monday, as I test everything.
    Marco
    a cleaned up version
    an even better way
    Italy
    Hi again,
    thanks for the cleaned and full working sample.
    I'm much scared about "its not interrupt proof , other pbp functons may and do use FSR2 and TBLPTR" ....
    I'll try to ask Melabs if it's safe or not.
    Marco
    marco
    I will give you three options
    1. intcon.7=0 ' I'm assuming it was set
    @ Flash2Ram _buff,_String1' Get a String from flash memory
    intcon.7=1
    2 . examine your .lst file and determine if any of your isr routines use FSR2 or TBLPTR
    if none of them do then don't worry (this is the most likely case)
    3. there are two other indirect addressing pointers FSR0 and FSR1 maybe one of them would be free
    as groucho would say if you don't like these I have others
    this is the best I can offer without seeing your code
    Looking at the DT-INTS_18 file Darrel is declaring variables for saving the FSR's:
    fsave0H     var WORD  BANK0  SYSTEM   ' locations for FSR registers
    fsave1H     var WORD  BANK0  SYSTEM
    fsave2H     var WORD  BANK0  SYSTEM
    fsave0L     var WORD  BANK0  SYSTEM   ' low priority FSR locations
    fsave1L     var WORD  BANK0  SYSTEM
    fsave2L     var WORD  BANK0  SYSTEM
    There's also a section towards the end that says
    ; ---[See if we need to save TBLPTR]------------------------------------------
    Which sets a flag SAVE_TBLPTR = 1 when any PBP command that uses TBLPTR is used and in the ReEnterPBP-18 file he's declaring variables for TBLPTR like:
        TBLPTRU_H     VAR HP_Vars[31]
          TBLPTRU_SaveH VAR TBLPTRU_H.lowbyte
        TBLPTR_H      VAR HP_Vars[32]
          TBLPTRH_SaveH VAR TBLPTR_H.highbyte
          TBLPTRL_SaveH VAR TBLPTR_H.lowbyte
    And then, further down in that file:
    @ if Save_TBLPTR == 1
        TBLPTRU_SaveH = TBLPTRU
        TBLPTRH_SaveH = TBLPTRH
        TBLPTRL_SaveH = TBLPTRL
    @ endif
    So, to me, it looks like DT-INTS is handling all that stuff and you would/should only need to worry about it of you're using the FSR's or TBLPTR in any other ASM routines which would mean that DT-INTS does't detect them being used and therefor doesn't save them.
    Of course I may have it all wrong in which case I hope someone who can understand the ASM in DT-Ints better then me can explain what's going on.
    thanks for that henrik I never thought to look at how dt ints works . dt's code leaves nothing to chance ,I'm left humbled again
    Italy
    Guys,
    about Darrel code I could put my hand on fire.
    about my code I can bet there are bugs ...
    but with your help now I have everything clear and know where problems can be or not. I have DTint and other ISR where I'll take care about FSR and TBLPTR.
    so, many thanks again for your support !
    bye
    Marco
    Italy
    Hi Richard,
    maybe I'm doing some confusion and about to say something of funny, but I have a doubt:
    How do you ensure in this code that you are in the correct bank reading the address of "buffer" ?
    Flash2Ram macro buffer, msg ; Fills the buffer from flash msg
       movlw   UPPER msg
       movwf   TBLPTRU
       movlw   HIGH msg
       movwf   TBLPTRH
       movlw   LOW msg
       movwf   TBLPTRL
       movlw   low buffer
       movwf   FSR2L
       movlw   High buffer
       movwf   FSR2H
       L?CALL  _bfill
    buffer does not actually exist its just a label in the macro , when assembled
    @ Flash2Ram _buff , _String1 , produces
    000168 0E00               M    movlw   UPPER _String1
    0016A 6EF8                 M    movwf   TBLPTRU
    00016C 0E01               M    movlw   HIGH _String1
    00016A 6EF8               M    movwf   TBLPTRU
    00016E 6EF7               M    movwf   TBLPTRH
    000170 0E3E               M    movlw   LOW _String1
    000172 6EF6               M    movwf   TBLPTRL
    000174 0E1A               M    movlw   low _buff
    000176 6ED9               M    movwf   FSR2L
    000178 0E00               M    movlw   High _buff
    00017A 6EDA               M    movwf   FSR2H
                              M    L?CALL  _bfill
    the label "buffer" is replaced with the symbol of the intended target
    at no stage do we actually write directly to the "buffer" we simply load its address (from the symbol table) into the fsr regs
    the bfill subroutine then fills the "buffer" indirectly via the fsr regs
    macro's are not subroutines they are just another shortcut way to save typing, every time the macro is encountered the real code as above is inserted into your program
    Italy
    Yes, but while _String1 is a fixed address that point to a univoque ROM location, isn't _buff a RAM location that points to different register according to the current bank ?
    Marco
    evidently I'm not explaining it well
    we never write directly to _buff we do it 'indirectly' via the 16 bit full address in fsr2 its called INDIRECT ADDRESSING read the chapter in the data sheet ,(this is how pic18's have arrays that can be bigger than a ram bank)
    bank select is not applicable to indirect addressing
    observe symbol table
    inbuff  var byte[30]
     buff var byte[30]       $500
    SYMBOL TABLE
    LABEL VALUE
    _STVREN_OFF_4L 000000FE
    _STVREN_ON_4L 000000FF
    _StartLoop 00000168
    _String1 0000013E
    _String2 00000150
    _TRISH 00000F94
    _TRISL 00000F93
    _WDTEN_OFF_2H 000000FE
    _WDTEN_ON_2H 000000FF
    _WDTPS_1024_2H 000000F5
    _WDTPS_128_2H 000000EF
    _WDTPS_16384_2H 000000FD
    _WDTPS_16_2H 000000E9
    _WDTPS_1_2H 000000E1
    _WDTPS_2048_2H 000000F7
    _WDTPS_256_2H 000000F1
    _WDTPS_2_2H 000000E3
    _WDTPS_32768_2H 000000FF
    _WDTPS_32_2H 000000EB
    _WDTPS_4096_2H 000000F9
    _WDTPS_4_2H 000000E5
    _WDTPS_512_2H 000000F3
    _WDTPS_64_2H 000000ED
    _WDTPS_8192_2H 000000FB
    _WDTPS_8_2H 000000E7
    _WRT0_OFF_6L 000000FF
    _WRT0_ON_6L 000000FE
    _WRT1_OFF_6L 000000FF
    _WRT1_ON_6L 000000FD
    _WRT2_OFF_6L 000000FF
    _WRT2_ON_6L 000000FB
    _WRT3_OFF_6L 000000FF
    _WRT3_ON_6L 000000F7
    _WRTB_OFF_6H 000000FF
    _WRTB_ON_6H 000000BF
    _WRTC_OFF_6H 000000FF
    _WRTC_ON_6H 000000DF
    _WRTD_OFF_6H 000000FF
    _WRTD_ON_6H 0000007F
    _XINST_OFF_4L 000000BF
    _XINST_ON_4L 000000FF
    __18F45K20 00000001
    _bfill 0000022C
    _buff 00000500
    _inbuff 0000001A
    main 000000EA
    pauseloop 000000A6
    pauseusloop 000000C2
    ser2delay 0000007C
    serout2bit 0000004E
    serout2done 0000004A
    serout2loop 00000022
    serout2norm 00000068
    buff var byte[30] $4f0 ; buff is now straddles banks 4 and 5
    _buff 000004F0 symbol table
    code still works perfectly as expected
    Italy
    Richard,
    the source of my doubts is that I have some unexpected behaviours and I'm trying to understand where is the problem.
    Watching the program memory, I found some "00" chars here and there in the middle of the string
    Lets' say the string "Hello",0 when I look the program memory is 48 65 6C 00 6C 6F 00
    I'm discovering now that the directive "da" is only for PIC12/16 and not for PIC18
    http://ww1.microchip.com/downloads/e...Doc/33014J.pdf
    I think I should use "db" or "data", I'm trying to understand
    "db" seems to work fine
    how are you looking at the pgm memory , I think something is not right
    for me the da and data directives produce exactly the same result , I left the da directive in, thinking I might try the code on a pic16f1825 for a learning experience , for 7 bit ascii data either will do (pic 18's can store 2x8 bit ,pic 16's 2x7bit )
    the relevant listings
    0013E 6854 7369 6920 00199  data "This is a string",0
              2073 2061 7473
              6972 676E 0000
    00013E 6854 7369 6920 00199  da "This is a string",0
                2073 2061 7473
                6972 676E 0000
    I think it might have something to do with the number of bytes (odd or even) in the string.
    In both of Richards examples there's an even number of bytes (16 and 22) but your Hello string there's an odd number of bytes (5). I seem to remember an issue with this being discussed in one of the 'Strings in codespace' threads some years ago.
    odd length strings , wastes space but not a problem
    00013E 6854 7369 6920 00199 data "This is a string1",0
    2073 2061 7473
    6972 676E 0031
    0000
    00013E 6854 7369 6920 00199 da "This is a string1",0
    2073 2061 7473
    6972 676E 0031
    0000
    00013E 6548 6C6C 006F 00199 da "Hello",0
    0000
    there's another little cheat if all the strings are odd length the 0 terminator is redundant
    Italy
    Found the problem.
    I have a string like this:
    say "hello"
    I use this format do declare it, the same format I was using with arraywrite
    @ da "say",34,"hello",34,0
    The result in program memory is that before each char 34 is added a char 00
    If I use "db" instead the result is correct.
    The pdf I linked before says that "da" is not for PIC18
    where ?
    da – Data ASCII.
    Generates a packed 14-bit number representing two 7-bit ASCII characters.
  1. String of characters(array) to decimal value
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 20th June 2012, 15:30
  2. Replies: 3
    Last Post: - 3rd December 2011, 23:48
  3. Array of string to send with TX int ?
    By amgen in forum General
    Last Post: - 18th August 2011, 17:56
  4. How to send a string with another string inside it?
    Last Post: - 13th May 2011, 18:11
  5. Manipulation of string array
    By Benny007 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 21:50
